Embedded Event manager scripting help
MarekVanco_2
Community Member
I'm looking into a way to do the following:
If pinging of BGP peer detects packet loss, or circuit flapping, lets say 5 flaps in 60 secs, then I'd like the bgp peering to go into admin down state.
Would be nice if it also recovered on its own when 1hour or X of stability was detected.
Thank you
MarekVanco_2
Community Member
I found a good doc and think i'll be going with this:
IP SLA 3
   icmp-echo X.X.X.X  source-interface GIGXXXX
IP SLA schedule  3 life forever  start-time now
track 3 ip sla 3  reachability
delay up XX
event manager applet  WAN_DOWN
event track 3 state  down
action 1.0 syslog msg "Packet loss  or Primary WAN cct loss detected"
action 2.0 cli command  "enable"
action 3.0 cli command "config  t"
action 4.0 cli command "router bgp XXXXX"
action 5.0 cli command "neighbor X.X.X.X shut"
action 6.0 cli command  "end"
action 7.0 syslog msg "BGP neighbor  placed in Admin Down because of packet loss to  Peer"
event managet applet  wan_up
event track 3 state  up
action 1.0 syslog msg "WAN network  restored"
action 5.0 cli command "no neighbor  x.x.x.x shut"
action 7.0 syslog msg "BGP neighbor  was brought up due to sustained comm with Peer"
so now I ahve issues trying to get the "delay up" to 10-30 minutes like i'd like... max is 180seconds
You will not be able to use delay up here.  What you can do is have the "up" policy configure a third policy to wait the specified amount of time.  Then modify the down policy to unconfigure that third policy.  For example:
  action 5.1 cli command "no event manager applet WAN_HOLD_DOWN_UP"
event manager environment q "
event manager applet WAN_UP
action 1.0 cli command "enable"
action 2.0 cli command "config t"
action 3.0 cli command "event manager applet WAN_HOLD_DOWN_UP"
action 3.1 cli command "event timer countdown time 1800"
action 3.2 cli command "action 1.0 syslog msg $q WAN network  restored$q"
action 3.3 cli command "action 2.0 cli command $q enable$q"
action 3.4 cli command "action 3.0 cli command $q config  t$q"
action 3.5 cli command "action 4.0 cli command $q router bgp XXXXX $q"
action 3.6 cli command "action 5.0 cli command $q no neighbor  x.x.x.x shut$q"
action 3.7 cli command "action 6.0 cli command  $q end$q"
action 3.8 cli command "action 7.0 syslog msg $q BGP neighbor was brought up due to sustained comm with Peer$q"
action 4.0 cli command "end"
