How to run the TCL script/EEM applet on C3750 after bootup into defaults?
Leo Gal
Hi gents,
Subject tells it all more less
I have a Cat3750, which, after erase nvram and reload will boot into defaults and
I would like to give him configuration (run the script)
And I was thinking about triggering (how?) the script based on...something after bootup.
Can someone give me a hint please?
Leo
mtimm
If the system is back at default, it won't have an eem policy registered.  One option might be a feature that has been in IOS for ages that can auto download configurations from the network:
http://www.cisco.com/en/US/docs/ios/12_1/configfun/command/reference/frd2002.html#wp1017913
This would have nothing to do with EEM though.
Mike
Hi Mike
thanks for replying.
But that would need again a configuration command...wouldn't it?
Leo
mtimm
If you do a write erase and reload without doing a write memory (copy run start) the system will not have a configuration which cause this feature to default to on per:
Defaults
Disabled, except on systems without NVRAM or with invalid or incomplete information in NVRAM. In these cases, autoloading of configuration files from a network server is enabled automatically.
Mike
