EEM crash router
Hi there,
The below script when run with cmd  "event manager run showIP" will always crash the router but i cant see why. It will run through, output the correct info and then the router will crash.
Any suggestions?
event manager applet showIP
event none max run 20
action 1010 cli command "enable"
action 1020 cli command "show ip int brief | include 10.64.129|192.168.20"
action 1021 puts "Test: $_cli_result"
action 1030 set noCalls "0"
action 1040 foreach line $_cli_result "\n"
action 1041  put "Line: $line"
action 1050  increment noCalls
action 1060 end
action 1070 puts "No of Calls: $noCalls"
Alexis
http://www.netpacket.co.uk/
http://www.blog.netpacket.co.uk/
http://www.netpacket.co.uk/ http://www.blog.netpacket.co.uk/
mtimm
Try changing the:
To something like:
action 1050 add $noCalls 1
action 1051 set noCalls "$_result"
If that avoids the crash, then this is caused by CSCud31581 where the increment command causes memory corruption.
Mike
10 Replies 10
Joe Clarke
What is the stack trace from the crash?  Post that and the output of the "show stack" command.
Hi there,
I have just included the part that I think its relevent ... unless you require the hole stack file?
CMD: ' action 1010 cli command "enable"' 11:52:43 UTC Thu Mar 7 2013
CMD: ' action 1020 cli command "show ip int brief | include 10.64.129|192.168.20"' 11:52:43 UTC Thu Mar 7 2013
CMD: ' action 1030 set noCalls "0"' 11:52:43 UTC Thu Mar 7 2013
CMD: ' action 1040 foreach line $_cli_result "\n" ' 11:52:43 UTC Thu Mar 7 2013
CMD: ' action 1050  increment noCalls' 11:52:43 UTC Thu Mar 7 2013
CMD: ' action 1060 end' 11:52:43 UTC Thu Mar 7 2013
CMD: ' action 1070 puts "No of Calls: $noCalls"' 11:52:44 UTC Thu Mar 7 2013
CMD: 'exit' 11:52:46 UTC Thu Mar 7 2013
CMD: 'exit' 11:52:47 UTC Thu Mar 7 2013
*Mar  7 11:52:47.548: %SYS-5-CONFIG_I: Configured from console by xxx on vty0 (10.64.164.64)
CMD: 'event manager run showIP' 11:52:49 UTC Thu Mar 7 2013
CMD: 'enable' 11:52:49 UTC Thu Mar 7 2013
CMD: 'show ip int brief | include 10.64.129|192.168.20' 11:52:49 UTC Thu Mar 7 2013
CMD: 'show ip int brief | include 10.64.129|192.168.20' 11:52:56 UTC Thu Mar 7 2013
*Mar  7 11:53:33.630: %SYS-2-CHUNKBADMAGIC: Bad magic number in chunk header, chunk 29C98534  data 29CA605C  chunkmagic A3C78B  chunk_freemagic EF4321CD -Process= "Check heaps", ipl= 0, pid= 6
-Traceback= 18E87A5z 2BF335Dz 2BF2F2Bz 1061F1z
chunk_diagnose, code = 1
chunk name is MallocLite
current chunk header = 0x29CA604C
data check, ptr = 0x29CA605C
next chunk header = 0x29CA6068
data check, ptr = 0x29CA6078
previous chunk header = 0x29CA6030
data check, ptr = 0x29CA6040
========= Dump chunk = 0x29CA604C ======================
29CA5F5C: 29C98534 EF4321CD        0        0 15A3C78B        0  2C4A6BF 29C98534
29CA5F7C: EF4321CD        0        0 15A3C78B        0  2C4A6BF 29C98534 EF4321CD
29CA5F9C:        0        0 15A3C78B        0  2C4A6BF 29C98534 EF4321CD        0
29CA5FBC:        0 15A3C78B        0  2C4A6BF 29C98534 EF4321CD        0        0
29CA5FDC: 15A3C78B        0  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B
29CA5FFC:        0  5B73B23 29C98534 EF4321CD  5B8C012  B0D0B0D 15A3C78B        0
--More--
29CA601C:  1BF2566 29C98534 EF4321CD  1BF2832  B0D0B0D 15A3C78B        0  1C0C46F
29CA603C: 29C98534 EF4321CD  1C0C4CA  B0D0B0D   A3C78B        0  1C1D277 29C98534
29CA605C: EF4321CD  1C1BF9A  B0D0B0D 15A3C78B        0  1C1D277 29C98534 EF4321CD
29CA607C:  1C1BF9A  B0D0B0D 15A3C78B        0  1C1D277 29C98534 EF4321CD  1C1BF9A
29CA609C:  B0D0B0D 15A3C78B        0  1BEED44 29C98534 EF4321CD  1C0879D  B0D0B0D
29CA60BC: 15A3C78B        1  2C4A6BF 29C98534        0        0        0 15A3C78B
29CA60DC:        0  1BF2566 29C98534 EF4321CD  1BF2832  B0D0B0D 15A3C78B        0
29CA60FC:  1BF2566 29C98534 EF4321CD  1BF2832  B0D0B0D 15A3C78B        0  1C1D277
29CA611C: 29C98534 EF4321CD  1C1BF9A  B0D0B0D 15A3C78B        0  1C1ACBB 29C98534
29CA613C: EF4321CD  1C1AFD4  B0D0B0D 15A3C78B        0  1C1ACBB 29C98534 EF4321CD
========= Dump chunk_next = 0x29CA6068 ======================
29CA5F68:        0 15A3C78B        0  2C4A6BF 29C98534 EF4321CD        0        0
29CA5F88: 15A3C78B        0  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B
29CA5FA8:        0  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B        0
29CA5FC8:  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B        0  2C4A6BF
29CA5FE8: 29C98534 EF4321CD        0        0 15A3C78B        0  5B73B23 29C98534
29CA6008: EF4321CD  5B8C012  B0D0B0D 15A3C78B        0  1BF2566 29C98534 EF4321CD
29CA6028:  1BF2832  B0D0B0D 15A3C78B        0  1C0C46F 29C98534 EF4321CD  1C0C4CA
29CA6048:  B0D0B0D   A3C78B        0  1C1D277 29C98534 EF4321CD  1C1BF9A  B0D0B0D
29CA6068: 15A3C78B        0  1C1D277 29C98534 EF4321CD  1C1BF9A  B0D0B0D 15A3C78B
29CA6088:        0  1C1D277 29C98534 EF4321CD  1C1BF9A  B0D0B0D 15A3C78B        0
29CA60A8:  1BEED44 29C98534 EF4321CD  1C0879D  B0D0B0D 15A3C78B        1  2C4A6BF
29CA60C8: 29C98534        0        0        0 15A3C78B        0  1BF2566 29C98534
29CA60E8: EF4321CD  1BF2832  B0D0B0D 15A3C78B        0  1BF2566 29C98534 EF4321CD
29CA6108:  1BF2832  B0D0B0D 15A3C78B        0  1C1D277 29C98534 EF4321CD  1C1BF9A
29CA6128:  B0D0B0D 15A3C78B        0  1C1ACBB 29C98534 EF4321CD  1C1AFD4  B0D0B0D
29CA6148: 15A3C78B        0  1C1ACBB 29C98534 EF4321CD  1C1AFD4  B0D0B0D 15A3C78B
========== Dump chunk_previous = 0x29CA6030 =====================
29CA5F30:        0 15A3C78B        0  2C4A6BF 29C98534 EF4321CD        0        0
29CA5F50: 15A3C78B        0  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B
29CA5F70:        0  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B        0
29CA5F90:  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B        0  2C4A6BF
29CA5FB0: 29C98534 EF4321CD        0        0 15A3C78B        0  2C4A6BF 29C98534
29CA5FD0: EF4321CD        0        0 15A3C78B        0  2C4A6BF 29C98534 EF4321CD
29CA5FF0:        0        0 15A3C78B        0  5B73B23 29C98534 EF4321CD  5B8C012
29CA6010:  B0D0B0D 15A3C78B        0  1BF2566 29C98534 EF4321CD  1BF2832  B0D0B0D
29CA6030: 15A3C78B        0  1C0C46F 29C98534 EF4321CD  1C0C4CA  B0D0B0D   A3C78B
29CA6050:        0  1C1D277 29C98534 EF4321CD  1C1BF9A  B0D0B0D 15A3C78B        0
29CA6070:  1C1D277 29C98534 EF4321CD  1C1BF9A  B0D0B0D 15A3C78B        0  1C1D277
29CA6090: 29C98534 EF4321CD  1C1BF9A  B0D0B0D 15A3C78B        0  1BEED44 29C98534
29CA60B0: EF4321CD  1C0879D  B0D0B0D 15A3C78B        1  2C4A6BF 29C98534        0
--More--
29CA60D0:        0        0 15A3C78B        0  1BF2566 29C98534 EF4321CD  1BF2832
29CA60F0:  B0D0B0D 15A3C78B        0  1BF2566 29C98534 EF4321CD  1BF2832  B0D0B0D
29CA6110: 15A3C78B        0  1C1D277 29C98534 EF4321CD  1C1BF9A  B0D0B0D 15A3C78B
Corrupted magic value in in-use chunk
%Software-forced reload
Cheers
Alexis
I also need the show version and show region output.
See below...
Alexis
MLIV001-010CVG02#show version
Cisco IOS Software, C3900e Software (C3900e-UNIVERSALK9-M), Version 15.2(4)M2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 07-Nov-12 17:47 by prod_rel_team
ROM: System Bootstrap, Version 15.1(1r)T4, RELEASE SOFTWARE (fc1)
MLIV001-010CVG02 uptime is 2 hours, 16 minutes
System returned to ROM by bus error at PC 0x18D7307, address 0x18D7307 at 11:53:44 UTC Thu Mar 7 2013
System image file is "flash:c3900e-universalk9-mz.SPA.152-4.M2.bin"
Last reload type: Normal Reload
Last reload reason: bus error at PC 0x18D7307, address 0x18D7307
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3925-CHASSIS (revision 1.0) with C3900-SPE200/K9 with 752640K/295936K bytes of memory.
Processor board ID FGL155111EW
4 Gigabit Ethernet interfaces
2 Channelized E1/PRI ports
DRAM configuration is 72 bits wide with parity enabled.
256K bytes of non-volatile configuration memory.
255744K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
--More--                           Device#      PID            SN
--More--                           -------------------------------------------------
--More--                           *0        C3900-SPE200/K9       FOC15475D97
--More--
Technology Package License Information for Module:'c3900e'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
uc            uck9          Permanent      uck9
data          None          None           None
MLIV001-010CVG02#
MLIV001-010CVG02#
MLIV001-010CVG02#
MLIV001-010CVG02#
MLIV001-010CVG02#sh
MLIV001-010CVG02#show region
Region Manager:
      Start         End     Size(b)  Class  Media  Name
0x00000000  0x000FFFFF     1048576  IText  R/W    bios
0x00100000  0x3E0FFFFF  1040187392  Local  R/W    main
0x0010176C  0x05D2126F    96598788  IText  R/O    main:text
0x05D21280  0x0BB985CF    99054416  IData  R/W    main:data
0x07FAEB00  0x08838F5F     8954976  Local  R/W    data:heap
0x0BB985D0  0x0C7FB77F    12988848  IBss   R/W    main:bss
0x0C7FB780  0x1E8FB77F   303038464  Iomem  R/W    main:iomem
0x1E8FB780  0x3BFFFFFF   493897856  Local  R/W    main:main
0x1E8FB780  0x3BFFFFFF   493897856  Local  R/W    main:heap
Free Region Manager:
MLIV001-010CVG02#
Can you post the crashinfo file from this crash?  The region has changed since the router reloaded.
Hope this is what your looking for.
Alexis
MXXX001-010CVG02#more  flash:crashinfo_20130307-115344-UTC
Writing crashinfo to flash0:crashinfo_20130307-115344-UTC013
CMD: 'enable' 12:15:00 UTC Fri Mar 1 2013
CMD: 'show event manager environment count15min503' 12:15:00 UTC Fri Mar 1 2013
CMD: 'show event manager environment count1hour503' 12:15:00 UTC Fri Mar 1 2013
CMD: 'show clock' 12:15:00 UTC Fri Mar 1 2013
CMD: 'config t' 12:15:01 UTC Fri Mar 1 2013
CMD: 'event manager environment count15min503 0' 12:15:01 UTC Fri Mar 1 2013
CMD: 'config t' 12:18:25 UTC Fri Mar 1 2013
CMD: 'no event manager environment count15min503 0' 12:18:26 UTC Fri Mar 1 2013
CMD: 'no event manager environment count1hour503 0' 12:18:26 UTC Fri Mar 1 2013
CMD: 'no event manager applet Capture_503' 12:18:26 UTC Fri Mar 1 2013
CMD: 'no event manager applet Notify15min' 12:18:26 UTC Fri Mar 1 2013
CMD: 'event manager environment _email_server x.x.x.x' 12:18:26 UTC Fri Mar 1 2013
CMD: 'event manager environment _email_to alex_@x.x.x.x.com' 12:18:26 UTC Fri Mar 1 2013
CMD: 'event manager applet Notify15min' 12:18:26 UTC Fri Mar 1 2013
CMD: ' event timer cron cron-entry "0,30 * * * *"' 12:18:26 UTC Fri Mar 1 2013
CMD: ' action 1010 cli command "enable"' 12:18:26 UTC Fri Mar 1 2013
CMD: ' action 1020 cli command "show voip rtp connections | inc 159|162"' 12:18:26 UTC Fri Mar 1 2013
CMD: ' action 1040 mail server "$_email_server" to "$_email_to" from "$_email_to" subject "Call Volume from MXXX001-010CVG02" body "Report\n========\n$_cli_result\n"' 12:18:27 UTC Fri Mar 1 2013
CMD: 'exit' 12:18:33 UTC Fri Mar 1 2013
CMD: 'exit' 12:18:34 UTC Fri Mar 1 2013
*Mar  1 12:18:34.708: %SYS-5-CONFIG_I: Configured from console by katsavra on vty0 (x.x.x.x)
CMD: 'sh run' 12:18:36 UTC Fri Mar 1 2013
CMD: '     wr mem' 12:18:44 UTC Fri Mar 1 2013
CMD: 'sh run' 12:19:07 UTC Fri Mar 1 2013
CMD: 'enable' 12:30:00 UTC Fri Mar 1 2013
CMD: 'show voip rtp connections | inc 159|162' 12:30:00 UTC Fri Mar 1 2013
CMD: 'sh run' 12:33:40 UTC Fri Mar 1 2013
CMD: 'enable' 13:00:00 UTC Fri Mar 1 2013
CMD: 'show voip rtp connections | inc 159|162' 13:00:00 UTC Fri Mar 1 2013
CMD: 'enable' 13:30:59 UTC Fri Mar 1 2013
CMD: 'show voip rtp connections | inc 159|162' 13:31:00 UTC Fri Mar 1 2013
CMD: 'terminal length 0' 14:00:59 UTC Fri Mar 1 2013
CMD: 'terminal width 0' 14:00:59 UTC Fri Mar 1 2013
CMD: 'enable' 14:00:59 UTC Fri Mar 1 2013
CMD: 'show voip rtp connections | inc 159|162' 14:01:00 UTC Fri Mar 1 2013
CMD: 'show privilege' 14:04:17 UTC Fri Mar 1 2013
CMD: 'show startup' 14:04:18 UTC Fri Mar 1 2013
CMD: 'show running' 14:04:20 UTC Fri Mar 1 2013
CMD: 'enable' 14:30:59 UTC Fri Mar 1 2013
CMD: 'show voip rtp connections | inc 159|162' 14:31:00 UTC Fri Mar 1 2013
CMD: 'sh run' 14:34:11 UTC Fri Mar 1 2013
--More--
CMD: '              config t' 14:34:20 UTC Fri Mar 1 2013
CMD: 'no event manager environment _email_server x.x.x.x' 14:34:26 UTC Fri Mar 1 2013
CMD: 'no event manager environment _email_to alex_katsavras@x.x.x.x.com' 14:34:32 UTC Fri Mar 1 2013
CMD: 'no event manager applet Notify15min' 14:34:37 UTC Fri Mar 1 2013
CMD: 'do sh run' 14:34:44 UTC Fri Mar 1 2013
CMD: 'sh run' 14:34:44 UTC Fri Mar 1 2013
CMD: '8~' 14:34:46 UTC Fri Mar 1 2013
CMD: 'exit' 14:34:48 UTC Fri Mar 1 2013
*Mar  1 14:34:48.169: %SYS-5-CONFIG_I: Configured from console by katsavra on vty0 (10.64.164.242)
CMD: 'exit' 14:37:03 UTC Fri Mar 1 2013
CMD: 'terminal length 0' 06:47:39 UTC Sat Mar 2 2013
CMD: 'terminal width 0' 06:47:40 UTC Sat Mar 2 2013
CMD: 'show privilege' 06:53:22 UTC Sat Mar 2 2013
CMD: 'show startup' 06:53:23 UTC Sat Mar 2 2013
CMD: 'show running' 06:53:25 UTC Sat Mar 2 2013
CMD: 'terminal length 0' 14:02:40 UTC Sat Mar 2 2013
CMD: 'terminal width 0' 14:02:41 UTC Sat Mar 2 2013
CMD: 'show privilege' 14:05:40 UTC Sat Mar 2 2013
CMD: 'show running' 14:05:41 UTC Sat Mar 2 2013
CMD: 'terminal length 0' 13:58:36 UTC Sun Mar 3 2013
CMD: 'terminal width 0' 13:58:36 UTC Sun Mar 3 2013
CMD: 'terminal length 0' 13:44:44 UTC Mon Mar 4 2013
CMD: 'terminal width 0' 13:44:44 UTC Mon Mar 4 2013
CMD: 'sh sccp' 18:21:05 UTC Mon Mar 4 2013
