Bookmark
Subscribe
3923
EEM Script for parsing & writing to output
patelvc7601
I am trying to capture output of certain command & Parse & than write the output into the file . I also want to repeate this process & appened the output .
Below works fine where I am capturing the output & appending to the file but i want to parse the output(show cell 0 all | inc SNR|RSSI|RSRP) & than wanted to write the file .
I looked into the action file but there is no append
event manager applet SIGNAL-STRENGTH
event timer cron name SIGNAL-STRENGTH cron-entry "*/5 * * * *"
action 10 cli command "enable"
action 20 cli command "show clock | append flash:SIGNAL-STRENGTH.txt"
action 30 cli command "show cell 0 all | append flash:SIGNAL-STRENGTH.txt"
Also documentation wise, if someoone can suggest material that will be great.
Sincerely
Viral Patel
2 Accepted Solutions
They resemble the Tcl functionality.  So remove "file" and look at the Tcl docs for the next command (e.g., "open", "puts", etc.).
For open : https://www.tcl.tk/man/tcl8.3/TclCmd/open.htm
thank you joe.
Sincerely
Viral Patel
Joe Clarke
The file action is a series of actions.  The first being "file open".  This takes an argument of the access type of the file.  If you open the file with "a" then it is opened for appending:
file open fd flash:SIGNAL-STRENGTH.txt a
file puts fd "Hello,"
file close fd
file puts fd "World!"
file close fd
At this point, the file's contents will be:
World!
Thanks  Joe, that worked.
 where can I find mor information on file command.
Sincerely
Viral Patel
thank you joe.
Sincerely
Viral Patel
