EEM - How to use argument passed into applet in a CLI command
6502
I have an eem "none" event applet that uses a wait action.  I'd like to be able to pass in the number of seconds to wait as an agument to the applet.  I'm able to use applet agruments ($_none_arg1, etc.) within CLI commands where a WORD is expected, but this doesn't seem to work when the command parser is expecting a numeric value.  Is there something I need to do to escape the argument in order to get the parser to accept it?
Based on my continued familiarization with EEM, it appears that the eem CLI parser isn't equipped to accept "$" variables representing numberic values.  Thinking about it, this would require run-time evaluation of these values, which is not a reasonable ask of the eem applet environment.
7 Replies 7
action xxx cli command "event timer countdown time xxx"
did you try this ?
The parser doesn’t like $_none_arg2 as a value for “time”.
I will try that when I have access to the equipment again.  I hope it works, but my concern is that the CLI parser only wants to see numeric characters for that argument, and doesn't know how to derefernce any variable starting with $.
6502
Tired, that didn't work.  The parser only wants to take a numeric value, so it appears that's either as designed/needs a feature enhancement request.
can you post the entire EEM script you are using ?
6502