CMD: 'sh run' 18:21:10 UTC Mon Mar 4 2013
CMD: 'conf t' 18:21:27 UTC Mon Mar 4 2013
CMD: 'no sccp local Loopback0' 18:21:31 UTC Mon Mar 4 2013
CMD: 'no sccp' 18:21:33 UTC Mon Mar 4 2013
CMD: 'no sccp ccm 10.64.24.31 identifier 1 priority 1 version 7.0' 18:21:38 UTC Mon Mar 4 2013
CMD: 'no sccp ccm group 1' 18:21:43 UTC Mon Mar 4 2013
CMD: 'no dspfarm profile 1 transcode' 18:21:49 UTC Mon Mar 4 2013
CMD: 'dspfarm profile 1 transcode' 18:21:52 UTC Mon Mar 4 2013
CMD: 'sh' 18:21:53 UTC Mon Mar 4 2013
CMD: 'no dspfarm profile 1 transcode' 18:21:59 UTC Mon Mar 4 2013
CMD: 'dspfarm profile 2 conference' 18:22:03 UTC Mon Mar 4 2013
CMD: 'sh' 18:22:04 UTC Mon Mar 4 2013
CMD: 'no dspfarm profile 2 conference' 18:22:14 UTC Mon Mar 4 2013
*Mar  4 18:22:15.106: %SYS-5-CONFIG_I: Configured from console by johnstev on vty0 (10.64.33.49)
CMD: 'sh runb' 18:22:16 UTC Mon Mar 4 2013
CMD: 'sh run ' 18:22:19 UTC Mon Mar 4 2013
CMD: 'conf t' 18:22:32 UTC Mon Mar 4 2013
CMD: 'dspfarm profile 3 mtp' 18:22:32 UTC Mon Mar 4 2013
CMD: 'sh' 18:22:33 UTC Mon Mar 4 2013
--More--
CMD: 'dspfarm profile 3 mtp' 18:22:42 UTC Mon Mar 4 2013
*Mar  4 18:22:42.204: %SYS-5-CONFIG_I: Configured from console by johnstev on vty0 (10.64.33.49)
CMD: 'sh start' 18:22:49 UTC Mon Mar 4 2013
CMD: 'conf t' 18:23:02 UTC Mon Mar 4 2013
CMD: 'dspfarm profile 1 transcode' 18:23:03 UTC Mon Mar 4 2013
CMD: ' description Transcoder' 18:23:03 UTC Mon Mar 4 2013
CMD: ' codec g711ulaw' 18:23:03 UTC Mon Mar 4 2013
CMD: ' codec g711alaw' 18:23:03 UTC Mon Mar 4 2013
CMD: ' codec g729ar8' 18:23:03 UTC Mon Mar 4 2013
CMD: ' codec g729abr8' 18:23:03 UTC Mon Mar 4 2013
CMD: ' maximum sessions 10' 18:23:03 UTC Mon Mar 4 2013
CMD: ' associate application SCCP' 18:23:04 UTC Mon Mar 4 2013
CMD: 'dspfarm profile 2 conference' 18:23:04 UTC Mon Mar 4 2013
CMD: ' codec g711ulaw' 18:23:04 UTC Mon Mar 4 2013
CMD: ' codec g711alaw' 18:23:04 UTC Mon Mar 4 2013
CMD: ' codec g729ar8' 18:23:04 UTC Mon Mar 4 2013
CMD: ' codec g729abr8' 18:23:04 UTC Mon Mar 4 2013
CMD: ' codec g729r8' 18:23:04 UTC Mon Mar 4 2013
CMD: ' codec g729br8' 18:23:05 UTC Mon Mar 4 2013
CMD: ' maximum sessions 7' 18:23:05 UTC Mon Mar 4 2013
CMD: ' associate application SCCP' 18:23:05 UTC Mon Mar 4 2013
CMD: 'dspfarm profile 3 mtp' 18:23:05 UTC Mon Mar 4 2013
CMD: ' description #### MTP FOR RFC2833 ####' 18:23:06 UTC Mon Mar 4 2013
CMD: ' codec g711ulaw' 18:23:06 UTC Mon Mar 4 2013
CMD: ' maximum sessions software 200' 18:23:06 UTC Mon Mar 4 2013
CMD: ' associate application SCCP' 18:23:06 UTC Mon Mar 4 2013
*Mar  4 18:23:07.590: %SYS-5-CONFIG_I: Configured from console by johnstev on vty0 (10.64.33.49)
CMD: 'sh rubn' 18:23:08 UTC Mon Mar 4 2013
CMD: 'sh run' 18:23:10 UTC Mon Mar 4 2013
CMD: 'conf t' 18:23:32 UTC Mon Mar 4 2013
CMD: 'sccp ccm 10.67.17.200 identifier 1 priority 1 version 4' 18:24:07 UTC Mon Mar 4 2013
CMD: 'sccp ccm 10.67.17.200 identifier 1 priority 1 version 4.1' 18:24:20 UTC Mon Mar 4 2013
CMD: 'nosccp ccm 10.64.24.31 identifier 1 priority 1 version 7.0' 18:24:31 UTC Mon Mar 4 2013
CMD: 'no sccp ccm 10.64.24.31 identifier 1 priority 1 version 7.0' 18:24:33 UTC Mon Mar 4 2013
CMD: 'nosccp ccm 10.65.28.158 identifier 2 priority 2 version 7.0' 18:24:39 UTC Mon Mar 4 2013
CMD: 'mo sccp ccm 10.65.28.158 identifier 2 priority 2 version 7.0' 18:24:41 UTC Mon Mar 4 2013
CMD: 'no sccp ccm 10.65.28.158 identifier 2 priority 2 version 7.0' 18:24:44 UTC Mon Mar 4 2013
CMD: 'sccp ccm 10.67.17.200 identifier 1 priority 1 version 4.1' 18:24:49 UTC Mon Mar 4 2013
*Mar  4 18:24:51.560: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (10.64.33.49)
CMD: 'sh run' 18:24:52 UTC Mon Mar 4 2013
CMD: 'sh sccp' 18:25:02 UTC Mon Mar 4 2013
CMD: 'conf t' 18:25:06 UTC Mon Mar 4 2013
CMD: 'sccp' 18:25:07 UTC Mon Mar 4 2013
--More--
CMD: 'sh run' 18:25:16 UTC Mon Mar 4 2013
*Mar  4 18:25:18.876: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (10.64.33.49)
CMD: 'sh start' 18:25:20 UTC Mon Mar 4 2013
CMD: 'conf t' 18:25:39 UTC Mon Mar 4 2013
CMD: 'sccp ccm group 1' 18:25:41 UTC Mon Mar 4 2013
CMD: 'description WOK_CMGroup_1' 18:25:44 UTC Mon Mar 4 2013
CMD: ' associate ccm 1 priority 1' 18:25:45 UTC Mon Mar 4 2013
CMD: 'ex' 18:25:47 UTC Mon Mar 4 2013
CMD: 'sccp' 18:25:49 UTC Mon Mar 4 2013
CMD: 'do sh run' 18:25:55 UTC Mon Mar 4 2013
CMD: 'sh run' 18:25:55 UTC Mon Mar 4 2013
CMD: 'sh start' 18:26:17 UTC Mon Mar 4 2013
*Mar  4 18:26:20.064: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (10.64.33.49)
CMD: 'sh sccp' 18:26:21 UTC Mon Mar 4 2013
CMD: 'conf t' 18:26:30 UTC Mon Mar 4 2013
CMD: 'sccp local loopback 0 ' 18:26:45 UTC Mon Mar 4 2013
CMD: 'sccp' 18:26:58 UTC Mon Mar 4 2013
*Mar  4 18:26:59.920: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (10.64.33.49)
CMD: 'sh sccp' 18:27:01 UTC Mon Mar 4 2013
CMD: 'sh sccp' 18:27:09 UTC Mon Mar 4 2013
CMD: 'conf t' 18:27:12 UTC Mon Mar 4 2013
CMD: 'do sh tart' 18:27:23 UTC Mon Mar 4 2013
CMD: 'sh tart' 18:27:23 UTC Mon Mar 4 2013
CMD: 'do sh start' 18:27:26 UTC Mon Mar 4 2013
CMD: 'sh start' 18:27:26 UTC Mon Mar 4 2013
CMD: 'sccp ccm group 1' 18:27:53 UTC Mon Mar 4 2013
CMD: ' description WOK_CMGroup_1' 18:27:53 UTC Mon Mar 4 2013
CMD: ' associate ccm 1 priority 1' 18:27:53 UTC Mon Mar 4 2013
CMD: ' associate ccm 2 priority 2' 18:27:53 UTC Mon Mar 4 2013
CMD: ' associate profile 3 register XXX-010CVG1-MP2' 18:27:53 UTC Mon Mar 4 2013
CMD: ' associate profile 4 register XXX-010CVG1-MP1' 18:27:53 UTC Mon Mar 4 2013
CMD: ' associate profile 2 register XXX-010CVG1-CB' 18:27:53 UTC Mon Mar 4 2013
CMD: ' associate profile 1 register XXX-010CVG1-XCD' 18:28:01 UTC Mon Mar 4 2013
*Mar  4 18:28:02.696: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (10.64.33.49)
CMD: 'sh sccp' 18:28:04 UTC Mon Mar 4 2013
CMD: 'sh sccp' 18:28:07 UTC Mon Mar 4 2013
CMD: ' sh run' 18:28:12 UTC Mon Mar 4 2013
CMD: 'conf t' 18:28:33 UTC Mon Mar 4 2013
CMD: 'dspfarm profile 1 transcode' 18:28:34 UTC Mon Mar 4 2013
CMD: 'no sh' 18:28:36 UTC Mon Mar 4 2013
CMD: 'dspfarm profile 2 conference' 18:28:39 UTC Mon Mar 4 2013
CMD: 'no sh' 18:28:41 UTC Mon Mar 4 2013
*Mar  4 18:28:42.010: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (x.x.x.x)
--More--
CMD: 'sh run' 18:28:44 UTC Mon Mar 4 2013
CMD: 'onf t' 18:28:52 UTC Mon Mar 4 2013
CMD: 'connect onf t' 18:28:52 UTC Mon Mar 4 2013
CMD: 'conf t' 18:28:53 UTC Mon Mar 4 2013
CMD: 'dspfarm profile 3 mtp' 18:28:54 UTC Mon Mar 4 2013
CMD: 'no sh' 18:28:56 UTC Mon Mar 4 2013
CMD: 'dspfarm profile 4 mtp' 18:28:58 UTC Mon Mar 4 2013
CMD: 'no sh' 18:29:00 UTC Mon Mar 4 2013
*Mar  4 18:29:02.798: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (x.x.x.x)
CMD: 'sh sccp' 18:29:06 UTC Mon Mar 4 2013
CMD: 'sh run' 18:43:09 UTC Mon Mar 4 2013
CMD: 'conf t' 18:43:33 UTC Mon Mar 4 2013
CMD: 'sccp ccm group 1' 18:43:35 UTC Mon Mar 4 2013
CMD: 'associate profile 1 register XXX-010CVG2-XCD' 18:43:41 UTC Mon Mar 4 2013
CMD: 'no associate profile 1 register XXX-010CVG1-XCD' 18:43:47 UTC Mon Mar 4 2013
CMD: 'ex' 18:43:56 UTC Mon Mar 4 2013
CMD: 'ex' 18:43:58 UTC Mon Mar 4 2013
CMD: 'do sh run' 18:44:00 UTC Mon Mar 4 2013
CMD: 'sh run' 18:44:00 UTC Mon Mar 4 2013
*Mar  4 18:49:00.914: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (x.x.x.x)
CMD: 'terminal length 0' 14:00:10 UTC Tue Mar 5 2013
CMD: 'terminal width 0' 14:00:10 UTC Tue Mar 5 2013
CMD: 'show privilege' 14:08:01 UTC Tue Mar 5 2013
CMD: 'show running' 14:08:02 UTC Tue Mar 5 2013
CMD: 'terminal length 0' 13:57:53 UTC Wed Mar 6 2013
CMD: 'terminal width 0' 13:57:54 UTC Wed Mar 6 2013
CMD: 'sh license ' 18:03:47 UTC Wed Mar 6 2013
CMD: 'sh license cme-srst' 18:03:53 UTC Wed Mar 6 2013
CMD: 'sh license fe cme-srst' 18:03:57 UTC Wed Mar 6 2013
CMD: 'sh license detail cme-srst' 18:04:11 UTC Wed Mar 6 2013
CMD: 'sh flash' 18:04:51 UTC Wed Mar 6 2013
CMD: 'sh ver' 18:06:52 UTC Wed Mar 6 2013
CMD: PASSWORD statement not printed
CMD: 'sh flash' 18:13:09 UTC Wed Mar 6 2013
CMD: 'sh lice' 18:18:28 UTC Wed Mar 6 2013
CMD: 'show voip rtp connections ' 10:59:14 UTC Thu Mar 7 2013
CMD: 'do sh run' 10:59:24 UTC Thu Mar 7 2013
CMD: 'sh run' 10:59:35 UTC Thu Mar 7 2013
CMD: 'coonfig t' 11:00:29 UTC Thu Mar 7 2013
CMD: 'connect coonfig t' 11:00:29 UTC Thu Mar 7 2013
CMD: 'config t' 11:00:31 UTC Thu Mar 7 2013
CMD: 'event manager applet showIP' 11:00:32 UTC Thu Mar 7 2013
--More--
CMD: ' event none sync yes' 11:00:32 UTC Thu Mar 7 2013
CMD: ' action 100 cli command "show ip interface brief | include Loopback0"' 11:00:32 UTC Thu Mar 7 2013
CMD: ' action 110 set result "none"' 11:00:32 UTC Thu Mar 7 2013
CMD: ' action 120 regexp " [0-9.]+ " $_cli_result result' 11:00:32 UTC Thu Mar 7 2013
CMD: ' action 130 puts "IP address=*$result*"' 11:00:32 UTC Thu Mar 7 2013
CMD: ' event manager run showIP' 11:00:33 UTC Thu Mar 7 2013
CMD: 'exit' 11:00:35 UTC Thu Mar 7 2013
CMD: 'exit' 11:00:37 UTC Thu Mar 7 2013
*Mar  7 11:00:37.892: %SYS-5-CONFIG_I: Configured from console by katsavra on vty0 (10.64.164.64)
CMD: 'event manager run showIP' 11:00:40 UTC Thu Mar 7 2013
CMD: 'show ip interface brief | include Loopback0' 11:00:40 UTC Thu Mar 7 2013
CMD: 'config t' 11:01:03 UTC Thu Mar 7 2013
CMD: 'event manager applet showIP' 11:01:07 UTC Thu Mar 7 2013
CMD: 'do sh voip rtp conn' 11:01:31 UTC Thu Mar 7 2013
CMD: 'sh voip rtp conn' 11:01:31 UTC Thu Mar 7 2013
CMD: 'action 100 cli command "sh voip rtp conn"' 11:01:52 UTC Thu Mar 7 2013
CMD: 'exit' 11:01:57 UTC Thu Mar 7 2013
CMD: 'exit' 11:02:01 UTC Thu Mar 7 2013
*Mar  7 11:02:01.368: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (10.64.164.64)
CMD: 'event manager run showIP' 11:02:02 UTC Thu Mar 7 2013
CMD: 'sh voip rtp conn' 11:02:02 UTC Thu Mar 7 2013
CMD: 'sh run' 11:02:08 UTC Thu Mar 7 2013
CMD: 'config t' 11:03:09 UTC Thu Mar 7 2013
CMD: 'event manager applet showIP' 11:03:15 UTC Thu Mar 7 2013
CMD: 'action 100 cli command "show voip rtp connections | include 10.64.128"' 11:03:35 UTC Thu Mar 7 2013
CMD: 'exit' 11:03:37 UTC Thu Mar 7 2013
CMD: 'exit' 11:03:38 UTC Thu Mar 7 2013
*Mar  7 11:03:38.796: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (10.64.164.64)
CMD: 'event manager run showIP' 11:03:40 UTC Thu Mar 7 2013
CMD: 'show voip rtp connections | include 10.64.128' 11:03:40 UTC Thu Mar 7 2013
CMD: 'sh ru' 11:03:42 UTC Thu Mar 7 2013
CMD: '       sh run' 11:03:45 UTC Thu Mar 7 2013
CMD: 'event manager run showIP' 11:09:09 UTC Thu Mar 7 2013
CMD: 'show voip rtp connections | include 10.64.128' 11:09:09 UTC Thu Mar 7 2013
CMD: 'show debugging ' 11:09:15 UTC Thu Mar 7 2013
CMD: 'ping 10.64.129.77' 11:30:06 UTC Thu Mar 7 2013
CMD: 'ping 10.64.129.77' 11:32:09 UTC Thu Mar 7 2013
CMD: 'ping 10.64.129.77' 11:32:14 UTC Thu Mar 7 2013
CMD: 'config t' 11:35:57 UTC Thu Mar 7 2013
CMD: 'event manager applet showIP' 11:35:59 UTC Thu Mar 7 2013
CMD: ' event none sync yes' 11:35:59 UTC Thu Mar 7 2013
CMD: ' action 1010 cli command "enable"' 11:35:59 UTC Thu Mar 7 2013
CMD: ' action 1020 cli command "show voip rtp connections | include x.x.x.x"' 11:35:59 UTC Thu Mar 7 2013
--More--
CMD: ' action 1040 set noCalls "0"' 11:35:59 UTC Thu Mar 7 2013
CMD: ' action 1050 regexp " [0-9.]+ " "$_cli_result" result' 11:35:59 UTC Thu Mar 7 2013
CMD: ' action 1060 if $_regexp_result eq 1' 11:35:59 UTC Thu Mar 7 2013
CMD: ' action 1070  increment noCalls' 11:35:59 UTC Thu Mar 7 2013
CMD: ' action 1080 end' 11:35:59 UTC Thu Mar 7 2013
CMD: ' action 1090 puts "No of Calls: $noCalls"' 11:36:01 UTC Thu Mar 7 2013
CMD: 'exit' 11:36:02 UTC Thu Mar 7 2013
CMD: 'exit' 11:36:04 UTC Thu Mar 7 2013
*Mar  7 11:36:04.232: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (10.64.164.64)
CMD: 'event manager run showIP' 11:36:14 UTC Thu Mar 7 2013
CMD: 'show voip rtp connections | include x.x.x.x' 11:36:14 UTC Thu Mar 7 2013
CMD: 'enable' 11:36:14 UTC Thu Mar 7 2013
CMD: 'config t' 11:36:21 UTC Thu Mar 7 2013
CMD: 'exit' 11:36:24 UTC Thu Mar 7 2013
*Mar  7 11:36:24.008: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (10.64.164.64)
CMD: 'show voip rtp connections | include x.x.x.x' 11:36:28 UTC Thu Mar 7 2013
CMD: 'sh run' 11:37:03 UTC Thu Mar 7 2013
CMD: '             no event manager applet showIP' 11:37:10 UTC Thu Mar 7 2013
CMD: 'config t' 11:37:15 UTC Thu Mar 7 2013
CMD: 'no event manager applet showIP' 11:37:26 UTC Thu Mar 7 2013
CMD: 'exit' 11:37:28 UTC Thu Mar 7 2013
*Mar  7 11:37:28.638: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (10.64.164.64)
CMD: 'config t' 11:37:38 UTC Thu Mar 7 2013
CMD: 'event manager applet showIP' 11:37:46 UTC Thu Mar 7 2013
CMD: ' event none sync yes' 11:37:46 UTC Thu Mar 7 2013
CMD: ' action 1010 cli command "enable"' 11:37:46 UTC Thu Mar 7 2013
CMD: ' action 1020 cli command "show voip rtp connections | include x.x.x.x"' 11:37:46 UTC Thu Mar 7 2013
CMD: ' action 1040 set noCalls "0"' 11:37:46 UTC Thu Mar 7 2013
CMD: ' action 1050 regexp " [0-9.]+ " "$_cli_result" result' 11:37:46 UTC Thu Mar 7 2013
CMD: ' action 1060 if $_regexp_result eq 1' 11:37:46 UTC Thu Mar 7 2013
CMD: ' action 1070  increment noCalls' 11:37:46 UTC Thu Mar 7 2013
CMD: ' action 1080 end' 11:37:46 UTC Thu Mar 7 2013
CMD: ' action 1090 puts "No of Calls: $noCalls"' 11:37:47 UTC Thu Mar 7 2013
CMD: 'exit' 11:37:49 UTC Thu Mar 7 2013
CMD: 'exit' 11:37:50 UTC Thu Mar 7 2013
*Mar  7 11:37:50.828: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (10.64.164.64)
CMD: 'event manager run showIP' 11:37:59 UTC Thu Mar 7 2013
