Difference between custom and standard discovery in LMS 4.2
Wolfgang Maier
can someone explain me whats the difference betwwen custom and standard discovery? There´s a line on the help page:
"The Use Policy Configuration Settings  radio button will be enabled only after adding a Default Credential Set  Policy."
The radio button is not enabled although I´ve  two default credential sets and two default credential sets policy configuration.
This is very confusing. Can someone explain the difference? Thank you.
Chris
tperrier
Level 4
Level 4
This question is old and not answered, but turns up first in a Google search for "lms standard discovery". Since I had the same question, I'll try to answer.
The standard discovery is a simplified (but good enough in my case) discovery with fewer configuration options. The discovery modules used, not configurable, are CDP/LLDP, routing table and ARP. If you need to use the OSPF, ping sweep, etc., modules, apply filters, or other fine tuning, then choose the custom discovery instead.
