SSH: Could not get a vty line for incoming session
Hi All,
I'm having a strange issue setting up a 887 when I'm trying to set it up for ssh access.
starting from an erase startup and reload I enter the following commands
Router#conf t
Router(config)#hostname test-rtr
test-rtr(config)#ip domain-name dom.ain
test-rtr(config)#username cisco password cisco
test-rtr(config)#enable secret 0 cisco
test-rtr(config)#int vlan 1
test-rtr(config-if)#ip add
test-rtr(config-if)#ip address 172.17.2.75 255.255.255.128
test-rtr(config-if)#no sh
test-rtr(config)#crypto key generate rsa modulus 1024
% Generating 1024 bit RSA keys, keys will be non-exportable...
[OK] (elapsed time was 1 seconds)
test-rtr(config)#
*Aug 5 14:45:41.995: %SSH-5-ENABLED: SSH 1.99 has been enabled
test-rtr(config)#ip ssh ver
test-rtr(config)#ip ssh version 2
test-rtr(config)#line vty 0 15
test-rtr(config-line)#transport pre
test-rtr(config-line)#transport preferred ssh
test-rtr(config-line)#logi
test-rtr(config-line)#login local
So once all that is done.
I run debug ip ssh
when I try to login to the device by ssh I get
*Aug  5 14:49:46.827: SSH: Could not get a vty line for incoming session
Has anyone seen what I'm missing here ?
Mark
Never mind found my problem,
On lines vty 0 15 I had accidentally left the the config as
transport input none
having forgot to set it to
transport input ssh
Somedays you gotta take a break to see the wood from the trees and on other days you gotta ask for directions from a friend
