EEM script using SNMP set-type int does not work on C2811...
Sergey Kostenko
Frequent Visitor
Frequent Visitor
I try to use these actions on my EEM script:
action 10.0 info type snmp oid .1.3.6.1.2.1.1.4.0 set-type string "[email protected]" community SWITCH ipaddr 10.1.101.21
Than get syslog:
Apr 12 16:20:22 10.1.101.1 000250: Apr 12 13:20:21.088: %HA_EM-7-FMFD_SNMP_OID_MAKE_FAIL: fh_fd_snmp_varbind_make: Unable to build an oid string into a SNMP oid; oid = .1.3.6.1.2.1.1.4.0
Apr 12 16:20:22 10.1.101.1 000251: Apr 12 13:20:21.088: %HA_EM-7-FMFD_SNMP_VARBIND_FAIL: fh_fd_snmp_set_var_remote: Unable to create a SNMP varbind
But when I try to execute bush-script at below, work result  is sucess:
#!/bin/sh
snmpset -v 1 -c SWITCH 10.1.101.21 .1.3.6.1.2.1.1.4.0 string "[email protected]"
How configure action EEM?
9 Replies 9
Joe Clarke
The leading '.' is a product of SNMP tools like HPOV and net-snmp.  It is not part of the spec, and SNMP Research's stack doesn't use them.  Leave out the leading '.' and it will work.
Sergey Kostenko
Frequent Visitor
Frequent Visitor
I removed leading "."and action worked partially. Work but slowly. Result syslog:
000153: Apr 16 06:15:22.882: %HA_EM-7-FMFD_SNMP_RESP_TIMEOUT: fh_fd_do_snmp_request_remote: SNMP response has timed out
Does it sometimes work and sometimes timeout, or does it always timeout?
Given you're using a remote SNMP operation, you should check your SNMP ACLs to make sure the source address of the router is allowed to make an SNMP Set.
This action work with timeout always. Snmp config on sourse C2811:
snmp-server manager
snmp-server enable traps event-manager
snmp-server host 10.1.101.22 public  event-manager
event manager applet Test2
 event none
 action 10.0 info type snmp oid 1.3.6.1.2.1.1.4.0 set-type string [email protected] community SWITCH ipaddr 10.1.101.21
I try other action and work w/timeout:
 event none
 action 10.0 info type snmp oid 1.3.6.1.4.1.25728.8900.1.1.13.3 set-type int 1 community SWITCH ipaddr 10.1.101.21
Destination device support snmp v1 only. May be it's reason timeoutes?
I believe the SNMP operations are going to use v2c to support larger objects.  There is no way to control version from EEM, but you can try executing this EXEC-level command:
snmp set v1 10.1.101.21 SWITCH oid 1.3.6.1.2.1.1.4.0 string [email protected]
How can I execute this command ("snmp set v1 10.1.101.21 SWITCH oid 1.3.6.1.2.1.1.4.0 string [email protected]")?
C2811#snmp set ?
% Unrecognized command
C2811#snmp ?
C2811#snmp
I do not understand...
This is a hidden command.  you can't use '?'.  You'll need to type it all out and trust it will work.
Hi. I try execute command and result below:
C2811>en
Password:
C2811#snmp set v1 10.1.101.21 SWITCH oid 1.3.6.1.2.1.1.4.0 string [email protected]
Timeout
C2811#
Than I turn on debug snmp packets...
C2811#debug snmp packets
Timeout
C2811#sh logg
000186: Apr 24 07:01:11.005: SNMP: Set request, reqid 7, errstat 0, erridx 0
 system.4.0 = [email protected]
000187: Apr 24 07:01:11.013: SNMP: Packet sent via UDP to 10.1.101.21.161
000188: Apr 24 07:01:11.021: SNMP: Packet received via UDP from 10.1.101.21 on BVI1
000189: Apr 24 07:01:21.013: SNMP: Set request, reqid 8, errstat 0, erridx 0
000190: Apr 24 07:01:21.021: SNMP: Packet sent via UDP to 10.1.101.21.161
000191: Apr 24 07:01:21.029: SNMP: Packet received via UDP from 10.1.101.21 on BVI1
000192: Apr 24 07:01:41.021: SNMP: Set request, reqid 9, errstat 0, erridx 0
000193: Apr 24 07:01:41.029: SNMP: Packet sent via UDP to 10.1.101.21.161
000194: Apr 24 07:01:41.037: SNMP: Packet received via UDP from 10.1.101.21 on BVI1
Oid has been set to "[email protected]" but after timeout. How execute command without timeouts? It's possable?
You can increase the timeout and retries keywords after the community string:
snmp set v1 10.1.101.21 SWITCH timeout 10 retry 1 oid 1.3.6.1.2.1.1.4.0 string [email protected]
But a bigger question is why does the device accept the change without sending a SET RESPONSE in a timely manner?
