EEM / Tcl Script Help Please
Hello Community,
I have been evaluating a Tcl Script posted here sometime ago, designed to help monitor track interfaces and routes, see attached.
I believe I have applied the configurations correctly, however when I test the script by shutting down interfaces nothing happens.
I'm sure its something very simple that I'm missing.
I wonder if someone could take a look at the configs and let me know what I'm doing wrong. I have also attached a diagram.
Cheers
Carlton
10 Replies 10
Joe Clarke
Keep reading the help text the author wrote in is Tcl policy.  You didn't configure any of the NOTIFY-foo applets he talks about there.  Those are the things that actually do the notifications.
Joseph,
I did read again and I got it to work :-)
Cheers
On a slightly different topic, is it possible to 'track' a static ip address?
For example, I have the following tracking configured:
track 1 ip route 0.0.0.0 0.0.0.0 reachability
track 2 interface FastEthernet0/0 ip routing
track 3 interface FastEthernet0/1 ip routing
track 4 ip route 180.80.8.4 255.255.255.255 reachability
track 5 ip route 170.70.7.4 255.255.255.255 reachability
R3#show track brie
Track   Object                         Parameter        Value
1       ip route  0.0.0.0/0            reachability     Up (static)
2       interface FastEthernet0/0      ip routing       Up
3       interface FastEthernet0/1      ip routing       Up
4       ip route  180.80.8.4/32        reachability     Down (no route)
5       ip route  170.70.7.4/32        reachability     Down (no route)
However, you will see that track 4 and 5 are down. This is because, although I can ping 180.80.8.4 and 170.70.7.4 the actual ip addresses don't appear in the routing table:
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
     170.70.0.0/24 is subnetted, 1 subnets
C       170.70.7.0 is directly connected, FastEthernet0/0
     10.0.0.0/24 is subnetted, 1 subnets
C       10.1.1.0 is directly connected, FastEthernet1/0
     180.80.0.0/24 is subnetted, 1 subnets
C       180.80.8.0 is directly connected, FastEthernet0/1
     150.50.0.0/24 is subnetted, 1 subnets
C       150.50.5.0 is directly connected, Ethernet2/0
S*   0.0.0.0/0 is directly connected, FastEthernet1/0
R3#
Therefore, is there way of creating a track for /32 ip addresses?
I hope that makes sense.
Cheers
You can use IP SLA to ping the hosts and track the state of the IP SLA operation.
ip sla 1
icmp-echo 170.70.7.4
ip sla schedule 1 start now life forever
track 1 ip sla 1 reachability
Hi Joseph,
Thanks for responding.
That does seem like an ideal solution.
Can you let me know what version allows me to
track 1 ip sla 1 reachability?
At the moment, I only have the following option
R3(config)#track 4 ip ?
  route  IP route
Cheers
Hi Joseph,
I managed to configure ip sla with old method - using rtr.
Everything is working fine:
R3#show track brie
4       rtr       1                    reachability     Down
R3#
The problem I'm having is that the script doesn't recognise track 4. As you can see track 4 shows 'Down', but the script still thinks everything is up and working.
Any thoughts?
Cheers mate.
From what I can tell this script doesn't discriminate from the track types.  It should see track 4 and recognize it is down.  Provided you have conditions and other applets setup accordingly the script should work.  But since this isn't my work, I cannot say for certain.
Hi Joesph,
I totally agree.
I think I have the necessary applets.
Ive attached the script - just in case you might want to check it outl
Hi Joseph,
I figured it out. However, would you happen to know how to add another track to the script?
At the moment, the script is written for three occurences. I would like to add more.
Cheers
To me it looks like the script would work with any number of tracks provided you use the right $X variable to represent the track value (e.g., $4).
Brilliant. I will try it tomorrow
Cheers mate