CMD: 'enable' 11:37:59 UTC Thu Mar 7 2013
CMD: 'show voip rtp connections | include x.x.x.x' 11:37:59 UTC Thu Mar 7 2013
CMD: 'sh run' 11:43:22 UTC Thu Mar 7 2013
CMD: 'ping 10.64.129.77' 11:43:37 UTC Thu Mar 7 2013
CMD: 'ping 10.64.129.77' 11:43:50 UTC Thu Mar 7 2013
--More--
CMD: 'ping 10.64.129.77' 11:44:04 UTC Thu Mar 7 2013
CMD: 'ping 10.64.129.77' 11:44:11 UTC Thu Mar 7 2013
CMD: 'sh run' 11:44:28 UTC Thu Mar 7 2013
CMD: 'sh ip int brief ' 11:45:31 UTC Thu Mar 7 2013
CMD: 'sh run' 11:46:37 UTC Thu Mar 7 2013
CMD: 'config t' 11:46:49 UTC Thu Mar 7 2013
CMD: 'no event manager applet showIP' 11:46:53 UTC Thu Mar 7 2013
CMD: 'event manager applet showIP' 11:47:00 UTC Thu Mar 7 2013
CMD: ' event none sync yes' 11:47:00 UTC Thu Mar 7 2013
CMD: ' action 1010 cli command "enable"' 11:47:01 UTC Thu Mar 7 2013
CMD: 'show ip int brief | include 10.64.129|192.168.20' 11:47:14 UTC Thu Mar 7 2013
CMD: ' action 1020 cli command "show ip int brief | include 10.64.129|192.168.20"' 11:47:21 UTC Thu Mar 7 2013
CMD: ' action 1040 set noCalls "0"' 11:47:28 UTC Thu Mar 7 2013
CMD: ' action 1050 regexp " [0-9.]+ " "$_cli_result" result' 11:47:28 UTC Thu Mar 7 2013
CMD: ' action 1060 if $_regexp_result eq 1' 11:47:28 UTC Thu Mar 7 2013
CMD: ' action 1070  increment noCalls' 11:47:28 UTC Thu Mar 7 2013
CMD: ' action 1080 end' 11:47:28 UTC Thu Mar 7 2013
CMD: ' action 1090 puts "No of Calls: $noCalls"' 11:47:29 UTC Thu Mar 7 2013
CMD: 'exit' 11:47:30 UTC Thu Mar 7 2013
CMD: 'exit' 11:47:32 UTC Thu Mar 7 2013
*Mar  7 11:47:32.784: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (10.64.164.64)
CMD: 'sh run' 11:47:36 UTC Thu Mar 7 2013
CMD: '    show ip int brief | include 10.64.129|192.168.20' 11:47:49 UTC Thu Mar 7 2013
CMD: '    show ip int brief ' 11:47:57 UTC Thu Mar 7 2013
CMD: '    show ip int brief ' 11:48:02 UTC Thu Mar 7 2013
CMD: '    show ip int brief | include 10.64.129|192.168.20' 11:48:45 UTC Thu Mar 7 2013
CMD: '    show ip int brief | include 10.64.129|192.168.20' 11:48:48 UTC Thu Mar 7 2013
CMD: 'sh run' 11:49:52 UTC Thu Mar 7 2013
CMD: '           no event manager applet showIP' 11:49:57 UTC Thu Mar 7 2013
CMD: 'config t' 11:50:00 UTC Thu Mar 7 2013
CMD: 'no event manager applet showIP' 11:50:02 UTC Thu Mar 7 2013
CMD: 'event manager applet showIP' 11:50:12 UTC Thu Mar 7 2013
CMD: ' event none sync yes' 11:50:12 UTC Thu Mar 7 2013
CMD: ' action 1010 cli command "enable"' 11:50:12 UTC Thu Mar 7 2013
CMD: ' action 1020 cli command "show ip int brief | include 10.64.129|192.168.20"' 11:50:12 UTC Thu Mar 7 2013
CMD: ' action 1040 set noCalls "0"' 11:50:12 UTC Thu Mar 7 2013
CMD: ' action 1050 regexp "\n" "$_cli_result" result' 11:50:12 UTC Thu Mar 7 2013
CMD: ' action 1060 if $_regexp_result eq 1' 11:50:12 UTC Thu Mar 7 2013
CMD: ' action 1070  increment noCalls' 11:50:13 UTC Thu Mar 7 2013
CMD: ' action 1080 end' 11:50:13 UTC Thu Mar 7 2013
CMD: ' action 1090 puts "No of Calls: $noCalls"' 11:50:13 UTC Thu Mar 7 2013
CMD: 'exit' 11:50:15 UTC Thu Mar 7 2013
CMD: 'exit' 11:50:16 UTC Thu Mar 7 2013
--More--                           *Mar  7 11:50:16.496: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (10.64.164.64)
CMD: 'event manager run showIP' 11:50:26 UTC Thu Mar 7 2013
CMD: 'enable' 11:50:26 UTC Thu Mar 7 2013
CMD: 'show ip int brief | include 10.64.129|192.168.20' 11:50:26 UTC Thu Mar 7 2013
CMD: 'config t' 11:52:28 UTC Thu Mar 7 2013
CMD: 'no event manager applet showIP' 11:52:38 UTC Thu Mar 7 2013
CMD: 'event manager applet showIP' 11:52:43 UTC Thu Mar 7 2013
CMD: ' event none sync yes' 11:52:43 UTC Thu Mar 7 2013
*Mar  7 11:52:47.548: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (10.64.164.64)
--More--
--More--
Buffered messages: (last 8192 bytes only)
1 11:46:27.716: %HA_EM-6-LOG: Capture_503: Number of 503_Error 15 min is:73
*Mar  1 11:46:27.716: %HA_EM-6-LOG: Capture_503: Number of 503_Error 1 hour is:1078
*Mar  1 11:46:28.506: EIGRP: Received HELLO on Gi0/0 - paklen 20 nbr 10.64.129.70
*Mar  1 11:46:28.506:   AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
*Mar  1 11:46:28.506:   {type = 1, length = 12}
*Mar  1 11:46:28.506:   {vector = {
*Mar  1 11:46:28.506:             {01000100 0000000F}
*Mar  1 11:46:28.506:   }
*Mar  1 11:46:28.506:   {type = 4, length = 8}
*Mar  1 11:46:28.506:             {0C020102}
*Mar  1 11:46:28.506: %HA_EM-6-LOG: Capture_503: 503_Error_has been_Encountered
*Mar  1 11:46:28.546: %SYS-5-CONFIG_I: Configured from console by  on vty1 (EEM:Capture_503)
*Mar  1 11:46:28.556: %HA_EM-6-LOG: Capture_503: Number of 503_Error 15 min is:74
*Mar  1 11:46:28.556: %HA_EM-6-LOG: Capture_503: Number of 503_Error 1 hour is:1079
*Mar  1 11:46:29.376: EIGRP: Received HELLO on Gi0/1 - paklen 20 nbr 10.64.129.74
*Mar  1 11:46:29.376:   AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
*Mar  1 11:46:29.376:   {type = 1, length = 12}
*Mar  1 11:46:29.376:   {vector = {
*Mar  1 11:46:29.376:             {01000100 0000000F}
*Mar  1 11:46:29.376:   }
*Mar  1 11:46:29.376:   {type = 4, length = 8}
*Mar  1 11:46:29.376:             {0C020102}
*Mar  1 11:46:29.378: %HA_EM-6-LOG: Capture_503: 503_Error_has been_Encountered
*Mar  1 11:46:29.418: %SYS-5-CONFIG_I: Configured from console by  on vty1 (EEM:Capture_503)
*Mar  1 11:46:29.428: %HA_EM-6-LOG: Capture_503: Number of 503_Error 15 min is:75
*Mar  1 11:46:29.428: %HA_EM-6-LOG: Capture_503: Number of 503_Error 1 hour is:1080
*Mar  1 12:18:34.708: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (x.x.x.x)
*Mar  1 14:34:48.169: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (10.64.164.242)
*Mar  4 18:22:15.106: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (x.x.x.x)
--More--
*Mar  4 18:22:42.204: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (x.x.x.x)
*Mar  4 18:23:07.590: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (x.x.x.x)
*Mar  4 18:24:51.560: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (x.x.x.x)
*Mar  4 18:25:18.876: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (x.x.x.x)
*Mar  4 18:26:20.064: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (x.x.x.x)
*Mar  4 18:26:59.920: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (x.x.x.x)
*Mar  4 18:28:02.696: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (x.x.x.x)
*Mar  7 11:00:37.892: %SYS-5-CONFIG_I: Configured from console by x.x.x.x on vty0 (10.64.164.64)
Queued messages:
*Mar  7 11:53:43.658: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar  7 11:53:44.050: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
11:53:44 UTC Thu Mar 7 2013: Unexpected exception to CPU: vector 4, PC = 0x3A8CA5
-Traceback= 3A8CA5 B7DBCB 2BF337F 2BF2F2B
CPU Register Context:
EAX = 0x00000000  ECX  = 0x00000000  EDX = 0x1F36E5C4  EBX  = 0x00000000
ESP = 0x1F794104  EBP  = 0x1F794104  ESI = 0x29C98534  EDI  = 0x29CA605C
EIP = 0x003A8CA5  PS   = 0x00000246  CS  = 0x00000008  SS   = 0x00000010
DS  = 0x00000010  ES   = 0x00000010  FS  = 0x00000010  GS   = 0x00000010
========= Start of Crashinfo Collection (11:53:44 UTC Thu Mar 7 2013) ==========
For image:
--More--
========= Malloc and Free Traces ===============================================
MallocFree Trace: ixmallocfree=0x2  ptr=0xBBA02D0
BBA02C0: 1E92AC70 60000464 2279CAE4  5D05D74 236209B4  18DFFE8 28BF8574  49C94B0
BBA02E0: 23531134  4A35B2D 28BF8574  4A35B2D 29FFE014  21DC5A8 1E934B34  222B5D2
BBA0300: 1E93520C 600002C4 1E902464  222B5D2 1E902374 50000060 1E902B3C 600000EC
BBA0320: 29FFE014 3000006E 29FFE014  21E5EEB 1E902374 40000354 1E902374  2226FAA
BBA0340: 28BF8574 30000012 28BF8574  49C94B0 23531134 3000001E 23531134  49C94B0
BBA0360: 28BF8574  4A35B2D 23531134  4A35B2D 29FFE014  21DC5A8 1E902374  222B5D2
BBA0380: 1E902A4C 60000164 29FFE014 3000006E 29FFE014  21E5EEB 1E902374 40000354
BBA03A0: 1E902374  2226FAA 23531134 3000001E 23531134  49C94B0 28BF8574 30000012
BBA03C0: 28BF8574  49C94B0 23531134  4A35B2D 28BF8574  4A35B2D 29FFE014  21DC5A8
BBA03E0: 1E902374  222B5D2 1E902A4C 60000164 29FFE014 3000006E 29FFE014  21E5EEB
BBA0400: 1E902374 40000354 1E902374  2226FAA 28BF8574 30000012 28BF8574  49C94B0
BBA0420: 23531134 3000001E 23531134  49C94B0 28BF8574  4A35B2D 23531134  4A35B2D
BBA0440: 29FFE014  21DC5A8 23531134 3000001E 23531134  2615417 23531134  2615295
BBA0460: 29FFE014 3000006E 29FFE014  21E5EEB 1E92A598 40000354 1E92A598  2226FAA
BBA0480: 23531134 3000001E 23531134  49C94B0 28BF8574 30000012 28BF8574  49C94B0
BBA04A0: 23531134  4A35B2D 28BF8574  4A35B2D 29FFE014  21DC5A8 1E92A598  222B5D2
ChunkMallocFree Trace: ixchunkmallocfree=0x3 ptr=0xC2F3564
C2F3540:  2C1C716  2C1AD33 2170F8B4  2C1C677  2C1AD33 236B7024   4DD1FF   4D2687
C2F3560: 21355134  1E878DD  1E87139 1FAD2538  2C1C716  2C21039 2170F8B4   4DD24F
C2F3580:   4CBD8E 21355D08   4DD29B   4C9DD1 21356450   4DD1AF   4D5EFC 21353E1C
C2F35A0:   4DD1AF   4D5EFC 21353DF8   4DD1AF   4D5EFC 21353DD4   4DD29B   4C9E22
C2F35C0: 21356450   4DD24F   4C9F3D 21355D08  2C1C716  2C1AD33 2170F8B4  2C1C677
C2F35E0:  2C1AD33 236B7024  2C1C677  2C1AB31 236B7024  2C1C716  2C21039 2170F8B4
C2F3600:   4DD24F   4CBD8E 21355D08   4DD29B   4C9DD1 21356450   4DD29B   4C9E22
C2F3620: 21356450   4DD24F   4C9F3D 21355D08  2C1C716  2C1AD33 2170F8B4  2C1C677
C2F3640:  2C1AD33 236B7024  2C1C677  2C1AB31 236B7024  2C1C716  2C21039 2170F8B4
C2F3660:   4DD24F   4CBD8E 21355D08   4DD29B   4C9DD1 21356450   4DD29B   4C9E22
C2F3680: 21356450   4DD24F   4C9F3D 21355D08  2C1C716  2C1AD33 2170F8B4  2C1C677
C2F36A0:  2C1AD33 236B7024  2C1C677  2C1AB31 236B7024  2C1C716  2C21039 2170F8B4
C2F36C0:   4DD24F   4CBD8E 21355D08   4DD29B   4C9DD1 21356450   4DD1AF   4D5E63
C2F36E0: 21353E1C   4DD1AF   4D5E63 21353DF8   4DD1AF   4D5E63 21353DD4   4DD29B
C2F3700:   4C9E22 21356450   4DD24F   4C9F3D 21355D08  2C1C716  2C1AD33 2170F8B4
--More--
C2F3720:  2C1C677  2C1AD33 236B7024  2C1C677  2C1AB31 236B7024  2C1C716  2C21039
C2F3740: 2170F8B4   4DD24F   4CBD8E 21355D08   4DD29B   4C9DD1 21356450   4DD29B
C2F3760:   4C9E22 21356450   4DD24F   4C9F3D 21355D08  2C1C716  2C1AD33 2170F8B4
C2F3780:  2C1C677  2C1AD33 236B7024  2C1C677  2C1AB31 236B7024  2C1C716  2C21039
C2F37A0: 2170F8B4   4DD24F   4CBD8E 21355D08   4DD29B   4C9DD1 21356450   4DD29B
C2F37C0:   4C9E22 21356450   4DD24F   4C9F3D 21355D08  2C1C716  2C1AD33 2170F8B4
C2F37E0:  2C1C677  2C1AD33 236B7024  2C1C677  2C1AB31 236B7024  2C1C716  2C21039
C2F3800: 2170F8B4   4DD24F   4CBD8E 21355D08   4DD29B   4C9DD1 21356450   4DD29B
C2F3820:   4C9E22 21356450   4DD29B   4C9E22 21356478   4DD24F   4C9F3D 21355D08
========= Stack Trace ==========================================================
========= Context ==============================================================
Signal = 23 Vector = 0x4 Uptime = 3w0d
========= Stack Dump ===========================================================
Stack Frame Pointer in Context is 0x1F794104, at process level
1F793D04: 1F793D48 96020000 AC020000 FFFFFFFF        0        0 16000000        0
1F793D24: 20000000        0 671D9C02 7A4C7D6C        0  A000000        0 24571723
1F793D44:        0        0  77B94A0 18642223 43000000 743D791F E01C9C02        0
1F793D64: 6C7D4C7A 1F793D6C        0 6C7D4C7A 8C3D791F B22BB002 5F642223 943D791F
1F793D84: 39727C02 231C8D64 E83D791F        0 E83D791F E83D791F B6858E01 A0047A1F
1F793DA4: CC047A1F 1F95866C  18E87A5        0        2        0 143E791F 143E791F
1F793DC4:        0 CC1B7E07 143E791F 143E791F 143E791F  B20D540 143E791F  1000000
1F793DE4:  18E87A5  83E791F A5878E01  B20D540        0 143E791F 143E791F  1000000
--More--
1F793E04:        0 8C40791F  1000000 8C40791F EF068E01  73F9AAC 9A020000  A2A4D61
1F793E24: 72202037 2031313A 35333A34 332E3635 383A2025 5359532D 332D4C4F 47474552
1F793E44: 5F464C55 5348494E 473A2053 79737465 6D207061 7573696E 6720746F 20656E73
1F793E64: 75726520 636F6E73 6F6C6520 64656275 6767696E 67206F75 74707574 2E0A0023
1F793E84: 243F791F D841C402 2244B508 1F793E98  2C4B03A F41A751F B03E791F E95BD005
1F793EA4: 1F751AF4 1F793EC4 F0A93D23 503F791F D841C402        0  100000C  2C4B03A
1F793EC4:        0 C8360000        0 C8360000        0 F43E791F 4FEB3F00 F43E791F
1F793EE4:     36C8 80060000 546BF906 214C9BB4 283F791F 3AA83A00 20000000        0
1F793F04: 383F791F 383F791F 9AA63A00        0        8        0        0 40DF3023
1F793F24: 16140000 2330DF40        0  4CF791F 26010000 1F79CF04 8CB4791F 543F791F
1F793F44: 80A7D105  CCF791F  4CF791F 643F791F 80A7D105 1F79CF04        0        8
1F793F64: 943F791F 4682C002 1F79CF04        8  2C15DB9 34382F0C 2330CB00 1F32425C
1F793F84:   661E0D 34382F0C 1F79B48C 1F79B48C 1040791F 4A80C002 9E381000        6
1F793FA4: D83F791F   661E0D  1000000  6000000 DC987720  73F9A00   9A3F07 3C977720
1F793FC4:   CB3023  73F9A14 2330DF40 924EC102 8CB4791F 74A8CA0B 1F79CF04 20779838
1F793FE4: 3C977720  1000000 1F79B48C      12C 1F32425C  1000000        6      1F4
1F794004: 1F79B48C 143E9F1F   661E0D 2040791F DB6EC002 2840791F 6029BF02 4040791F
1F794024: D228BF02 1F79B48C   661E0D 5040791F  A1BC102  77DC38C        0 143E9F1F
1F794044: 1F32CE34 34CE321F        0 6840791F 9840791F 9840791F 5ED26500        0
1F794064: 8040791F D820C102        0 143E9F1F        2  1000000 A41B7E07 6CDC361F
1F794084:        0        0 9C40791F 15168E01 CC40791F C2018E01 CC40791F 8C048E01
1F7940A4: E1877F01 A41B7E07 6CDC361F        0 D440791F        0       F0 D440791F
1F7940C4:        1  C916BA4 E440791F E440791F 39727C02 1F36E5C4 F040791F        0
