EEM CLI Commands not executing
scecie1977
Community Member
I am new to scripting, SLA and EEM and have been browsing the forums and documenation for a couple of days now learning what I can.  I cannot get my event manager applet to trigger for some reason.  I do get the following Syslog message based on my ip sla reaction config:
Aug  4 21:25:13.915: %RTT-3-IPSLATHRESHOLD: IP SLAs(100): Threshold Occurred for timeout
My configuration is below
ip sla 100
icmp-echo 2.2.2.2 source-ip 1.1.1.1
threshold 1000
timeout 1000
frequency 1
ip sla schedule 100 start now life forever
ip sla reaction-config 100 react timeout threshold-type xofy 2 5 action-type trapOnly
event manager applet ipsla-ploss
 description PROACTIVE WAN PACKET LOSS SCRIPT
 event ipsla operation-id 100 reaction-type timeout
 action 1.0 cli command "enable"
 action 1.1 cli command "conf t"
 action 1.2 cli command "ip access-list standard bgp-routes-in"
 action 1.3 cli command "5 deny 5.5.5.5"
 action 1.4 cli command "6 deny 6.6.6.6"
 action 1.5 cli command "end"
Any help is greatly appreciated!
Add the following to your config:
ip sla logging
ip sla enable reaction-alerts
6 Replies 6
Joe Clarke
Please enable "debug event manager action cli" and then post the log output after reproducing the trigger.
Hi Joe, I get no output from the debug, only the following shows up in the logs:
Aug 5 09:01:14.092: %RTT-3-IPSLATHRESHOLD: IP SLAs(100): Threshold Occurred for timeout
Aug 5 09:01:17.932: %TRACK-6-STATE: 5 ip sla 100 reachability Up -> Down
FYI, this is on a 2911 running 15.4(3)M4 with perm licenses for security and uc.  Also, I have through testing been able to get EEM to trigger off a tracking event and make CLI changes on this router, but that doesn't give me what I need and was just to verify that I set up the username privileges correctly.
Shawn
ip sla logging
Awesome...I was missing the "ip sla enable reaction-alerts" command. Now I just have to figure out how to fix it so it only triggers when the connection goes down, and not also when it restores. Any hints on that?
if $_ipsla_condition eq "Occurred"
end
This worked like a charm. Thanks so much Joe!
