EEM Applet SSH won't get passed Enable Prompt
Cory Anderson
Hi All,
I'm not sure what the issue is, but I've created an SSH Applet to log into an ASA from an ISR.  If I debug, I see that it logs in, and sends "enable" but never gets a "Password:" response.
Here's the script:
event manager applet FIREWALL
event action timer watchdog time 60
action 1.0 cli command "enable"
action 2.0 cli command "ssh -l username 1.1.1.1" pattern "assword:"
action 3.0 cli command "SecretPassword00**" pattern ">"
action 4.0 cli command "enable" pattern "assword:"
action 5.0 cli command "enablePassword123!@#" pattern "#"
action 6.0 cli command "show conn address 2.2.2.2"
action 7.0 cli command "exit"
action 8.0 cli command "exit"
I believe these are all the relevant logs.
%HA_EM-6-LOG: FIREWALL : DEBUG(cli_lib) : : OUT : FIREWALL>
%HA_EM-6-LOG: FIREWALL : DEBUG(cli_lib) : : IN : enable
%HA_EM-6-LOG: FIREWALL : DEBUG(cli_lib) : : CTL : cli_close called
Joe Clarke
You might try relaxing the pattern.  Maybe try .* to see what you get.  Of course, you should run through this exact thing manually from the router to see exactly what you see at each step.
Hi Joseph!  Thanks for the response.  I changed the pattern from line 4.0 down to "*", but I have the same results.  I even tried removing the patterns with no change.
A * by itself is wrong.  You need to use ".*".  But have you tried these same sequence of commands manually from the same router?  Are the prompts what you expect?
