EEM Script to parse log buffer for current date
mlossmann
Community Member
Greetings,
I have a EEM script that looks for OSPF down/full neighbors, but I am wondering if there is a way that I can have the EEM Script look for the current date that the script was run?
For example, if I have an OSPF neighbor go down, is there a way that I could only show the date and time (+/- 10 minutes) to show up in the email alert?
Thanks in advance for any help.
-Mike
Joe Clarke
Try using $_event_pub_time within your applet.
Thanks for the reply Joseph.  Would this go into my "action" where I have the email generated?  If so, is there any specific place it should go or anywhere in the action is fine
-Mike
Anywhere in a string within an action is fine.
