EEM to save configuration
nvanhaute
hi all,
I'm trying to make an EEM script to backup my ISR conf .
It's ok but I need a bit more : I would like to keep history of my conf files so I need to have a different filename each time I save it
I'm ok if it's possible with date or an increment value
I know I can do that with "archive" but I need to do it also with EEM if possible because I need to save in different locations each time.
Niko
PS : I use ISR 3825 IOS 12.4(24)T
Maria Palmero Amador
you can have a look at the
http://forums.cisco.com/eforum/servlet/EEM?page=eem&fn=script&scriptId=1103
Archive Config EEM policy,
I hope this will help you,
Marisol
