EIGRP Key Rotation - Expired keys
douglas.mckee
Good afternoon,
What's the best way to replace/update expired EIGRP keys without losing neighbor relationships?  We currently have "EIGRP DMVPN" and EIGRP LAN key authentication as listed below.
key chain EIGRP_KEYCHAIN
key 9997
key-string 7 XXXXXXXXXXXXXXXXXXXXXXXXXXX
accept-lifetime 23:55:00 Jun 30 2021 00:05:00 Jan 1 2022
send-lifetime 23:55:00 Jun 30 2021 00:05:00 Jan 1 2022
cryptographic-algorithm hmac-sha-256
key 9998
key-string 7 XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
accept-lifetime 23:55:00 Dec 31 2021 00:05:00 Jul 1 2022
send-lifetime 23:55:00 Dec 31 2021 00:05:00 Jul 1 2022
key 9999
accept-lifetime 23:55:00 Jun 30 2021 infinite
send-lifetime 23:55:00 Jun 30 2021 infinite
key chain OSPF_KEYCHAIN
key 9997
key-string 7 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
key 9998
key 9999
key-string 7 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXx
key chain TEST
key 1
key-string 7 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXx
accept-lifetime 00:00:00 Jan 1 2020 00:05:00 Jul 1 2020
password encryption aes
router eigrp DMVPN
address-family ipv4 unicast autonomous-system 10
af-interface default
passive-interface
exit-af-interface
af-interface Tunnel100
authentication mode hmac-sha-256 7 XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
authentication key-chain EIGRP_KEYCHAIN
no passive-interface
no split-horizon
exit-af-interface
topology base
redistribute eigrp 5
exit-af-topology
network XX.X.XX.X.0.0.0
network XX.X.XX.X 0.0.0.0
exit-address-family
router eigrp LAN
address-family ipv4 unicast autonomous-system 5
passive-interface
exit-af-interface
af-interface GigabitEthernet1/0/0
exit-af-interface
af-interface GigabitEthernet1/0/1
authentication mode hmac-sha-256 7 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
exit-af-interface
af-interface Tunnel300
authentication mode hmac-sha-256 7 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
exit-af-interface
topology base
redistribute eigrp 10
redistribute static
exit-af-topology
Thank you,
Doug
A couple things to note as I don't know your level or familiarity.
1. When using MD5 you can do key rotation. When using HMAC-SHA-256 under the af-interface there is no key rotation. So you will only be able to apply it to the MD5 configured interfaces.
2. When sending key chains the network device will send the lowest active key configured but the remote device can match it against any active key on the other side. So if Router A sends a key with a value of 2 (lowest active key it has), the it can match against any active key Router B has (active meaning lifetime is still valid). Its good you have higher numbers configured to you can just keep moving down the list of key numbers as rotations happen.
That being said it looks like those keys have all expired. When you configure new keys you will lose the EIGRP neighbor ship. Even if you are able to make the changes on both devices in a quick manner it will still bring it down and re-establish. If one router is remote I would make the changes on that (with a "reload in" command as a backup plan) and then make changes on the local router to complete the configuration. I would also suggest a maintenance window to do this as like I said it will bring it down.
Not sure what your timeline is but you can have them overlap for 24 hours so you have time to troubleshoot in case anything goes wrong. You can look at the EIGRP debug packets to see what key each device is sending. If its not correct you will have tome to fix it.
Hope that helps
-David
Hope that helps
-David
douglas.mckee
David,
Appreciate the quick response. It sounds like the best way to proceed is configuring between 2 connected EIGRP routers and ensuring everything is operational prior to proceeding. I was tempted just to test on one set of routers and send out to the remaining routers through DNAC but sounds like it would be a major problem since connectivity is temporarily lost as you mentioned.
Thank you,
Doug
