Empty syslog message when filtering with ESM
ealeatherman
Level 4
Level 4
I am attempting to out syslog messages using ESM. I found a tcl script in an older post and modified it slightly:
if { [string length $::orig_msg] == 0 } {
    return ""
set msgs [list {LINK-3-UPDOWN} {PROTO-5-UPDOWN}]
set fac_sev_mnem "${::facility}-${::severity}-${::mnemonic}"
foreach msg $msgs {
    if { $msg == $fac_sev_mnem } {
    return ""
return $::orig_msg
I'm testing this using a catalyst 3750 running 12.2.44SE5.
It's working except, when it matches a message instead of dropping it completely it sends a blank message to syslog, buffer, etc. It seems like a very simple script, I'm not sure where to go from here.
Thanks in advance!
Ed
You can use this script as a workaround.
    return ""
foreach msg $msgs {
    return ""
set first_char [string range $::orig_msg 0 0]
if { [string compare $first_char "\n"] == 0 } {
    set new_string [string range $::orig_msg 1 end]
    return $new_string
} else {
    return $::orig_msg
Joe Clarke
I think I see what you're seeing, but I don't think it's the filtered messages that generate the newlines.  I think you're seeing all non-filtered messages followed by an extra newline.  For example:
Sep 28 21:46:04: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/23, changed state to up
Sep 28 21:46:17: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/23, changed state to down
Sep 28 21:46:22: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/23, changed state to up
Sep 28 21:48:15: %SYS-5-CONFIG_I: Configured from console by cse on vty3 (172.18.123.93)
Sep 28 21:48:25: %SYS-5-CONFIG_I: Configured from console by cse on vty3 (172.18.123.93)
If so, then this is bug CSCsu74220, which is not yet fixed on the Cat3K line.
    return ""
foreach msg $msgs {
    return ""
    return $new_string
} else {
    return $::orig_msg
Joseph, that did the trick. Thanks A LOT!
Ed
