EEM Script to apply the QOS command in interface as per time base
jubair151
I want to apply service policy in my router lan interface time basis. I want to control non-business traffic in business hours, I am thinking to apply QOS to rate limit the non-business traffic in business hours. Hence, i am seeking a help for a EEM script which will punch and remove  the commands as per the time basis.
Jubair.S
Joe Clarke
You can wrap your commands around an EEM timer applet:
event manager applet timed-qos-enable
 event timer cron cron-entry "0 8 * * *"
 action 001 cli command "enable"
 action 002 cli command "config t"
! QoS enable commands here
event manager applet timed-qos-disable
 event timer cron cron-entry "0 18 * * *"
! QoS disable commands here
Joe Clarke
Thanks Joseph...it worked!!!!!....
