I am trying to find a way to check all of the ports on a switch simultaneously using EEM. My goal is to have an applet or script that will be able to read the syslog and look for ports that are either up or down. Can anyone help?
More details are needed. Please post the syslog message you want to react to. While EEM cannot check all ports "simultaneously" it can react to a syslog message and then check the state of a port or multiple ports.
Learn, share, save