1F7940E4: F840791F 348C3A00 1F36E5C0 3485C929 5C60CA29 A58C3A00 4B071000  4000000
1F794104: 1441791F CBDBB700 29CA5F5C F8060000 5C41791F 7F33BF02        0 29C98534
1F794124: 29CA605C        1  B20D7C8 29C98534 29CA605C   A3C78B EF4321CD F8060000
1F794144: 23604400   446023 29C98534 23604400 29CA605C 29C98534 9441791F 2B2FBF02
1F794164: 6828BA0B        0 6C7D2428 1F7941C4  BBA2868 6828BA0B 23604400   446023
1F794184:   1061F1 23604400   1061F1 1F794168 CC41791F F1611000 FFFFFFFF        0
1F7941A4:        0 6C7D23C3 1F7941A4 1F7941C4  BBA1B4C  BBA1680  BB98A0C  BBA00FC
1F7941C4:        0 6C7D23C3        0 2EE5C102        0 FD0110DF AB1234CD    60000
1F7941E4:        6  5EAAE48  2C1EAC3 1F7944E0 1F7912DC 8000016A        1        0
1F794204:  100000C 1F74E528 1F7912F8 C8FE721F        0        0        0        0
1F794224:        0        0        0        0        0        0   1060F6        0
1F794244:    10000        1        0        0        0        0        0        6
1F794264:        0        0        0      D44       F0     3FE4        0        0
1F794284:        0        6        0        0 6C7D23C3        0        0        0
1F7942A4: 6C7D23C4        0 6C7D23C4    5A608      142    2E6BD 221ED87C    3C306
1F7942C4:    1E18F  5D21718        5     145A        0        0        0        B
1F7942E4:        0     2EE0     2EE0 1F32CD18        0        0        0        0
1F794304:        0 20779838        0 1F79420C  BCAA874        0        0  71CB8B8
1F794324:        0        0        0        0     420E        0        0        0
1F794344: 1F794318        0        0        0        0     4294        0 1F79420C
--More--
1F794364:        0        0 1F794318 1F79420C        0        0        0    142D2
1F794384:        0        0        0 1F794318 1F79420C        0        0        0
1F7943A4:    242D2        0        0        0        0        0        0 1F794510
1F7943C4:        0        0        0        0        0        0        0        0
1F7943E4:        0 1F7945A4 1F7943D4 1F794518        0  C2F34C0        0        0
1F794404:        0        0        0  FFFFFFF  FFFFFFF        0        0        0
1F794424:        0        0        0        0        0        0        0        0
1F794444:        0        0 1F7946D4        0        0 FFFFEC0A        0        0
1F794464:        0 1F79464C        0        0     1038 1F35C2EC 1F35C2EC 1F751C4C
1F794484: 1F794520 1F794478  77DC6A4       A5    D0000        1        0  65CF46C
1F7944A4:  2C153DA  2C153E4  77DC68C        0 1F74E528        0  100000C        0
1F7944C4:        0        0        0        0        0 BEEFCAFE FD0110DF AB1234CD
1F7944E4:    60000        6  65CF024  2C1A396 1F7945D0 1F7941F0 80000060        1
========= Process Level Info ===================================================
---- Current Process Stack (0x880 bytes used, out of 0x2EE0 available) ----
Current SP = 0x1F794104, saved SP = 0x1F72FEC8
1F793DD8:  B20D540 143E791F  1000000  18E87A5  83E791F A5878E01  B20D540        0
1F793DF8: 143E791F 143E791F  1000000        0 8C40791F  1000000 8C40791F EF068E01
1F793E18:  73F9AAC 9A020000  A2A4D61 72202037 2031313A 35333A34 332E3635 383A2025
1F793E38: 5359532D 332D4C4F 47474552 5F464C55 5348494E 473A2053 79737465 6D207061
1F793E58: 7573696E 6720746F 20656E73 75726520 636F6E73 6F6C6520 64656275 6767696E
1F793E78: 67206F75 74707574 2E0A0023 243F791F D841C402 2244B508 1F793E98  2C4B03A
1F793E98: F41A751F B03E791F E95BD005 1F751AF4 1F793EC4 F0A93D23 503F791F D841C402
1F793EB8:        0  100000C  2C4B03A        0 C8360000        0 C8360000        0
1F793ED8: F43E791F 4FEB3F00 F43E791F     36C8 80060000 546BF906 214C9BB4 283F791F
1F793EF8: 3AA83A00 20000000        0 383F791F 383F791F 9AA63A00        0        8
1F793F18:        0        0 40DF3023 16140000 2330DF40        0  4CF791F 26010000
1F793F38: 1F79CF04 8CB4791F 543F791F 80A7D105  CCF791F  4CF791F 643F791F 80A7D105
1F793F58: 1F79CF04        0        8 943F791F 4682C002 1F79CF04        8  2C15DB9
1F793F78: 34382F0C 2330CB00 1F32425C   661E0D 34382F0C 1F79B48C 1F79B48C 1040791F
1F793F98: 4A80C002 9E381000        6 D83F791F   661E0D  1000000  6000000 DC987720
1F793FB8:  73F9A00   9A3F07 3C977720   CB3023  73F9A14 2330DF40 924EC102 8CB4791F
1F793FD8: 74A8CA0B 1F79CF04 20779838 3C977720  1000000 1F79B48C      12C 1F32425C
1F793FF8:  1000000        6      1F4 1F79B48C 143E9F1F   661E0D 2040791F DB6EC002
1F794018: 2840791F 6029BF02 4040791F D228BF02 1F79B48C   661E0D 5040791F  A1BC102
1F794038:  77DC38C        0 143E9F1F 1F32CE34 34CE321F        0 6840791F 9840791F
1F794058: 9840791F 5ED26500        0 8040791F D820C102        0 143E9F1F        2
1F794078:  1000000 A41B7E07 6CDC361F        0        0 9C40791F 15168E01 CC40791F
--More--
1F794098: C2018E01 CC40791F 8C048E01 E1877F01 A41B7E07 6CDC361F        0 D440791F
1F7940B8:        0       F0 D440791F        1  C916BA4 E440791F E440791F 39727C02
1F7940D8: 1F36E5C4 F040791F        0 F840791F 348C3A00 1F36E5C0 3485C929 5C60CA29
1F7940F8: A58C3A00 4B071000  4000000 1441791F CBDBB700 29CA5F5C F8060000 5C41791F
1F794118: 7F33BF02        0 29C98534 29CA605C        1  B20D7C8 29C98534 29CA605C
1F794138:   A3C78B EF4321CD F8060000 23604400   446023 29C98534 23604400 29CA605C
1F794158: 29C98534 9441791F 2B2FBF02 6828BA0B        0 6C7D2428 1F7941C4  BBA2868
1F794178: 6828BA0B 23604400   446023   1061F1 23604400   1061F1 1F794168 CC41791F
1F794198: F1611000 FFFFFFFF        0        0 6C7D23C3 1F7941A4 1F7941C4  BBA1B4C
1F7941B8:  BBA1680  BB98A0C  BBA00FC        0 6C7D23C3        0 2EE5C102        0
========= Interrupt Level Stack Dump ===========================================
========= Interrupt Stack ======================================================
---- Level 1 Interrupt stack (0x4A8 bytes used, out of 0x4650 available) ----
intstacks[1]: base 0x21242D70 stack 0x212473BC routine 0x39C772
              size 0x4650     low   0x4650     desc    Network devices
21246F18: 3C6F2421 3C6F2421 1BA93A00  7000000 1C07060F 3C826A21  E000000 C0000000
21246F38:  1000000 AC722421 B6A43A00    E0000        1        0 7EF06200  8000000
21246F58: 46020000 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
21246F78: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
21246F98: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF D86F2421
21246FB8: D86F2421 1BA93A00 E46F2421 E46F2421 EC6F2421 EC6F2421 1BA93A00  7000000
21246FD8: 1F74E848  8B54422        0 C0000000  1000000 18702421 B6A43A00 2244B508
21246FF8:        0 1F74E848 7428751F        0 1F74E848 7428751F 24702421 E95BD005
21247018: 1F752874 21247038 A000831F C4702421 D841C402 2244B508 21247038  2C4B03A
21247038: 3AB0C402 21D30E14 4CB0C402  8000000 98702421        0  1000004 7428751F
21247058:        0  1000004 1F752874 21247080  CEE8D1F  C712421 D841C402 2244B508
21247078: 21247080  2C4B03A  1000000  6000000 C4702421 9E381000        6 D0702421
21247098: C0702421        0        0  1000004 21C935D0 46020000 924EC102      202
212470B8: CC702421 A041C402 21C93560 D8702421 A041C402 E8702421        0  1000004
212470D8: F4702421 2694C402  77E5A3C        0        0 1042781F 1F74E848 24712421
212470F8: EE5E6800 1F74E848 46020000 96ADB600      206        0 18712421 30ADB600
21247118: 48712421 F38AC102        1 40712421 40712421 AD1FC102  1000000 1F332658
21247138: 5826331F 4781400A 1F8300A0 6434C921 5C712421 A5B9C102        0 1F8300A0
21247158: 4781400A 70712421        0 1F74E974 842D751F 80712421 E95BD005 1F752D84
21247178: 21247194 B0838020 20722421 D841C402 2244B508 21247194  2C4B03A 34722421
21247198: D841C402 2244B508 212471A8  2C4B03A        1  10470A0  A408147        0
--More--
212471B8:  1000001 2018C102  77DC38C DD56BD0B        0  1000004 1F8300A0 E8712421
212471D8: BE8AC202 1F8300A0        7 1F8300A0 18722421 71521100        7 1F8300A0
212471F8: 214C9BB4        0 10722421 214CA84C        1 1F8300A0    10000 214C9BB4
21247218: 3C722421 29B51100 34722421 A041C402        0        0  1000001 50722421
21247238: 2694C402  77E5A3C        0        0 8443781F 1F74E974 80722421 EE5E6800
21247258: 1F74E974 1042781F 1F74E848 84722421 ABBE3A00 208083B0 74E9741F 208083B0
21247278: B0838020        1 20806F14 C8722421 C8722421 5ED26500        1 B0722421
21247298:   49A34C AD1FC102  1000000 20806F14 146F8020 20806F14 B436B321 1499C621
212472B8: CC722421 B836B321 B436B321 208083B0 E4722421 4CA34900 208083B0 1F3326D0
212472D8: 21C632B4   A34900  1000000 54732421  2000000 B836B321 54732421 5A968300
212472F8:  F29FFC0 21247338 74732421 F0121200 208070A0 5ED26500 1C732421 C00DC721
21247318:        0 80D1C621 21B338A4     FEF0 A8896A21 40732421 21B336B8 208083B0
21247338:       60  F2BF500     FEF0 FF000000       FF A438B321 21247338 84732421
21247358: 1D274800 21B338A4 38BF4E21 21510FC0        0 10954C21 50264800 216A8998
21247378: 80732421 B4A82404 94732421 3DCC2404 9C732421        0 546BF906        0
21247398: D0270000        0 B0732421 D9314000        0 D0270000 FC3D791F 82A73A00
212473B8:        0 FFFFFFFF
---- Level 2 Interrupt stack (0x0 bytes used, out of 0x4650 available) ----
intstacks[2]: base 0x2123E720 stack 0x21242D6C routine 0x3FEDB0
              size 0x4650     low   0x4650     desc    One Shot Timer
---- Level 5 Interrupt stack (0xC4 bytes used, out of 0x4650 available) ----
intstacks[5]: base 0x2123A0D0 stack 0x2123E71C routine 0x3B4B1A
              size 0x4650     low   0x4650     desc    Console Uart
2123E65C: 80E62321 80E62321 1BA93A00  7000000 1F32CD18 18CD321F      3F8 9CE62321
2123E67C: 9CE62321 1BA93A00  7000000 FFFFFFFF 18CD321F 1F32F2E2 E0000000  5000000
2123E69C: BCE62321 B0E62321 3B453B00  3F90000  D000000 C8E62321  5413B00  1000000
2123E6BC: CCE62321 3B453B00 1F32F679 F4E62321 484A3B00 1F32CD18        1 C1000000
2123E6DC:  5453B00 1F32CD18        0 F4E62321 F0443B00  2FA0000 14E72321 904B3B00
2123E6FC: B6A43A00 8000E0FE 1A4B3B00 1CE72321 1A4B3B00 446BF906 54FF721F 2AA93A00
2123E71C: FFFFFFFF
---- Level 7 Interrupt stack (0x54 bytes used, out of 0x4650 available) ----
intstacks[7]: base 0x21235A80 stack 0x2123A0CC routine 0xB7F20C
              size 0x4650     low   0x4650     desc    Clocktick Interrupt
2123A07C:        0 6C7D23C4        0 6C7D4C7A 1F79420C 46020000 EA1B1000      206
2123A09C: 2123A0A8 FFFFFFFF B4A02321        0 BCA02321 8B15BF02   83126E  CF2B700
--More--
2123A0BC: C4A02321 BFF2B700 C83D791F 2AA93A00 FFFFFFFF
========= Register Memory Dump =================================================
Reg00(EAX):        0
Reg01(EBX):        0
Reg02(ECX):        0
Reg03(EDX): 1F36E5C4
Reg04(ESP): 1F794104
Reg05(EBP): 1F794104
Reg06(ESI): 29C98534
Reg07(EDI): 29CA605C
Reg08(EIP):   3A8CA5
Reg09(PS ):      246
Reg10(CS ):        8
Reg11(SS ):       10
Reg12(DS ):       10
Reg13(ES ):       10
Reg14(FS ):       10
Reg15(GS ):       10
buffer check=0 sched_hc=0x0
---- block0  ptr=1F7940A4  is_malloc=0  length=0x260 ----
--More--
---- block1  ptr=29C98504  is_malloc=1  length=0x100 ----
29C984C4:        0   978B82        0        0        0        0        0        0
29C984E4:        0        0        0        0        0        0        0 FD0110DF
29C98504: AB1234CD FFFC0000        0 23604450  2C4A6BF 29CA8538 29C884E4 80008002
29C98524:        2        0  1000005 1F74E7E4        0        0 23604400        0
29C98544: 23604400      800      7FC        C       1C      73D        0        0
29C98564:        0        C     1423  BBEE2E0        0        0        0        0
29C98584: 4D616C6C 6F634C69 74650000        0 29C9A598 29CA8528        0        0
29C985A4:        0 29C9A5A8 29C9A5C4 29C9A5E0 29C9A5FC 29C9A618 29C9A634 29C9A650
29C985C4: 29C9A66C 29C9A688 29C9A6A4 29C9A6C0 29C9A6DC 29C9A6F8 29C9A714 29C9A730
29C985E4: 29C9A74C 29C9A768 29C9A784 29C9A7A0 29C9A7BC 29C9A7D8 29C9A7F4 29C9A810
---- block2  ptr=29CA5F5C  is_malloc=0  length=0x1F0 ----
29CA5F1C:        0  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B        0
29CA5F3C:  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B        0  2C4A6BF
---- block3  ptr=29CA6068  is_malloc=0  length=0x100 ----
--More--
---- block4  ptr=29CA6030  is_malloc=0  length=0x100 ----
---- block5  ptr=C916B70  is_malloc=1  length=0x340 ----
C916B30:        0        0        0        0        0        0        0        0
C916B50:        0        0        0        0        0        0        0 FD0110DF
C916B70: AB1234CD FFFE0000        0  5E20684   658B96  C916EB0  C916844 80000188
C916B90:        1        0  1000001 1F74E974 AFACEFAD  A2A4D61 72202037 2031313A
C916BB0: 35333A33 332E3633 303A2025 5359532D 322D4348 554E4B42 41444D41 4749433A
C916BD0: 20426164 206D6167 6963206E 756D6265 7220696E 20636875 6E6B2068 65616465
C916BF0: 722C2063 68756E6B 20323943 39383533 34202064 61746120 32394341 36303543
C916C10: 20206368 756E6B6D 61676963 20413343 37384220 20636875 6E6B5F66 7265656D
C916C30: 61676963 20454634 33323143 44202D50 726F6365 73733D20 22436865 636B2068
C916C50: 65617073 222C2069 706C3D20 302C2070 69643D20 360A2D54 72616365 6261636B
C916C70: 3D203138 45383741 357A2032 42463333 35447A20 32424632 4632427A 20313036
C916C90: 3146317A        0        0        0        0        0 20687474 703A2F2F
C916CB0: 7777772E 63697363 6F2E636F 6D2F7465 63687375 70706F72 740A436F 70797269
C916CD0: 67687420 28632920 31393836 2D323030 39206279 20436973 636F2053 79737465
C916CF0: 6D732C20 496E632E  A436F6D 70696C65 64205468 75203136 2D417072 2D303920
