EEM Script issue blocking show run
Mark Malone
any TCL wizards out there may be able to help me with this script
We have huge menus running on our devices and I wanted to block the menu and alias syntax from the running config
I put this script together from bits on the forums and its working well , when you check sh run ... you don't see menu commands or alias
The issue is its not allowing the shortcut command anymore like sh run int g0/0/0 , instead it shows the whole sh run
I have tried a few things to alter it but getting no where
any help appreciated scripting's not my strong point thanks
This is what I have so far
event manager applet MenuBlock
 event cli pattern "show run" sync yes
 action 111 cli command "enable"
 action 112 cli command "show run | excl menu|alias"
 action 114 puts "$_cli_result"
 action 115 set _exit_status "0"
15 Replies 15
Great thanks Joe ill try that and bounce it off TAC too see what they say , appreciate that
