EEM-TCL Script to switch config from interface X to interface Y
Hello Guys,
I’m trying to create a script which is controlled by an EEM-UPDOWN event of an interface. What I’m trying to do is, if interface X is down for some reason it should copy the interface configuration to interface Y.
So my problem is I’m very new to eem-tcl scripting and I have some basic problem hopefully u can help me =) I’m working on a ASR9K !
So what i have done so fare:
::cisco::eem::event_register_syslog occurs 1 pattern ".*CHANGED.*$_sat_1_link_1.*" maxrun 90
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
array set arr_einfo [event_reqinfo]
if {$_cerrno != 0} {
    set result [format "component=%s; subsys err=%s; posix err=%s;\n%s" \
      $_cerr_sub_num $_cerr_sub_err $_cerr_posix_err $_cerr_str]
    error $result
if [catch {cli_open} result] {
    error $result $errorInfo
} else {
    array set cli1 $result
action_syslog priority emergencies msg "start script testv1_1"
#puts "\nEXECUTE CLI COMAND :\n"
set out {cli_exec $cli1(fd) "show running-config formal interface $_sat_1_link_1"}
set xout [split $out \n]
#puts "DEBUG : $xout \n\n"
set anz [llength $xout]
#puts "DEBUG : count rows = $anz \n\n"
for {set ii "0"}  {$ii < $anz } {incr ii} {
       set indexout [lindex $out $ii]
    regexp  {([\w]+)[ ]([\w\d/]+)\s(.*)} $indexout a b c d
    #puts "\nDEBUG START"
    #puts "\nindex Nr  $ii"
    #puts "Full Match: $a"
    #puts "Sub Match1: $b"
    #puts "Sub Match2: $c"
    #puts "Sub Match3: $d"
    #puts "DEBUG END\n"
    set intsrc {cli_exec $cli1(fd) "no $b $_sat_1_link_1 $d"}
    set intdest {cli_exec $cli1(fd) "$b $_sat_1_link_2 $d"}
if [catch {cli_exec $cli1(fd) "commit"} result] {
if [catch {cli_exec $cli1(fd) "end"} result] {
action_syslog priority emergencies msg "End script testv1_1"
ps. $_sat_1_link_1 and $_sat_1_link_2 are globaly set per cli in the event manager env.
Thanks for your help and hopefully u can help me with this script
What about this:
set output [cli_exec $cli(fd) "show run interface $ointf"]
cli_exec $cli(fd) "config t"
cli_exec $cli(fd) "default int $intf"
cli_exec $cli(fd) "int $intf"
foreach line [split $output "\n"] {
    if { [regexp {^ } $line] } {
        cli_exec $cli(fd) $line
cli_exec $cli(fd) "commit"
cli_exec $cli(fd) "end"
Joe Clarke
What problem are you having and what is the output of the various CLI commands?
Hey
after show running-config formal interface TenGigE 0/0/2/1 the cli output example is :
interface TenGigE0/0/2/1 description Test: 0-43
interface TenGigE0/0/2/1 shutdown
and now i want to split the config with my regex
As example line 1
set x= "TenGigE0/0/2/2"                  --> =dest_interface
a= interface TenGigE0/0/2/1 description Test: 0-43
b= interface
c= TenGigE0/0/2/1
d= description Test: 0-43
do this
cli_exec $cli1(fd) "no $b $c $d"      --->no interface TenGig E0/0/2/1 description Test: 0-43
cli_exec $cli1(fd) " $b $x $d"          ---> interface TenGigE0/0/2/2 description Test: 0-43
and from this point it shoud do this until there are no config lines  =)
as a final result is should copy the whole config from interface X to interface Y  if the trigger is active
but as i see, the main problem is to get the CLI output in a format like this
set xy = interface TenGigE0/0/2/1 description Test: 0-43\ninterface TenGigE0/0/2/1\ninterface TenGigE0/0/2/1 shutdown
or in an index like this:
Index | command
1         interface TenGigE0/0/2/1 description Test: 0-43
2         interface TenGigE0/0/2/1
3         interface TenGigE0/0/2/1 shutdown
Thx
What about this:
Thank for your much simpler solution of the script !
