EEM compare string not working
ez9
I tried to create an eem applet where i want to compare a string value with the content of a file in flash. My applet is below:
event manager applet TEST
event none
action 1.0 cli command "enable"
action 1.3 cli command "more flash:test | include teststring"
action 1.5 string equal "teststring" "$_cli_result"
action 1.6 if $_string_result eq "1"
action 1.6.1 syslog msg "Success"
action 1.7 end
In file i have only the word 'teststring' but the Success syslog message never logged....
i tried also to match my strings with if statement (without string equal) but without success.
Joe Clarke
When you use CLI to gather data, the result will never just be one word (or one line).  Try this code instead:
action 1.5 regexp "teststring" "$_cli_result"
action 1.6 if $_regexp_result eq "1"