C916D10: 31383A33 38206279 2070726F 645F7265 6C5F7465 616D0006   146369 73636F20
C916D30: 57532D43 36353036 2D450002   110000    10101 CC00040A 40814A00  3001647
C916D50: 69676162 69744574 6865726E 6574332F 33000400  8000000 29000900  74C4956
C916D70:    B0005  1001600 11000000  10101CC    40A40 814A001A   100000    10000
C916D90:     FFFF FFFF0401  9090D01  2010506  5000B57 8691793C FFACA73D DC78647C
C916DB0: E2EEA73C 7F16DEF4 C9B907AD 64EBA867 3DBF9C5B 6867F471 A7CF783A 9F1DF970
C916DD0: E1FB3F1D FD5C300B F70E8913 3CF2F1DC 7D43A31F 8D8B333D 30B4E9D3 73CE098A
C916DF0: A33E9EFB E9D0E476 3E14C98F 6FFC00C1 B32F8E3E EE17CC0F 871CE98E BF1B7DB8
C916E10:  74170DF D003BF2E 260B50D2  EE4B648 4BD4D36A 5AD207F8 F5DED381 F4B08E7E
--More--
C916E30: 999E6569  90660A9        0        0        0        0        0        0
C916E50:        0        0        0        0        0        0        0        0
C916E70:        0        0        0        0        0        0        0        0
C916E90:        0        0        0        0        0        0        0 FD0110DF
---- block6  ptr=39727C00  is_malloc=0  length=0x100 ----
39727BC0: 9AAE506E 1F9A8DDA AF61FA7E DDF5BFA7 5F43F5FD FAF8D6FF 3FFD5ACD FAB5DA25
39727BE0: 6C53FA95 AAEFD735 11FD5AAA EB9780DF 8AF575E0 212CEF0C 24A95F76 4A2AFD82
39727C00: 24F5CB4A 493BEF22 2463A44D 3B644AC5 FA0E9AFD C50EBD71 230ACD45 E9EB107D
39727C20: 5FC505FF ABFB4ACA 402CEFEB 17F3F57D BD56ED6B 92EF00EF 2ECCF334 EA2EFFAE
39727C40: 85BE6B3D CB77A542 175A062D A8B5FB3A 46053BA0 B1696807  A420EE4 E65B7D07
39727C60: CCD6B684 20B49400 32AB1B39 A3D62FE2 B289B7AA 5269FF94 3B4E3F92 41F32358
39727C80: 989F3B38 E9A97724  E8051EF  84A12E6 2FF07508 9C7A0770 D27551A9 9DCFCB34
39727CA0: 7F468C3A 2F19B1EA BC6438D4 79C98853 F093118F F8294840 2257F153 D22F7E82
39727CC0: 1DA30019 C1032319 72283D82 D2802421 78E0024A DB820706 50C24E00 2E4AC710
39727CE0: 56ED948E A57C1BA5 1D94B652 3A8ED216 4AC703E6 13A2627E 9C1EF34F CEEF8BF9
---- block7  ptr=1F36E06C  is_malloc=1  length=0x804 ----
1F36E02C:        0        0  2622024        0        0  262229A        0        0
1F36E04C:  2622030        0        0  2622292        0        0        0 FD0110DF
1F36E06C: AB1234CD FFFE0000        0 1F339590  27C79F0 1F36E870 1F36D87C 800003EA
1F36E08C:        1        0  1000001 1F74E974        0        0 1FC5B530        0
1F36E0AC: 1F339540       64       75        C        C        0        0        0
1F36E0CC:        0        C        3  BBEE2E0        0        0        0        0
1F36E0EC: 52656720 46756E63 74696F6E 204C6900 1F36E2E4 1F36E860        0        0
1F36E10C:        0 1F36E2E4 1F36E2F0 1F36E2FC 1F36E308 1F36E314 1F36E320 1F36E32C
1F36E12C: 1F36E338 1F36E344 1F36E350 1F36E35C 1F36E368 1F36E374 1F36E380 1F36E38C
1F36E14C: 1F36E398 1F36E3A4 1F36E3B0 1F36E3BC 1F36E3C8 1F36E3D4 1F36E3E0 1F36E3EC
1F36E16C: 1F36E3F8 1F36E404 1F36E410 1F36E41C 1F36E428 1F36E434 1F36E440 1F36E44C
1F36E18C: 1F36E458 1F36E464 1F36E470 1F36E47C 1F36E488 1F36E494 1F36E4A0 1F36E4AC
1F36E1AC: 1F36E4B8 1F36E4C4 1F36E4D0 1F36E4DC 1F36E4E8 1F36E4F4 1F36E500 1F36E50C
1F36E1CC: 1F36E518 1F36E524 1F36E530 1F36E53C 1F36E548 1F36E554 1F36E560 1F36E56C
1F36E1EC: 1F36E578 1F36E584 1F36E590 1F36E59C 1F36E5A8 1F36E5B4 1F36E5C0 1F36E5CC
1F36E20C: 1F36E5D8 1F36E5E4 1F36E5F0 1F36E5FC 1F36E608 1F36E614 1F36E620 1F36E62C
1F36E22C: 1F36E638 1F36E644 1F36E650 1F36E65C 1F36E668 1F36E674 1F36E680 1F36E68C
1F36E24C: 1F36E698 1F36E6A4 1F36E6B0 1F36E6BC 1F36E6C8 1F36E6D4 1F36E6E0 1F36E6EC
1F36E26C: 1F36E6F8 1F36E704 1F36E710 1F36E71C 1F36E728 1F36E734 1F36E740 1F36E74C
1F36E28C: 1F36E758 1F36E764 1F36E770 1F36E77C 1F36E788 1F36E794 1F36E7A0 1F36E7AC
1F36E2AC: 1F36E7B8 1F36E7C4 1F36E7D0 1F36E7DC 1F36E7E8 1F36E7F4 1F36E800 1F36E80C
1F36E2CC: 1F36E818 1F36E824 1F36E830 1F36E83C 1F36E848 1F36E854 1FAAF8C8        0
1F36E2EC:        0 1FAAF8D4        0        0 1FAAF8E0        0        0 1FAAF8EC
1F36E30C:        0        0 1FAAF8F8        0        0 1FAAF904        0        0
1F36E32C: 1FAAF910        0        0 1FAAF91C        0        0 1FAAF928        0
--More--
1F36E34C:        0 1FAAF934        0        0 1FAAF940        0        0 1FAAF94C
1F36E36C:        0        0 1FAAF958        0        0 1FAAF964        0        0
1F36E38C: 1FAAF970        0        0 1FAAF97C        0        0 1FAAF988        0
1F36E3AC:        0 1FAAF994        0        0 1FAAF9A0        0        0 1FAAF9AC
1F36E3CC:        0        0 1FAAF9B8        0        0 1FAAF9C4        0        0
1F36E3EC: 1FAAF9D0        0        0 1FAAFA00        0        0 1FAAFA0C        0
1F36E40C:        0 1FAAFA18        0        0 1FAAFA24        0        0 1FAAFA48
1F36E42C:        0        0 1FAAFA54        0        0 1FAAFA6C        0        0
1F36E44C: 1FAAFA78        0        0 1FAAFA84        0        0 1FAAFA90        0
1F36E46C:        0 1FAAFAB4        0        0 1FAAFAC0        0        0 1FAAFBB0
1F36E48C:        0        0 1FAAFBBC        0        0 1FAAFBEC        0        0
1F36E4AC: 1FAAFC10        0        0 1FAAFC28        0        0 1FAAFC34        0
1F36E4CC:        0 1FAAFC40        0        0 1FAAFC58        0        0 1FAAFC64
1F36E4EC:        0        0 1FAAFC7C        0        0 1FAAFC94        0        0
1F36E50C: 1FAAFCA0        0        0 1FAAFCAC        0        0 1FAAFCC4        0
1F36E52C:        0 1FAAFCD0        0        0 1FAAFCDC        0        0 1FAAFCE8
1F36E54C:        0        0 1FAAFD00        0        0 1FAAFD30        0        0
1F36E56C: 1F36DB28        0        0 1F36DBA0        0        0 1F36DBF4        0
1F36E58C:        0 1F36DC00        0        0 1F36DC24        0        0 1F36DC54
1F36E5AC:        0        0 1F36DC60        0        0 1F36DC6C        0        0
1F36E5CC: 1F36DCE4        0        0 1F36DCF0        0        0 1F36DCFC        0
1F36E5EC:        0 1F36DD08        0        0 1F36DD14        0        0 1F36DD20
1F36E60C:        0        0 1F36DD2C        0        0 1F36DD50        0        0
1F36E62C: 1F36DD5C        0        0 1F36DD68        0        0 1F36DD74        0
1F36E64C:        0 1F36DD80        0        0 1F36DDA4        0        0 1F36DDB0
1F36E66C:        0        0 1F36DDE0        0        0 1F36DDEC        0        0
1F36E68C: 1F36DDF8        0        0 1F36DE04        0        0 1F36DE10        0
1F36E6AC:        0 1F36DE1C        0        0 1F36DE28        0        0 1F36DE34
1F36E6CC:        0        0 1F36DE4C        0        0 1F36DE58        0        0
1F36E6EC: 1F36DE64        0        0 1F36DE7C        0        0 1F36DE88        0
1F36E70C:        0 1F36DE94        0        0 1F36DED0        0        0 1F36DEF4
1F36E72C:        0        0 1F36DF00        0        0 1F36DF0C        0        0
1F36E74C: 1F36DF18        0        0 1F36DF24        0        0 1F36DF30        0
1F36E76C:        0 1F36DF3C        0        0 1F36DF48        0        0 1F36DF54
1F36E78C:        0        0 1F36DF60        0        0 1F36DF6C        0        0
1F36E7AC: 1F36DF78        0        0 1F36DF84        0        0 1F36DF90        0
1F36E7CC:        0 1F36DF9C        0        0 1F36DFA8        0        0 1F36DFB4
1F36E7EC:        0        0 1F36DFC0        0        0 1F36DFCC        0        0
1F36E80C: 1F36DFD8        0        0 1F36DFE4        0        0 1F36DFF0        0
1F36E82C:        0 1F36DFFC        0        0 1F36E008        0        0 1F36E02C
1F36E84C:        0        0 1F36E044        0        0        0        0        0
1F36E86C: FD0110DF
---- block8  ptr=348C3A00  is_malloc=0  length=0x100 ----
--More--
348C39C0:        0        0        0        0        0        0        0        0
348C39E0:        0        0        0        0        0        0        0        0
348C3A00:        0        0        0        0        0        0        0        0
348C3A20:        0        0        0        0        0        0        0        0
348C3A40:        0        0        0        0        0        0        0        0
348C3A60:        0        0        0        0        0        0        0        0
348C3A80:        0        0        0        0        0        0        0        0
348C3AA0:        0        0        0        0        0        0        0        0
348C3AC0:        0        0        0        0        0        0        0        0
348C3AE0:        0        0        0        0        0        0        0        0
---- block9  ptr=3485C928  is_malloc=0  length=0x100 ----
3485C8E8:        0        0        0        0        0        0        0        0
3485C908:        0        0        0        0        0        0        0        0
3485C928:        0        0        0        0        0        0        0        0
3485C948:        0        0        0        0        0        0        0        0
3485C968:        0        0        0        0        0        0        0        0
3485C988:        0        0        0        0        0        0        0        0
3485C9A8:        0        0        0        0        0        0        0        0
3485C9C8:        0        0        0        0        0        0        0        0
3485C9E8:        0        0        0        0        0        0        0        0
3485CA08:        0        0        0        0        0        0        0        0
---- block10  ptr=1441791C  is_malloc=0  length=0x100 ----
144178DC:        0        0        0        0        0        0        0        0
144178FC:        0        0        0        0        0        0        0        0
1441791C:        0        0        0        0        0        0        0        0
1441793C:        0        0        0        0        0        0        0        0
1441795C:        0        0        0        0        0        0        0        0
1441797C:        0        0        0        0        0        0        0        0
1441799C:        0        0        0        0        0        0        0        0
144179BC:        0        0        0        0        0        0        0        0
144179DC:        0        0        0        0        0        0        0        0
144179FC:        0        0        0        0        0        0        0        0
---- block11  ptr=B20D7C8  is_malloc=0  length=0x100 ----
B20D788:  65D5E60  77E036C    30200  77E0378  B20CF54  65CE4AC  65D78A0        0
B20D7A8:      600  77E037C  B20CF54  65CE4A4  65D78D4        0      600  77E0380
B20D7C8:  B20CF54  65CE4B8  65D5EC0  77E0384    30200  77E0390  B20CF54  65CE4C8
B20D7E8:  65D78FC  77E0394    30200  77E03A0  B20CF54  65CE4D8  65D7934  77E03A4
B20D808:    30200  77E03B0  B20CF54  65CE4E8  65D7968  77E03B4    30200  77E03C0
B20D828:  B20CF54  65CE4FC  65D5F20  77E03C4    30200  77E03D0  B20CF54  65CE514
--More--
B20D848:  65D7998  77E03D4    30200  77E03E0  B20CF54  65CE520  65D5F80  77E03E4
B20D868:    30200  77E03F0  B20CF54  65CE530  65D6000  77E03F4    30200  77E0400
B20D888:  B20CF54  65CE540  65D6060  77E0404    30200  77E0410  B20CF54  6362B34
B20D8A8:  65D79D0        0      400  77E0414  B20CF54  65CE54C  65D79F4        0
---- block12  ptr=236043D0  is_malloc=1  length=0x100 ----
23604390:     1421  BBEE2E0        0        0        0        0 4D616C6C 6F634C69
236043B0: 74650000        0 236043CC 236043CC        0        0        1 FD0110DF
236043D0: AB1234CD FFFC0000        0  5D21564  2BFF689 23604478 2360433C 8000003C
236043F0:        2        0  1000005 1F74E7E4 236044A8 29C98534        0        0
23604410: 29C98534      800        0        C       1C        0       BF      154
23604430:      73D        0     1421  BBEE2E0        0        0        0        0
23604450: 4D616C6C 6F634C69 74650000        0 23604474 23604474        0        0
23604470:        1 FD0110DF AB1234CD FFFC0000        0  5D21564  2BFF689 23604520
23604490: 236043E4 8000003C        1        0  1000005 1F74E7E4 23604A9C 29CA8568
236044B0:        0        0 29CA8568      400        0       64       74        0
---- block13  ptr=2B2FBF00  is_malloc=0  length=0x100 ----
2B2FBEC0:        0        0        0        0        0        0        0        0
2B2FBEE0:        0        0        0        0        0        0        0        0
2B2FBF00:        0        0        0        0        0        0        0        0
2B2FBF20:        0        0        0        0        0        0        0        0
2B2FBF40:        0        0        0        0        0        0        0        0
2B2FBF60:        0        0        0        0        0        0        0        0
2B2FBF80:        0        0        0        0        0        0        0        0
2B2FBFA0:        0        0        0        0        0        0        0        0
2B2FBFC0:        0        0        0        0        0        0        0        0
2B2FBFE0:        0        0        0        0        0        0        0        0
---- block14  ptr=BBA2868  is_malloc=0  length=0x100 ----
BBA2828:        0        0        0        0        0        0        0        0
BBA2848:        0        0        0        0        0        0        0        0
BBA2868:        0        0        0  BBA00FC        0        0 6C7D23C3     4202
BBA2888:        0        0        0 2123E720        0        0        0        0
BBA28A8:        0        0        0        0        0        0        0        0
BBA28C8:        0        0        0        0        0        0        0        0
BBA28E8:        0        0        0        0 229BD6C8 29C92AA0       1D        0
