EEM daily reload script
Thomas McLean
Hi all,
I've got a very small requirement that means I need to reload about 5 routers daily - these sites have very bad attenuation and reloading the router seems to sort it somewhat for a few hours so I'm ideally looking to write a script that will reload the router at say 0500 every morning.
I thought I had it right but I don't - could anyone give me any pointers for a daily reload?
Cheers,
Thomas
Joe Clarke
This should do it for you:
event manager applet daily-reload
event timer cron cron-entry "0 5 * * *"
action 1.0 reload
Joe Clarke
action 1.0 reload
Thanks Joseph,
I havent implemented this yet but I know from past experience this will work as in my past life I used cron on a daily basis.
I was using kron last night but that didn't work.
Thanks for your help.
Thomas.
