EEM Configure interface based on description
ThatSander
I am trying to create a script that configures an interface based on what description you have configured it as. For example if I set "description PRINT" on a interface I want the interface to get configured as a trunk interface. I have managed to complete both the EEM applet and the python script but it is not working as I want it to. The python script need to know the interface to be able to configure, I have done this by writing %s as you can see below. But when I write the action for the EEM applet where it says "guestshell run python /flash/confscript1.py" I need to write a interface, for example GigabitEthernet1/0/1. I can for example write GigabitEthernet1/0/1 instead of GigabitEthernet* and it works to configure that interface. However I want it to be able to configure any interface and not just one specific. Is there any simple way to do this?
EEM
event manager applet AUTO_CONFIGURE
event cli pattern "description ADM" sync no skip yes
action 0.0 cli command "enable"
action 1.0 cli command "guestshell run python /flash/confscript1.py GigabitEthernet*"
Python script
import sys
from cli import cli,clip,execute,executep,configure,configurep
intf= sys.argv[1:]
intf = ''.join(intf[0])
print ('This script is going configure interface %s'%intf)
if intf != 'Fo1/1/2':
cmd='int %s,switchport mode trunk, switchport trunk allowed vlan 540,end' % intf
configurep(cmd.split(','))
executep('show ip interface brief')
Thanks in advance!
0 Replies 0