BBA2908: 21235A80        0  71D82A0        0        0        0        0        0
BBA2928:        0        0        0 1F790F78        0        0        0        0
BBA2948:        0 2123A0D0        0 21242D70        0        0        0        0
---- block15  ptr=29CA8528  is_malloc=1  length=0x110 ----
29CA84E8:        0        0 15A3C78B        1  2C4A6BF 29C98534        0        0
--More--
29CA8508:        0 15A3C78B        1  2C4A6BF 29C98534        0        0        0
29CA8528:        0        0        0 FD0110DF AB1234CD FFFC0000        0 236044F8
29CA8548:   B6F2DB 29CB856C 29C98518 80008002        1        0  1000005 1F74E7E4
29CA8568:        0        0 236044A8        0 236044A8      400      221       64
29CA8588:       74      1D1        0        0        0       14     1423  BBEE2E0
29CA85A8:        0        0        0        0 4D616C6C 6F634C69 74650000        0
29CA85C8: 29CA8E60 29CB8554        0        0        0 29CA8E70 29CA8EE4 29CA8F58
29CA85E8: 29CA8FCC 29CA9040 29CA90B4 29CA9128 29CA919C 29CA9210 29CA9284 29CA92F8
29CA8608: 29CA936C 29CA93E0 29CA9454 29CA94C8 29CA953C 29CA95B0 29CA9624 29CA9698
29CA8628: 29CA970C 29CA9780 29CA97F4 29CA9868
---- block16  ptr=29C884D0  is_malloc=1  length=0x100 ----
29C88490:        0        0     A698        0        0        0        0        0
29C884B0:        0        0        0        0        0        0        0 FD0110DF
29C884D0: AB1234CD FFFC0000        0 236043A8  2C4AF93 29C98504 29C784B0 80008002
29C884F0:        1        0  1000005 1F74E7E4        0        0 23604358        0
29C88510: 23604358      400      5CE       18       28      454        0        0
29C88530:        0       24     1423  BBEE2E0        0        0        0        0
29C88550: 4D616C6C 6F634C69 74650000        0 29C89CAC 29C984DC        0        0
29C88570:        0 29C89CBC 29C89CE4 29C89D0C 29C89D34 29C89D5C 29C89D84 29C89DAC
29C88590: 29C89DD4 29C89DFC 29C89E24 29C89E4C 29C89E74 29C89E9C 29C89EC4 29C89EEC
29C885B0: 29C89F14 29C89F3C 29C89F64 29C89F8C 29C89FB4 29C89FDC 29C8A004 29C8A02C
---- block17  ptr=1F74E7E4  is_malloc=0  length=0x100 ----
1F74E7A4: 1F74E780 1F74BFA4        0        0        0        0        0        0
1F74E7C4:        0        0        0        0 15A3C78B        1  2C4AE40 1F74C2BC
1F74E7E4:        0  1000005 1F7507A1      301        0        0  1000000 1F74E864
1F74E804: 1F74E79C 1F74E7E4 1F74BFA4        0        0        0        0        0
1F74E824:        0        0        0        0        0 15A3C78B        1  2C4AE40
1F74E844: 1F74C2BC        0  1000004 1F7507B5      301  2C212D4        0  1000000
1F74E864: 1F74E8C8 1F74E800 1F74E848 1F74BFA4        0        0        0        0
1F74E884:        0        0        0        0        0        0 15A3C78B        1
1F74E8A4:  2C4AE40 1F74C2BC        0  1000003 1F7507C9      301  2C212D4        0
1F74E8C4:  1000000 1F74E92C 1F74E864 1F74E8AC 1F74BFA4        0        0        0
---- block18  ptr=BBEE2E0  is_malloc=0  length=0x100 ----
BBEE2A0: 107CB600 46020000  8000000 10000000 10000000 10000000 10000000 10000000
BBEE2C0:        0   3CFE16        0        1  41CC474  41C941A        0        0
BBEE2E0:  5D87F8C        1  6FD3510  6FD1DD0  BCAC7AC  BBEF2B8  BBEE2E8  77DC6A4
BBEE300:        7    10000        2        0  5D87F8C  2C153DA  2C153E4  77DC68C
BBEE320:        0  9A16B14   400000  8FC5E5E 1CCFF2CC 1DF8ECE0        0     7C0B
BBEE340:  96B17E2        0        0 1E8FB780        0        0    18000     8000
BBEE360:        0        0        0        0        0        0        0        0
--More--
BBEE380:  BBEE7C4  BBEEBFC       25        E        0        E        0       27
BBEE3A0: 28BF8574        0        0        0        0        0 2131CF68        0
BBEE3C0:        0        0       28        F       28       28       33 29FECF5C
---- block19  ptr=29C9A598  is_malloc=0  length=0x100 ----
29C9A558: 29CA8378 29CA8394 29CA83B0 29CA83CC 29CA83E8 29CA8458 29CA8420 29CA8458
29C9A578: 29CA8474 29CA843C 29CA8490 29CA84AC 29CA84C8 29CA84E4 29CA8500 29CA851C
29C9A598: 15A3C78B        0  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B
29C9A5B8:        0  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B        0
29C9A5D8:  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B        0  2C4A6BF
29C9A5F8: 29C98534 EF4321CD        0        0 15A3C78B        0  2C4A6BF 29C98534
29C9A618: EF4321CD        0        0 15A3C78B        0  2C4A6BF 29C98534 EF4321CD
29C9A638:        0        0 15A3C78B        0  2C4A6BF 29C98534 EF4321CD        0
29C9A658:        0 15A3C78B        0  2C4A6BF 29C98534 EF4321CD        0        0
29C9A678: 15A3C78B        0  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B
---- block20  ptr=29C9A6A4  is_malloc=0  length=0x100 ----
29C9A664:  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B        0  2C4A6BF
29C9A684: 29C98534 EF4321CD        0        0 15A3C78B        0  2C4A6BF 29C98534
29C9A6A4: EF4321CD        0        0 15A3C78B        0  2C4A6BF 29C98534 EF4321CD
29C9A6C4:        0        0 15A3C78B        0  2C4A6BF 29C98534 EF4321CD        0
29C9A6E4:        0 15A3C78B        0  2C4A6BF 29C98534 EF4321CD        0        0
29C9A704: 15A3C78B        0  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B
29C9A724:        0  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B        0
29C9A744:  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B        0  2C4A6BF
29C9A764: 29C98534 EF4321CD        0        0 15A3C78B        0  2C4A6BF 29C98534
29C9A784: EF4321CD        0        0 15A3C78B        0  2C4A6BF 29C98534 EF4321CD
---- block21  ptr=29C9A7BC  is_malloc=0  length=0x100 ----
29C9A77C:  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B        0  2C4A6BF
29C9A79C: 29C98534 EF4321CD        0        0 15A3C78B        0  2C4A6BF 29C98534
29C9A7BC: EF4321CD        0        0 15A3C78B        0  2C4A6BF 29C98534 EF4321CD
29C9A7DC:        0        0 15A3C78B        0  2C4A6BF 29C98534 EF4321CD        0
29C9A7FC:        0 15A3C78B        0  2C4A6BF 29C98534 EF4321CD        0        0
29C9A81C: 15A3C78B        0  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B
29C9A83C:        0  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B        0
29C9A85C:  2C4A6BF 29C98534 EF4321CD        0        0 15A3C78B        0  2C4A6BF
29C9A87C: 29C98534 EF4321CD        0        0 15A3C78B        0  2C4A6BF 29C98534
29C9A89C: EF4321CD        0        0 15A3C78B        0  2C4A6BF 29C98534 EF4321CD
---- block22  ptr=15A3C788  is_malloc=0  length=0x100 ----
15A3C748:        0        0        0        0        0        0        0        0
15A3C768:        0        0        0        0        0        0        0        0
--More--
15A3C788:        0        0        0        0        0        0        0        0
15A3C7A8:        0        0        0        0        0        0        0        0
15A3C7C8:        0        0        0        0        0        0        0        0
15A3C7E8:        0        0        0        0        0        0        0        0
15A3C808:        0        0        0        0        0        0        0        0
15A3C828:        0        0        0        0        0        0        0        0
15A3C848:        0        0        0        0        0        0        0        0
15A3C868:        0        0        0        0        0        0        0        0
---- block23  ptr=B0D0B0C  is_malloc=0  length=0x100 ----
B0D0ACC: 41414120 41747472 4C205375 62000000 41414120 41747472 4C204864 72000000
B0D0AEC: 41414120 41747472 20436F70 79206C69 73747300 41414120 41747472 204C6973
B0D0B0C: 74000000 41414120 41747472 20537472 696E6700 41414120 41434354 20424320
B0D0B2C: 436F756E 74657200 41414120 61636374 20726573 706F6E73 65000000 41414120
B0D0B4C: 4C6F6361 6C204461 74610000 41414120 41636374 2041564C 6E6F6465 20636875
B0D0B6C: 6E6B0000 41414120 41636374 20526571 20636875 6E6B0000  BB989F0  612E7C4
B0D0B8C:   160064  B0D0B9C        0        0        D  76793B0        9  76793A8
B0D0BAC:  BB989F0        0        0        0        0 5DDF4801 B4DF4801 B4DF4801
B0D0BCC: B4DF4801 B4DF4801 B4DF4801 B4DF4801 B4DF4801 B4DF4801 B4DF4801 B4DF4801
B0D0BEC: B4DF4801 B4DF4801 B4DF4801 B4DF4801 B4DF4801 B4DF4801 B4DF4801 B4DF4801
---- block24  ptr=5E20684  is_malloc=0  length=0x100 ----
5E20644: 6F6F6C73        0 50726976 61746520 506F6F6C 73000000 48656164 65722050
5E20664: 6F6F6C73        0 7365713A 20636100 2A506163 6B657420 48656164 65722A00
5E20684: 2A506163 6B657420 44617461 2A000000 50415254 49434C45 50414B44 55504641
5E206A4: 494C0000 64617461 6772616D 5F646F6E 65000000 536D616C 6C000000 4D696464
5E206C4: 6C650000 56657279 42696700 48756765        0 636F6E74 6967756F 75732064
5E206E4: 73740000 73636174 74657265 64000000 636F6E74 6967756F 75732073 72630000
5E20704: 70616B5F 72657175 65756500 70616B5F 64657175 65756500 70616B5F 6765745F
5E20724: 656C656D 656E7400 70616B5F 696E7371 75657565        0 70616B5F 656E7175
5E20744: 65756500 70616B5F 756E7175 65756500 5061636B 65742045 6C656D65 6E747320
5E20764: 43616368 65000000 5061636B 65742045 6C656D65 6E747300 6964625F 6363615F
---- block25  ptr=C916EB0  is_malloc=1  length=0x340 ----
C916EB0: AB1234CD FFFE0000        0  5E20684   658B96  C9171F0  C916B84 80000188
C916ED0:        1        0  1000001 1F74E974 AFACEFAD  A2A4D61 72202031 2031313A
C916EF0: 34363A32 322E3739 343A2020 20415320 312C2046 6C616773 20307830 3A284E55
C916F10: 4C4C292C 20536571 20302F30 20696E74 65720100  CCCCCCC    7C464 1325ED00
C916F30: 588D09DE B7000800 45600054 EB180000 7906AFCB  A4311C8  A408015  7D060B6
C916F50: 4ADEA287  4B520C3 50184050 E4CD0000 24000000        0 9D000000 4572726F
C916F70: 723A2044 4220436F 6E666967        0        0        0        0  A20636F
--More--
C916F90: 64656320 67373131 756C6177  D0A2063 6F646563 20673731 31616C61 770D0A20
C916FB0: 636F6465 63206737 32396172 380D0A20 636F6465 63206737 32396162 72380D0A
C916FD0: 206D6178 696D756D 20736573 73696F6E 73203130  D0A2061 73736F63 69617465
C916FF0: 20617070 6C696361 74696F6E 20534343 500D0A21  D0A6473 70666172 6D207072
C917010: 6F66696C 65203220 636F6E66 6572656E 63652020  D0A2063 6F646563 20673731
C917030: 31756C61 770D0A20 636F6465 63206737 3131616C 61770D0A 20636F64 65632067
C917050: 37323961 72380D0A 20636F64 65632067 37323961 6272380D  A20636F 64656320
C917070: 67373239 72380D0A 20636F64 65632067 37323962 72380D0A 206D6178 696D756D
C917090: 20736573 73696F6E 7320370D  A202D2D 4D6F7265 2D2D2000 29000900  74C4956
C9170B0:    B0005  1001600 11000000  10101CC    40A40 8146001A   100000    10000
C9170D0:     FFFF FFFF3A28 57BB57FB CCDE6A61 C3CA973B 46D9A59C 68366EA3 27ECDB96
C9170F0:  ADB43F7 147E8DEC ABFE8446 F0D1649E 1ABCD774 18374CBB 24FEB3A2 4D53A688
C917110: 554E631C E38CC766  3DF57AF C9726DC6  5F6B74E 5F5E7433 EE71F530 85B58C8C
C917130: 8ED7DE0A 5566ADDE 8CD59BE4 54B12A68 30418475 A0C8E476 50C6757E 73688CF7
C917150: 35DD2996 3B8D02E9 3879CCEC 83FFDC72 55E2360A ADABC70A 5A6988AE A4ADFC61
C917170: 3D17F623 D1F570C7        0        0        0        0        0        0
C917190:        0        0        0        0        0        0        0        0
C9171B0:        0        0        0        0        0        0        0        0
C9171D0:        0        0        0        0        0        0        0 FD0110DF
---- block26  ptr=C916830  is_malloc=1  length=0x340 ----
C9167F0:        0        0        0        0        0        0        0        0
C916810:        0        0        0        0        0        0        0 FD0110DF
C916830: AB1234CD FFFE0000        0  5E20684   658B96  C916B70  C916504 80000188
C916850:        1        0  1000001 1F74E974 AFACEFAD 7D000061 72202031 2031313A
C916870: 34343A35 372E3733 383A2020 207B7479 7065203D 20362C20 6C656E67 7468203D
C916890: 20367D00 3A204E75 6D626572 206F6620 35300100  CCCCCCC   1B588D  9DEB640
C9168B0: C4641325 ED010800 45C00039 E2000000 FF069EF6  A408147  A40A440   17F64A
C9168D0: 90DF4907 2801CA86 50180FCD A1280000 4D4C4956 3030312D 30313043 56473032
C9168F0: 23020102 FF010000        0        0        0  2000000 FF001A0A        0
C916910:        0        0        0        0        0        0        0        0
C916930:        0        0        0        0        0        0        0        0
C916950:        0        0        0        0        0        0 20687474 703A2F2F
C916970: 7777772E 63697363 6F2E636F 6D2F7465 63687375 70706F72 740A436F 70797269
C916990: 67687420 28632920 31393836 2D323030 39206279 20436973 636F2053 79737465
C9169B0: 6D732C20 496E632E  A436F6D 70696C65 64205468 75203136 2D417072 2D303920
C9169D0: 31383A33 38206279 2070726F 645F7265 6C5F7465 616D0006   146369 73636F20
C9169F0: 57532D43 36353036 2D450002   110000    10101 CC00040A 40814A00  3001647
C916A10: 69676162 69744574 6865726E 6574332F 33000400  8000000 29000900  74C4956
C916A30:    B0005  1001600 11000000  10101CC    40A40 814A001A   100000    10000
C916A50:     FFFF FFFFF423 A5F2F8F6 AB736DCC 8F5A5320 BF38AFCE 919E3A72 DD530B1F
C916A70: C3AB1913 A9E76315 CA92EF06 1FE1AAB9  9EABB75 12B896F7 32B41868 53466D22
C916A90: FBC02D78 A59050AE 5DBAC208  62418E3 619BECEB 1BEB6FA0 6FB1A376 F64FD62C
--More--
C916AB0: 2D4EF05D EA0B5B08 37E26F48 C86F77B3 6F036981 5CF11D2A B3BFFF32 DFE2A525
C916AD0: 46800C84 333C03E1 16D74088 19CE3310 8CF098B6 5A1B08D1 8E4C5B32 31DA1119
C916AF0:  84DF008 36310642        0        0        0        0        0        0
