EEM Auto Access Point Scipt
alexanderkieser
Frequent Visitor
Frequent Visitor
So I'm having a small issue, the following script will work, but after some time the interface will revert to the detect-AP-remove EEM.
event manager applet detect-AP-add authorization bypass
 event neighbor-discovery interface regexp Ethernet.* cdp add
 action 1.0 regexp "(AIR-)" "$_nd_cdp_platform"
 action 2.0 if $_regexp_result eq 1
 action 3.0  cli command "enable"
 action 4.0  cli command "config t"
 action 5.0  cli command "default interface $_nd_local_intf_name"
 action 5.1  cli command "int $_nd_local_intf_name"
 action 5.2  cli command "switch access vlan 500"
 action 5.3  cli command "switchport mode access"
 action 5.4  cli command "load-interval 30"
 action 5.5  cli command "spanning-tree portfast"
 action 5.6  cli command "spanning-tree link-type shared"
 action 6.0  cli command "end"
 action 6.1  cli command "exit"
 action 7.0 end
event manager applet detect-AP-remove authorization bypass
 event neighbor-discovery interface regexp Ethernet.* cdp delete
 action 5.2  cli command "switchport mode access"
 action 5.3  cli command "switchport access vlan 205"
 action 5.4  cli command "spanning-tree portfast"
 action 5.5  cli command "switchport nonegotiate"
 action 7.0 end
3750-Switch-TESTING#show cdp ne
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
AP649e.f32f.XXXX Fas 1/0/43        173              R T   AIR-LAP11 Gig 0.1
3750-Switch-TESTING#show run int Fas 1/0/43
Building configuration...
Current configuration : 136 bytes
interface FastEthernet1/0/43
end
Any help would be appreciated, or even converting two EEM's into one ? Basiclly a AP connects, the EEM kicks off and configures the interface accordingly, once disconnected or removed form CDP, it'll re-configure the interface to a regular user interface,
2 Accepted Solutions
Joe Clarke
You can't use the cdp delete event as it will cause a bounce.  Instead, use a syslog policy for the second one to look for the link going down.  I did this for CiscoLive US.  You can read about it in the blog linked from this community.
You realize that your port description contains "CDP -" and the logic you have your reset applet will abort if the port description contains CDP?  Seems like it's working as designed.
6 Replies 6
Joe Clarke
So this is what I've updated to, and doesn't look the second part is working, any input is appreciated 🙂
 action 7.0 end
event manager applet reset-port authorization bypass
 event syslog pattern "LINK-3-UPDOWN.*Interface Ethernet.* changed state to down"
 action 001  regexp "Interface ([^,]+)" $_syslog_msg match intf
 action 002  cli command "enable"
 action 003  cli command "show int $intf | inc Description:"
 action 004  regexp "CDP -" $_cli_result
 action 005  if $_regexp_result eq 1
 action 006   exit 0
 action 007  end
 action 008  cli command "config t"
 action 009  cli command "default interface $intf"
 action 010  cli command "interface $intf"
 action 011  cli command "switchport mode access"
 action 012  cli command "switchport access vlan 205"
 action 017  cli command "switchport nonegotiate"
 action 020  cli command "spanning-tree portfast"
 action 021  cli command "end"
3750-Switch-TESTING#show run int fa1/0/43
Current configuration : 217 bytes
 description CDP - Alex-Personal-AP:GigabitEthernet0.1
 switchport access vlan 500
 load-interval 30
end
Your second regexp is wrong.  If you want to match on all Ethernet interfaces, use:
LINK-3-UPDOWN.*Interface .*Ethernet.* changed state to down
I've updated, and the interface still doesn't update once the AP interface goes down;
Sep 11 18:38:09.967: %LINK-3-UPDOWN: Interface FastEthernet1/0/43, changed state to down
Sep 11 18:38:11.167: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/43, changed state to down
Sep 11 18:38:13.919: %LINK-3-UPDOWN: Interface FastEthernet1/0/43, changed state to up
Sep 11 18:38:14.925: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0/43, changed state to up
Sep 11 18:39:48.645: %SYS-5-CONFIG_I: Configured from console by  on vty1 (EEM:detect-mac)
Sep 11 18:39:52.160: %SYS-5-CONFIG_I: Configured from console by  on vty3 (EEM:CDP)
Sep 11 18:39:54.609: %SYS-5-CONFIG_I: Configured from console by  on vty1 (EEM:detect-AP-add)
 action 7.0 end
 event syslog pattern "LINK-3-UPDOWN.*Interface .*Ethernet.* changed state to down"
 action 006   exit 0
 action 007  end
And that's why you are the man!
