eem script with pipe
paul amaral
Level 7
Level 7
Hoping someone can help me here as i been unable to figure this out.
I have a command "sh ip cache flow | in 0000" that I need to append to a file on flash.
However when i use action 1.6 cli command "sh ip cache flow | in 0000 | append disk0:/rxload.txt" it does not work because of the extra pipe. I was thinking of using $_cli_result but cant figure out how to append that to the file.
TIA, Paul
Seb Rupik
Hi there,
I have only tested this on GNS3 (where it is not working)...but try the following:
event manager applet TEST
 event none
 action 1.0 cli command "sh ip int | inc packets"
 action 1.5 file open fh disk0:/test.txt w
 action 1.6 file write fh "$_cli_result"
 action 1.7 file close fh
...reading the EEM4.0 docs, there is no mention of whether action file write appends to an existing file or not....hopefully it does.
cheers,
Seb.
that did not work, anyone know how to pass a | in a EEM script.
Paul