C916B10:        0        0        0        0        0        0        0        0
---- block27  ptr=1F74E974  is_malloc=0  length=0x100 ----
1F74E934: 1F74E910 1F74BFA4        0        0        0        0        0        0
1F74E954:        0        0        0        0 15A3C78B        1  2C4AE40 1F74C2BC
1F74E974:        0  1000001 1F7507F1      301  2C212D4        0  1000000        0
1F74E994: 1F74E92C 1F74E974 1F74BFA4        0        0        0        0        0
1F74E9B4:        0        0        0        0        0        0 FD0110DF AB1234CD
1F74E9D4: FFFE0000        0 1F742138  2C4A250 1F750204 1F74C2A0 80000C02        1
1F74E9F4:        0  1000001 1F74E974 1F74E974 80000000        0 1F74E910 80000000
1F74EA14:        0 1F74E8AC 80000000        0 1F74E848 80000000        0 1F74E7E4
1F74EA34: 80000000        0 1F74E780 80000000        0 1F74E71C 80000000        0
1F74EA54: 1F74E6B8 80000000        0 1F74FAE0     8000        0 1F74E5F0 80000000
---- block28  ptr=A2A4D60  is_malloc=0  length=0x100 ----
A2A4D20:  6E6DF14 CC6D01BD 85416F61 D25BA656  D8ADCD3 A8655739 A34A32D6 3A37D41E
A2A4D40: 3CC1B8DB 7F3E46DC ED65C68F A48E65D3  F29D8B0 FB72C6EE 8DB7A21F 3DAE6BFA
A2A4D60: 21795D79 8DEF4B49 3B1A27E1 4F03420B C471821C 50DCB6B2 71587A94 71789B3E
A2A4D80: 5766FD51 9EDD3486 BBDD7D5E 5E79AF5D D94E555F D6A67715 B5E974B6 89312F1A
A2A4DA0: BB9267AD F78ED27F 41CEAD89 75D1A322 234B7D99 139967AE 17CE0FC6 642EE7A8
A2A4DC0: 785D85B0 A6646D35 EC5EC17A 75DC0F65 C07B990B AB7E72AD ED4E96DA CA765FC2
A2A4DE0: 3ECD50D6 BB38AE90 8F3F6230 48B3E6F3 4EF3F915 F3F9F074 798D0DA6 9DDFF381
A2A4E00: F57028A7 C1C27BC2 A938654C FB38AA03 583B09B1 A3EF34E7 EAF789CF  A31E59C
A2A4E20: 5043E436 F17DD2D8 E2F341F3 6B4389C8 B6DC4ADF EADC75BE 5558E79F 9033D056
A2A4E40: 9D97907E  4113C27 B16A89D3 97F2397D 4E7C8B9C 85A38CF7 C6571ABF 3FE22B6B
---- block29  ptr=20313138  is_malloc=0  length=0x100 ----
203130F8:        0        0        0        0        0        0        0        0
20313118:        0        0        0        0        0        0        0        0
20313138:        0        0        0        0        0        0        0        0
20313158:        0        0        0        0        0        0        0        0
20313178:        0        0        0        0        0        0        0        0
20313198:        0        0        0        0        0        0        0        0
203131B8:        0        0        0        0        0        0        0        0
203131D8:        0        0        0        0        0        0        0        0
203131F8:        0        0        0        0        0        0        0        0
20313218:        0        0        0        0        0        0        0        0
---- block30  ptr=35333A30  is_malloc=0  length=0x100 ----
--More--
353339F0:        0        0        0        0        0        0        0        0
35333A10:        0        0        0        0        0        0        0        0
35333A30:        0        0        0        0        0        0        0        0
35333A50:        0        0        0        0        0        0        0        0
35333A70:        0        0        0        0        0        0        0        0
35333A90:        0        0        0        0        0        0        0        0
35333AB0:        0        0        0        0        0        0        0        0
35333AD0:        0        0        0        0        0        0        0        0
35333AF0:        0        0        0        0        0        0        0        0
35333B10:        0        0        0        0        0        0        0        0
---- block31  ptr=332E3630  is_malloc=0  length=0x100 ----
332E35F0:        0        0        0        0        0        0        0        0
332E3610:        0        0        0        0        0        0        0        0
332E3630:        0        0        0        0        0        0        0        0
332E3650:        0        0        0        0        0        0        0        0
332E3670:        0        0        0        0        0        0        0        0
332E3690:        0        0        0        0        0        0        0        0
332E36B0:        0        0        0        0        0        0        0        0
332E36D0:        0        0        0        0        0        0        0        0
332E36F0:        0        0        0        0        0        0        0        0
332E3710:        0        0        0        0        0        0        0        0
---- block32  ptr=303A2024  is_malloc=0  length=0x100 ----
303A1FE4: 6E58C00C 338A6391 C3A75F7E BF95993E B68B8974 5DF7551D 4FECFFFF 16E6FEA1
303A2004: DD1486AB F80A0D6F F13454AB B7FE60A7 43213D2B B856CB4D B1D80D0B A7D82E75
303A2024: FE511E24 880696DB 9579FCD0 839F91FD F615D84F 5091DF2C DDBD9DB4 7B4E0AE3
303A2044: 56CB241E 9CB7095F B20FA9FF 4C1FC208 87386BB3 F32A0F9D 14FCB22A A5B99EFB
303A2064: 2E299B07 E1771F98 4F713AFC 69D83256 C9D985F7 D98BC72D  C40AACC 3EE76771
303A2084: 563782B1 1615BC10 4ABC70C0 228DD0E6 4506756C 68AB5A6D A5B282C9 C3EAD6B3
303A20A4:  2D3258B CD98B280 E0F1926F 7D73E4A4 8AF26901 CB3EE5EE 2D31CFCB 17EC68A0
303A20C4: 42D272F8 79E1410A D12DE3F2 13412779 95B419E3 35EF7DDF 7ADAD117 D69C45EB
303A20E4: ECB1BA87 5B9929C3 97B80F45 E353B47D 2CCD5496 73D7D09C FBC2E943 6DCDA55C
303A2104: 51948F76 C10E5EB5 152C19D0 DA3AA138 E8F980A4 7EC2D0C0 F883C0A8 357B85AF
---- block33  ptr=322D4348  is_malloc=0  length=0x100 ----
322D4308:        0        0        0        0        0        0        0        0
322D4328:        0        0        0        0        0        0        0        0
322D4348:        0        0        0        0        0        0        0        0
322D4368:        0        0        0        0        0        0        0        0
322D4388:        0        0        0        0        0        0        0        0
322D43A8:        0        0        0        0        0        0        0        0
--More--
322D43C8:        0        0        0        0        0        0        0        0
322D43E8:        0        0        0        0        0        0        0        0
322D4408:        0        0        0        0        0        0        0        0
322D4428:        0        0        0        0        0        0        0        0
---- block34  ptr=24F5CB48  is_malloc=0  length=0x100 ----
24F5CB08:        0        0        0        0        0        0        0        0
24F5CB28:        0        0        0        0        0        0        0        0
24F5CB48:        0        0        0        0        0        0        0        0
24F5CB68:        0        0        0        0        0        0        0        0
24F5CB88:        0        0        0        0        0        0        0        0
24F5CBA8:        0        0        0        0        0        0        0        0
24F5CBC8:        0        0        0        0        0        0        0        0
24F5CBE8:        0        0        0        0        0        0        0        0
24F5CC08:        0        0        0        0        0        0        0        0
24F5CC28:        0        0        0        0        0        0        0        0
---- block35  ptr=2463A44C  is_malloc=0  length=0x100 ----
2463A40C:        0        0        0        0        0        0        0        0
2463A42C:        0        0        0        0        0        0        0        0
2463A44C:        0        0        0        0        0        0        0        0
2463A46C:        0        0        0        0        0        0        0        0
2463A48C:        0        0        0        0        0        0        0        0
2463A4AC:        0        0        0        0        0        0        0        0
2463A4CC:        0        0        0        0        0        0        0        0
2463A4EC:        0        0        0        0        0        0        0        0
2463A50C:        0        0        0        0        0        0        0        0
2463A52C:        0        0        0        0        0        0        0        0
---- block36  ptr=3B644AC4  is_malloc=0  length=0x100 ----
3B644A84: 7A97FC5E AFB60BCD 36DFA58E 36FBF9C0 92BB4D72 B756E57D CEDCE00F 784F47DB
3B644AA4: 8FFB8078 572F3A27 458781CC   FE786B B4CB449B EC741C39 5F8D8B4E 55A4BEB7
3B644AC4: 3387EC7E 41965969 33D624F0 325569B7 1B14EF8B 63517FF9  B53137E F4725993
3B644AE4: 9EBAD1CC B1DC13A3 D34DC2E5 1DDF4B8F F4AC52C0 2CB02CF5 9F05B5E6 48668E7A
3B644B04: CC6FCD01 3387DF06 BD2A32AB F4CAEFAC 1292EEF4 E8873038 C8641D9D 24E9C6F8
3B644B24: 807A10A2 BEC9545F 722DDA9D  B3B85D1 4226A1B3 CAE1B55A 9DE491BE BFBC253A
3B644B44: BC6226A1 8B35AC11 D31B3431 93B095CA 5B03E188 1CA9D337 A1FDCBC1 A0B39096
3B644B64: 6CB55A61 6B05A2CE 2D909954 722DCADD 5B4C69B3 5BC9D077 F1C5B57C 7C1BAE81
3B644B84: 5A3C85A6 8E8BF461 93B64887 9BB4ACE2 F3DC2A46 99FC3E20 8B22A4E2 22EE975B
3B644BA4: 74202BFC A0410F77 4F55071F AB7E2B77 D3CA529D AAAECE44 FA9830D4 D31FA00C
---- block37  ptr=230ACD34  is_malloc=1  length=0x100 ----
230ACCF4:  6C530A0  4C957E1 230ACD34 230ACBB0 8000000E        1        0  1000001
--More--
230ACD14: 1F74E974 636C6964 5F636F6C 5F6E7077 5F330000        0        0 FD0110DF
230ACD34: AB1234CD FFFE0000        0  6C530B4  4C95801 230ACD90 230ACCFC 80000016
230ACD54:        1        0  1000001 1F74E974 6275696C 74696E3A 6170705F 636C6964
230ACD74: 5F636F6C 5F6E7077 5F335F73 63726970 742E7463 6C000000 FD0110DF AB1234CD
230ACD94: FFFE0000        0  6C530E8  4C95823 230ACDEC 230ACD48 80000016        1
230ACDB4:        0  1000001 1F74E974 6275696C 74696E3A 6170705F 636C6964 5F636F6C
230ACDD4: 5F6E7077 5F335F73 63726970 742E7463 6C000000 FD0110DF AB1234CD FFFE0000
230ACDF4:        0 1F330F08  2C1AD33 230AD3FC 230ACDA4 800002F0        1        0
230ACE14:  1000001 1F74E974        0 23064B4C 230E3F10        0 1F330EB8        A
---- block38  ptr=17F3F57C  is_malloc=0  length=0x100 ----
17F3F53C:        0        0        0        0        0        0        0        0
17F3F55C:        0        0        0        0        0        0        0        0
17F3F57C:        0        0        0        0        0        0        0        0
17F3F59C:        0        0        0        0        0        0        0        0
17F3F5BC:        0        0        0        0        0        0        0        0
17F3F5DC:        0        0        0        0        0        0        0        0
17F3F5FC:        0        0        0        0        0        0        0        0
17F3F61C:        0        0        0        0        0        0        0        0
17F3F63C:        0        0        0        0        0        0        0        0
17F3F65C:        0        0        0        0        0        0        0        0
---- block39  ptr=2ECCF334  is_malloc=0  length=0x100 ----
2ECCF2F4: 32323FDB 68FF6F99 1FB9B44D FD04A5CC B6847376 CE619CA0 480A6892 FE70CD85
2ECCF314: B28488AD 7EAADD37 C3C3003E 48401861 C822B020 F3D55866 14F46178 EB144A8B
2ECCF334: 8D940556 E0ABD6B4 F30BF02B   53F38A C20B5E16 FE6664DE 97ADA93C 5BA48BA4
2ECCF354: EA7972B7 8891206E 3CB99DFA 75D8E75E 213037AD CEC83BE3 CA76F0A2 AA30717A
2ECCF374: A494B423 559997E5 461202D1 C8C1E197  E08B943 27EBB59E CB84D1CC B1C3576C
2ECCF394: DA547B42 CB1AAA12 B6A08B1C 478A2AEC E17E1611 79C72EF3 1565159E BF58CE66
2ECCF3B4: 6045C98A 72D63457 5F920D54 28AB563B 915C60BC E3C031A5 39129308 DEB0DDBB
2ECCF3D4: 4073D868 D271F129  5EEAD39 936E2FD3 EB4EC16C  86F69A1 BB49913D 6D03196C
2ECCF3F4: 1710E073 C15B2ED0   FD686A  5223990 6FA71D53 F94BC351 53B22A52 D21BC2AB
2ECCF414: 7D6E16CF DDAFF287 F97D36BB FB75775E 66E1E8D8 CA6D9851 C86F7A83 C1F9E0D0
---- block40  ptr=175A062C  is_malloc=0  length=0x100 ----
175A05EC:        0        0        0        0        0        0        0        0
175A060C:        0        0        0        0        0        0        0        0
175A062C:        0        0        0        0        0        0        0        0
175A064C:        0        0        0        0        0        0        0        0
175A066C:        0        0        0        0        0        0        0        0
175A068C:        0        0        0        0        0        0        0        0
175A06AC:        0        0        0        0        0        0        0        0
175A06CC:        0        0        0        0        0        0        0        0
--More--
175A06EC:        0        0        0        0        0        0        0        0
175A070C:        0        0        0        0        0        0        0        0
---- block41  ptr=A420EE4  is_malloc=0  length=0x100 ----
A420EA4: D55FADB4 39D3A2FC  70609E2 FF5694A4 F165EE89 C9A95D07 C1F0C1AB  F0BFF95
A420EC4: 27DE92C0  BFC4C48 F310CF51 F7F0C488 821A19BC DC45C9CE BC683B71 E6D642C0
A420EE4: 59CAB3B0 99621613 C77B5E67 2607FF74 C484D308 8BC29FF6 65AFD583 7983235F
A420F04: 76ADEE77 F048EF6B 21FF6E8B E74724AE C477504D DA05860D 86A75706 C412470E
A420F24: 5ED7F65E 46663DE8 5B7160DA 1A11D053 9D00013F 3FED6DB7 E8AAC11D 776AE108
A420F44: 4D8A11E3 46DA40BC 5DBDBBB4 64B050FE 1F93FB4E FD9FB763 AFE6011C 91D47704
A420F64: 8C24F883 3FEB489F 261AFBE1 FFECFC07  CFC2EA8 15DB7ED8 865E0729 59F6CBF8
A420F84: 66A1952E 1DFD49DD 9E5F6BCA 80AD1C42 195CEE78 DB34592B 7A73599C AC596707
A420FA4: C356B95E 832E23D1 71D2AF1F 42E5F172 7B341743 E957133B  BF7F508 D9873229
A420FC4: 5290CF8F CFF7536A D9DCEA87 98CEF3EF E4753B65 146F64C7 79C0D591 7DA1AAB4
---- block42  ptr=20B491BC  is_malloc=1  length=0x4C4 ----
