EEM: Search Index from file flash
Mario C. G.
Hi Team,
I trying make an EEM applet for delete one file from my flash if this is reach some limit.
I search the OID and this work fine, but if I reload my router this OID change (the last index of the file).
For this reason, I like first search this OID for this File in the flash and after this delete my file.
Given this output:
Directory of flash0:/c1900-universalk9-mz.SPA.156-2.T.bin
  250  -rw-    81042792  Apr 20 2016 16:34:56 -04:00  c1900-universalk9-mz.SPA.156-2.T.bin
I would use:
regexp " +[0-9]+ +-rw- +([0-9]+).*c1900-universalk9-mz.SPA.156-2.T.bin" $_cli_result match size
And the $size variable would give me the size for the c1900-universalk9-mz.SPA.156-2.T.bin file.
Joe Clarke
CLI would work better for this since you can parse the output of "dir" and simply delete the file you want by name.
Hi Joe,
I am trying many times to get tu size file from this output but I can't.
You know how I can get the file size from dir flash command?
I need check the file size before delete this
Thank you for your time and help, have a nice day!!!!!
Given this output:
I would use:
Hi Joe,
You are a Master. Your answer resolved my issue
GW-LAB-3900#dir flash:SRST.txt
Directory of flash0:/SRST.txt
  461  -rw-         192   Jun 8 2017 14:16:42 -05:00  SRST.txt
261222400 bytes total (149004288 bytes free)
GW-LAB-3900#event manager run TEST
192
Thanks a lot for:
Your help
Monitor and respond.
Your Time
