EEM: cli pattern of multiple lines
smitsialis
Frequent Visitor
Frequent Visitor
I'm trying to create a script that will perform an action when a port is configured with specific VLANs.  I need to know which interface was configured in order to be able to take action.  Problem is only the 2nd line shows up in the $_cli_msg.
event manager applet testapp1
 description "when port configured for vlans 825 command issued to enable poe"
 event tag 1 cli pattern "interface GigabitEthernet" sync no occur 1 skip no
 event tag 2 cli pattern "switchport access vlan 825" sync no occur 1 skip no
 trigger
 correlate even 1 or event 2
 exit
 action 1.0 set intf ""
 action 1.2 set interf ""
 action 2.0  regexp "GigabitEthernet[0-9/]+" $_cli_msg intf
 action 2.2  if $_regexp_result ne 1
 action 2.4      set interf $intf
 action 2.5      syslog msg "in the if section, $intf, $interf"
 action 2.6 end
 action 4.0 syslog msg  "Message: $_cli_msg, INTERFACE $intf"
The script runs twice, once per line so I dont get the interface the 2nd time it runs.  How can I do this differently to make it work?
Spiro
Joe Clarke
This is actually extremely complex to do.  What you have here will absolutely not work as you've already seen.  What you can do is enable config archive so it will record the CLI history:
archive
 log config
  logging enable
Then run the "show archive log config user $_cli_username 0" command and parse the output to find the interface.  The last line should be the interface.  Plus you can compare the VTY on that line to $_cli_tty to make sure the user didn't have multiple sessions.  See, not easy :-).  But it can be done.