20B4917C:        0        0        0        0        0        0        0        0
20B4919C:        0        0        0 1F74E974        1 20B491EC 20B48864 FD0110DF
20B491BC: AB1234CD FFFE0000        0  5E20674   658B4D 20B49680 20B48D0C 8000024A
20B491DC:        1        0  1000001 1F74E974        0        0        0        0
20B491FC:        0        0 FFFF0000        0        0       54        0        0
20B4921C:        0       54        0        0        0        0        0        0
20B4923C:        0        0        0        0        0 FF000000        0        0
20B4925C:        0        0        0        0        0        0        0        0
20B4927C:        0        0        0        0        0        1        0 2080C1A4
20B4929C:        0   6583EC        0        0        0        0        0        0
20B492BC:        0        0        0        0        0        0        0        0
20B492DC:        0        0        0        0        0        0        0        0
20B492FC:        0        0        0        0        0        0        0        0
20B4931C:     2144        0     2144        0        0        0        0        0
20B4933C:        0        0        0        0        0        0        0        0
20B4935C:        0        0        0        0        0        0        0        0
20B4937C:        0        0        0        0        0        0        0        0
20B4939C:        0        0        0        0        0        0        0        0
20B493BC:        0        0        0        0        0        0        0        0
20B493DC:        0        0        0        0        0        0        0        0
20B493FC:        0        0        0        0        0        0        0        0
20B4941C:        0        0        0        0        0        0        0        0
20B4943C:        0        0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
20B4945C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
20B4947C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
20B4949C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
20B494BC: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF        0        0        0        0
--More--
20B494DC:        0        0        0        0        0        0        0        0
20B494FC:        0        0        0        0        0        0        0        0
20B4951C:        0        0        0        0        0        0        0        0
20B4953C:        0        0        0        0        0        0        0        0
20B4955C:        0        0        0        0        0        0        0        0
20B4957C:        0        0        0        0        0        0        0        0
20B4959C:        0        0        0        0        0        0        0        0
20B495BC:        0        0        0        0        0        0        0        0
20B495DC:        0        0        0        0        0        0        0        0
20B495FC:        0        0        0        0        0        0        0        0
20B4961C:        0        0        0        0        0        0        0        0
20B4963C:        0        0        0        0        0        0        0        0
20B4965C:        0        0        0        0 1F74E974        1 20B496B0 20B48D28
20B4967C: FD0110DF
---- block43  ptr=32AB1B38  is_malloc=0  length=0x100 ----
32AB1AF8:        0        0        0        0        0        0        0        0
32AB1B18:        0        0        0        0        0        0        0        0
32AB1B38:        0        0        0        0        0        0        0        0
32AB1B58:        0        0        0        0        0        0        0        0
32AB1B78:        0        0        0        0        0        0        0        0
32AB1B98:        0        0        0        0        0        0        0        0
32AB1BB8:        0        0        0        0        0        0        0        0
32AB1BD8:        0        0        0        0        0        0        0        0
32AB1BF8:        0        0        0        0        0        0        0        0
32AB1C18:        0        0        0        0        0        0        0        0
---- block44  ptr=1F339510  is_malloc=1  length=0x100 ----
1F3394D0:        1  BBEE2E0        0        0        0        0 52656720 46756E63
1F3394F0: 74696F6E 20536500 1F33950C 1F33950C        0        0        0 FD0110DF
1F339510: AB1234CD FFFE0000        0  6503474  27C7B27 1F3395B8 1F33947C 8000003C
1F339530:        1        0  1000001 1F74E974 1F3395E8 231C8598        0        0
1F339550: 1F36E09C       64        0        C        C        0      85B      85B
1F339570:       10        0        1  BBEE2E0        0        0        0        0
1F339590: 52656720 46756E63 74696F6E 204C6900 1F3395B4 1F3395B4        0        0
1F3395B0:       12 FD0110DF AB1234CD FFFE0000        0  650348C  27C7B4E 1F339660
1F3395D0: 1F339524 8000003C        1        0  1000001 1F74E974 1F339690 1F3397E0
1F3395F0:        0        0 1F3397E0       5A        0       10       10        0
========= Additional Subsystem Crashinfo =======================================
-------------- show redundancy history --------------
--More--
00:00:52 RF_PROG_ACTIVE_PRECONFIG(202) CHKPT RF(25) op=0 rc=1100:00:52 RF_PROG_ACTIVE_PRECONFIG(202) VOIP RF CLIENT(1345) op=0 rc=1100:00:52 RF_PROG_ACTIVE_PRECONFIG(202) TPM RF client(402) op=0 rc=1100:00:52 RF_PROG_ACTIVE_PRECONFIG(202) LLDP(208) op=0 rc=1100:00:52 RF_PROG_ACTIVE_PRECONFIG(202) SNMP RF Client(34) op=0 rc=1100:00:52 RF_PROG_ACTIVE_PRECONFIG(202) History RF Client(35) op=0 rc=1100:00:52 RF_PROG_ACTIVE_PRECONFIG(202) EEM Server RF CLIENT(250) op=0 rc=1100:00:52 RF_PROG_ACTIVE_PRECONFIG(202) EEM POLICY-DIR RF CLIENT(252) op=0 rc=1100:00:52 RF_PROG_ACTIVE_PRECONFIG(202) FH_RF_Event_Detector_stub(50) op=0 rc=1100:00:52 RF_PROG_ACTIVE_PRECONFIG(202) CRYPTO RSA(130) op=0 rc=1100:00:52 RF_PROG_ACTIVE_PRECONFIG(202) PKI RF Client(131) op=0 rc=1100:00:52 RF_EVENT_SLAVE_PROG_DONE(522) Slave(3) op=0 rc=1100:00:52 RF_PROG_ACTIVE_PRECONFIG(202) Last Slave(65000) op=0 rc=1100:00:52 *my state = ACTIVE_POSTCONFIG(12) peer state = DISABLED(1)00:00:52 RF_PROG_ACTIVE_POSTCONFIG(203) First Slave(0) op=0 rc=1100:00:52 RF_PROG_ACTIVE_POSTCONFIG(203) Slave(3) op=0 rc=2300:00:52 RF_PROG_ACTIVE_POSTCONFIG(203) Redundancy Mode RF(29) op=0 rc=1100:00:52 RF_PROG_ACTIVE_POSTCONFIG(203) CHKPT RF(25) op=0 rc=1100:00:52 RF_PROG_ACTIVE_POSTCONFIG(203) VOIP RF CLIENT(1345) op=0 rc=1100:00:52 RF_PROG_ACTIVE_POSTCONFIG(203) TPM RF client(402) op=0 rc=1100:00:52 RF_PROG_ACTIVE_POSTCONFIG(203) LLDP(208) op=0 rc=1100:00:52 RF_PROG_ACTIVE_POSTCONFIG(203) SNMP RF Client(34) op=0 rc=1100:00:52 RF_PROG_ACTIVE_POSTCONFIG(203) History RF Client(35) op=0 rc=1100:00:52 RF_PROG_ACTIVE_POSTCONFIG(203) EEM Server RF CLIENT(250) op=0 rc=1100:00:52 RF_PROG_ACTIVE_POSTCONFIG(203) EEM POLICY-DIR RF CLIENT(252) op=0 rc=1100:00:52 RF_PROG_ACTIVE_POSTCONFIG(203) FH_RF_Event_Detector_stub(50) op=0 rc=1100:00:52 RF_PROG_ACTIVE_POSTCONFIG(203) CRYPTO RSA(130) op=0 rc=1100:00:52 RF_PROG_ACTIVE_POSTCONFIG(203) PKI RF Client(131) op=0 rc=1100:00:52 RF_EVENT_SLAVE_PROG_DONE(522) Slave(3) op=0 rc=1100:00:52 RF_PROG_ACTIVE_POSTCONFIG(203) Last Slave(65000) op=0 rc=1100:00:52 *my state = ACTIVE(13) peer state = DISABLED(1)00:00:52 RF_PROG_ACTIVE(204) First Slave(0) op=0 rc=1100:00:52 RF_PROG_ACTIVE(204) Slave(3) op=0 rc=2300:00:52 RF_PROG_ACTIVE(204) Redundancy Mode RF(29) op=0 rc=1100:00:52 RF_PROG_ACTIVE(204) CHKPT RF(25) op=0 rc=1100:00:52 RF_PROG_ACTIVE(204) VOIP RF CLIENT(1345) op=0 rc=1100:00:52 RF_PROG_ACTIVE(204) TPM RF client(402) op=0 rc=1100:00:52 RF_PROG_ACTIVE(204) LLDP(208) op=0 rc=1100:00:52 RF_PROG_ACTIVE(204) SNMP RF Client(34) op=0 rc=1100:00:52 RF_PROG_ACTIVE(204) History RF Client(35) op=0 rc=1100:00:52 RF_PROG_ACTIVE(204) EEM Server RF CLIENT(250) op=0 rc=1100:00:52 RF_PROG_ACTIVE(204) EEM POLICY-DIR RF CLIENT(252) op=0 rc=1100:00:52 RF_PROG_ACTIVE(204) FH_RF_Event_Detector_stub(50) op=0 rc=1100:00:52 RF_PROG_ACTIVE(204) CRYPTO RSA(130) op=0 rc=1100:00:52 RF_PROG_ACTIVE(204) PKI RF Client(131) op=0 rc=1100:00:52 RF_EVENT_SLAVE_PROG_DONE(522) Slave(3) op=0 rc=1100:00:52 RF_PROG_ACTIVE(204) Last Slave(65000) op=0 rc=1100:00:52 System initialization complete
========= Scheduler History Dump ======================
PID Exectime(ms) Caller PC Process Name
   6       10422 0x0        Check heaps
138         152 0x4EB986   Ethernet Msec Timer CFM
173         270 0x1EAE6B8  IPAM Manager
159         462 0x2E5B4A0  VRRS Main thread
138         304 0x4EB986   Ethernet Msec Timer CFM
  34          34 0x149462D  ARP Background
  24          18 0xE1420F   IPC Deferred Port Closure
  23          40 0xE13C47   IPC Periodic Timer
--More--
138         228 0x4EB986   Ethernet Msec Timer CFM
390         256 0x1F31562  MLD
119       17804 0xA5E3DC   Netclock Background Proccess
138          76 0x4EB986   Ethernet Msec Timer CFM
185         146 0x2A05D87  SSS Feature Timer
137          32 0x4EBA2C   Ethernet Timer CFM
197        2548 0x1BAA66C  CEF: IPv4 process
347         492 0x3F2CDDA  trunk conditioning supervisory
  57         274 0x18185A5  TTY Background
111          32 0xE1D441   Ether-Switch RBCP Monitor
115          64 0x419517   UHCI Periodic Task
230          36 0x16111B3  bsm_xmt_proc
157         334 0x2E5B4A0  FHRP Main thread
228         102 0x290CD53  RUDPV1 Main Process
147          22 0xA64F3E   PI MATM Aging Proc
  18     5611280 0xDBDFEF   Environmental monitor
293          54 0x4237221  CME Extension Mobility
397       11242 0x1A1A89A  EIGRP-IPv4
398        7752 0x19BA065  EIGRP-IPv4 Hello
129       42268 0x1C35B5   IP Input
   3       20404 0x41561BF  Skinny Msg Server
--More--
292         206 0x43EEC2D  VOICE REG BG Process
  84     7283464 0x68FA4A   Per-Second Jobs
  49          80 0x18BBBCD  GraphIt
120     1301938 0x84B833   BPSM stat Process
361          48 0x458F380  TRP_PSEUDOTIMER
--More--
126       27904 0x49A3BD   HWIC dsx IPC
Dumping Managed Timer Operation history [Next Entry(4)]
Index IPL Caller_pc   Timer      Operation
0     0   0x4CF9081  0x227E0A40 Managed Timer Initialized
1     0   0x4CF90A3  0x227E0A78 Managed Timer Initialized
2     0   0x4CF90BF  0x227E0AC0 Managed Timer Initialized
3     0   0x4CF90DB  0x227E0A9C Managed Timer Initialized
4     0   0x0  0x0 Empty Buffer
5     0   0x0  0x0 Empty Buffer
6     0   0x0  0x0 Empty Buffer
7     0   0x0  0x0 Empty Buffer
8     0   0x0  0x0 Empty Buffer
9     0   0x0  0x0 Empty Buffer
10    0   0x0  0x0 Empty Buffer
11    0   0x0  0x0 Empty Buffer
12    0   0x0  0x0 Empty Buffer
--More--
13    0   0x0  0x0 Empty Buffer
14    0   0x0  0x0 Empty Buffer
15    0   0x0  0x0 Empty Buffer
16    0   0x0  0x0 Empty Buffer
17    0   0x0  0x0 Empty Buffer
18    0   0x0  0x0 Empty Buffer
19    0   0x0  0x0 Empty Buffer
20    0   0x0  0x0 Empty Buffer
21    0   0x0  0x0 Empty Buffer
22    0   0x0  0x0 Empty Buffer
23    0   0x0  0x0 Empty Buffer
24    0   0x0  0x0 Empty Buffer
========= Data Inconsistency Errors =========
No data inconsistency errors have been recorded.
==== CF Client Using Large No. of Buffer for domain 0 ====
========= End of Crashinfo Collection ==========================================
------------------ show chunk failures ------------------
When      Cause   Caller     In-use    Chunk      Name
------------------ show redundancy states ------------------
       my state = 13 -ACTIVE
     peer state = 1  -DISABLED
           Mode = Simplex
        Unit ID = 0
     Maintenance Mode = Disabled
    Manual Swact = disabled (system is simplex (no peer unit))
Communications = Down      Reason: Simplex mode
   client count = 12
client_notification_TMR = 60000 milliseconds
          keep_aXXXe TMR = 4000 milliseconds
        keep_aXXXe count = 0
    keep_aXXXe threshold = 7
--More--
           RF debug mask = 0x0
MXXX001-010CVG02#             exit
http://www.netpacket.co.uk/ http://www.blog.netpacket.co.uk/
mtimm
Try changing the:
action 1050  increment noCalls
To something like:
action 1050 add $noCalls 1
action 1051 set noCalls "$_result"
If that avoids the crash, then this is caused by CSCud31581 where the increment command causes memory corruption.
Mike
Resolved! Mike looks like CSCud31581 like you suggested.
Thanks for help Mike and Joseph
Cheers
Alexis
Hi Alexis,
I know it's more work for you, but I would suggest you open a TAC SR for this still.  That way the TAC engineer can link the SR to bug and if you want the SR can be left open until a release with the fix that you can run is released.  That way we get some feedback to the development team of the impact and scope of the bug.  Or the TAC SR can be closed (if you so desire) and you can use the Cisco Notification Service to be notfied when a release with the fix is released.  The point though would be show how this impacts customers and just having it resolved through a support forums post does not help provide that context to our development team.  This is important because it can help direct our development team to commit the fix to specific places or decide not to.  One would hope that they would err on the side of caution and commit the fix everywhere it is needed since this is a crash but that may not always be the case.
Thank you,
Mike
Hi Mike,
Raised a TAC case (625147067) this morning like you suggested to put emphasis on this bug.
Thanks again for your help on this
Alexis
