EEM not giving me the Interface option
I am trying to configure the Event Manager to send me an email when the utilization threshold of one of my interfaces goes above 75%, but when I try to configure it, the interface option is not available. I made sure that feature evmed is enabled. I will list the option the NX-OS gives me. This is a Nexus 9000 running ver 7.0(3) I7 (5). Can someone tell me why I don't get the interface option?
(config-applet)# event ?
cli Create a cli event specification
counter Create a counter event
fanabsent Create fanabsent event specification
fanbad Create fanbad event specification
fib FIB related event
gold Create a 'Diagnostic' event specification
internal-link-flap Create a 'internal-link-flap' event specification
memory Create memory thresholds event specification
module Create a 'module' event specification
module-failure Create a 'module-failure' event specification
neighbor-discovery Show CDP new neighbors
none Manually run policy event with none
oir Create Online-Insertion-Removal event specification
policy-default Use the event in the system policy being overridden
poweroverbudget Create poweroverbudget event specification
snmp Create a 'snmp' event specification.
storm-control Create a storm control event specification
syslog Create a syslog event specification
sysmgr System manager related events
tag Event tag identifier
temperature Create temperature event specification
test Create a 'test' event specification
timer Create a timer event specification
track Create a 'track' event specification
balaji.bandi
if you looking interface threshold you should example as below :
event tag X interface name ethernet x/x  parameter rxload entry-op gt entry-val 75 entry-type value poll-interval 30
BB
Thank you for your response. I tried that, but didn't put it in my comment. Here is what I get:
TK5-3WP03-R02-93180-01(config)# feature evmed
TK5-3WP03-R02-93180-01(config)# event manager applet int-rate-test
TK5-3WP03-R02-93180-01(config-applet)# event tag test interface ?
% Invalid command at '^' marker.
TK5-3WP03-R02-93180-01(config-applet)# event tag test ?
