IP SLA UDP-ECHO socket error
jschweng
Level 4
Level 4
have this configuration on ASR1002F router. Trying to setup IP Sla so that we can monitor the delay on WAN interfaces. Would like to send UDP-ECHO from one router to another across the WAN.   I need to send and receive on fixed port numbers. Keep getting socket errors.  any ideas on what i need to do?
no ip sla 5
ip sla 5
udp-echo <dest ip> 65000 source-port 65000 control disable
frequency 5
ip sla schedule 5 life forever start-time now
exit
yjdabear
Was there a "source-ip xx.xx.xx.xx" portion on the "udp-echo 65000 source-port 65000 control disable" line?
