EEM for detect route change from ospf to static
Juníperus
I need periodocaly check status of default route (0.0.0.0/0) on my devices.
I normal situation default route from ospf via tunnel interface must be determined.
If default route changes (tunnel is down) I need notification via syslog.
I gteated next script:
event manager applet CHECK_DEFAULT_ROUTE_HQ
 event timer watchdog time 30
 action 10 cli command "show ip route 0.0.0.0"
 action 20 regexp "Tunnel" "$_cli_result" ignore match
 action 30 if $_regexp_result eq "0"
 action 40  syslog msg "default_route_changes_detected via script"
 action 50 end
But this scenario always write syslog msg "default_route_changes_detected via script".
it seems that the function (regexp) does not work correctly in my case.
0 Replies 0
