EEM Multiple string
alexanderkieser
Frequent Visitor
Frequent Visitor
So instead of having multiple scripts, trying to combine 3 into one, see below. It doesn't seem to be adding the strings, any suggestions?
no event manager applet DETECT_CDP_Add authorization bypass
event neighbor-discovery interface regexp .*GigabitEthernet.* cdp add
action 1 puts "CDP Device Type $_nd_cdp_platform detected on Interface $_nd_local_intf_name"
action 2 set result "0"
action 3.1 string equal length 8 "AIR-AP38*" "$_nd_cdp_platform"
action 3.2 if $_string_result eq 1
action 3.3 set result "1"
action 4.1 string equal length 8 "AIR-AP27*" "$_nd_cdp_platform"
action 4.2 if $_string_result eq 2
action 4.3 set result "2"
action 5.1 string equal length 8 "AIR-AP35*" "$_nd_cdp_platform"
action 5.2 if $_string_result eq 3
action 5.3 set result "3"
action 6.0 end
action 10 if $result eq 1
action 11 cli command "enable"
action 12 cli command "conf t"
action 13 cli command "switchport access vlan 101"
action 14 end
action 20 if $result eq 2
action 21 cli command "enable"
action 22 cli command "conf t"
action 23 cli command "switchport access vlan 102"
action 30 if $result eq 3
action 31 cli command "enable"
action 32 cli command "conf t"
action 33 cli command "switchport access vlan 103"
action 99 end
Joe Clarke
What do you mean "adding the strings?"  You may want to have a look at the solution I posted as the first comment to https://supportforums.cisco.com/document/100791/automatically-set-port-descriptions .
