EEM scripting assistance: Switch, router and AP CDP
Leo Laohoo
We would like to create an EEM script which will let the switch populate the interface description based on the CDP neighbour, however, we want the script to only populate the interface if (and only if) the CDP is a Cisco wireless access point (AP), a Cisco Catalyst switch and a Cisco router.   We DO NOT want the interface description to be edited if the CDP neighbour is a Cisco phone or a Cisco DMP (for example).
This is our EEM script:
event manager applet update-port
event none
event neighbor-discovery interface regexp GigabitEthernet.* cdp add
action 100 if $_nd_cdp_capabilities_string eq "Router" goto 200
action 110 elseif $_nd_cdp_capabilities_string eq "Switch" goto 200
action 120 if $_nd_cdp_capabilities_string eq "Switch" goto 200
action 200 cli command "enable"
action 210 cli command "config t"
action 220 cli command "interface $_nd_local_intf_name"
action 230 cli command "description $_nd_cdp_entry_name"
action 400 else
action 500 end
And this is a sample of our “sh cdp neighbor” output:
Switch#sh cdp n d
Device ID: Wireless
Entry address(es):
  IP address: <REMOVED>
Platform: cisco AIR-CAP3602I-N-K9   ,  Capabilities: Router Trans-Bridge
Interface: GigabitEthernet0/8,  Port ID (outgoing port): GigabitEthernet0.1
Holdtime : 146 sec
Version :
Cisco IOS Software, C3600 Software (AP3G2-K9W8-M), Version 15.2(2)JB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 10-Dec-12 23:52 by prod_rel_team
advertisement version: 2
Duplex: full
Power drawn: 15.400 Watts
Power request id: 19701, Power management id: 2
Power request levels are:15400 0 0 0 0
Power Available TLV:
    Power request id: 0, Power management id: 0, Power available: 0, Power management level: 0
Management address(es):
Device ID: 00:0f:44:02:c5:29
Entry address(es):
Platform: Cisco DMP 4310G,  Capabilities: Host
Interface: GigabitEthernet0/3,  Port ID (outgoing port): eth0
Holdtime : 157 sec
Version :
5.4
Duplex: full
Device ID: CALM040.mgmt.educ
Entry address(es):
Platform: cisco WS-C3750E-24PD,  Capabilities: Switch IGMP
Interface: GigabitEthernet0/10,  Port ID (outgoing port): GigabitEthernet1/0/22
Holdtime : 126 sec
Version :
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.0(2)SE, RELEASE SOFTWARE (fc1)
Compiled Fri 27-Jul-12 23:26 by prod_rel_team
Protocol Hello:  OUI=0x00000C, Protocol ID=0x0112; payload len=27, value=00000000FFFFFFFF010221FF0000000000000023AC075300FF0000
VTP Management Domain: 'ACTEducation'
Native VLAN: 99
Duplex: full
    Power request id: 0, Power management id: 1, Power available: 0, Power management level: -1
Device ID: 00:0f:44:02:b6:31
Entry address(es):
Interface: GigabitEthernet0/2,  Port ID (outgoing port): eth0
Holdtime : 169 sec
Version :
5.4
Duplex: full
Best Regards/Leo
3 Accepted Solutions
Joe Clarke
You use regexp to do what you want:
action 100 regexp "(Switch|Router)" $_nd_cdp_capabilities_string
action 110 if $_regexp_result eq 1
action 500 end
This would only set the port description if the capabilities string contains the words Router or Switch.
You can still use regexp for this:
action 221 regexp "^([^\.])\." $_nd_cdp_entry_name match host
action 230 cli command "description $host"
Sorry, I forgot a '+':
action 230 regexp "^([^\.]+)\." $_nd_cdp_entry_name match host
6 Replies 6
Joe Clarke
action 500 end
Thanks Joe.   This works very, very well.
Can I ask for another "tweak"?
In the CDP, we get the domain extension like "Switch.Domain".  How do I concatinate the ".Domain"-bit so I will only get "Switch"?
Hi Joe,
So the EEM is going to look like this:
action 230 regexp "^([^\.])\." $_nd_cdp_entry_name match host
action 240 cli command "description $host"
action 500 end
Is this correct?
THANKS JOE!
