EIGRP AND DHCP
Sanjay916
Hello, I am trying to solve this network. I have 3 routers which is R0, R1, and R2, and 3 switches and 3 PC. R1 one is hosting a dhcp that is giving ip address to all 3 PC. The routing protocol that I am using is eigrp. I cannot get my 3rd  PCto acquire an ip address from the dhcp. I am not sure what I am doing wrong. This is my config script. Also I included an screenshot of the network Topology. Please Help me thanks.
ROUTER0
G0/0:195.165.85.9 255.255.255.252
G0/1:195.165.85.158 255.255.255.224
ROUTER1
G0/0:195.165.85.10 255.255.255.252
G0/1: 195.165.85.13 255.255.255.252
G0/2: 195.165.85.190 255.255.255.224
G0/2: ip helper-address 195.165.85.158
ROUTER2
G0/0:195.165.85.14 255.255.255.252
G0/1: 195.165.85.222 255.255.255.224
G0/1: ip helper-address 195.165.85.158
EIGRP 100 CONFIG
ROUTER0
Router eigrp 100
network 195.165.85.128 0.0.0.31
network 195.165.85.8 0.0.0.3
ROUTER1
Router eigrp 100
network 195.165.85.160 0.0.0.31
network 195.165.85.12 0.0.0.3
ROUTER2
Router eigrp 100
network 195.165.85.192 0.0.0.31
ROUTER0 DHCP CONFIG
ip dhcp pool net128
network 195.165.85.128 255.255.255.224
default-router 195.165.85.158
ip dhcp pool net160
network 195.165.85.160 255.255.255.224
default-router 195.165.85.190
ip dhcp pool net192
network 195.165.85.192 255.255.255.224
default-router 195.165.85.222
ip dhcp excluded-address 195.165.85.158
ip dhcp excluded-address 195.165.85.190
ip dhcp excluded-address 195.165.85.222
Saludos compañero, podrias falicitarme un diagrama o verificar si en los SW tienes configurado el Ip default Gateway ejecuta un ping desde el Sw donde esta conectada la pc al Routre cero.
Recuerda hacer click en la estrella, para seguir fortaleciendo la comunidad
