Enable snmp traps
romanroma
Level 4
Level 4
I am a little confused and need to make sure I have my switches configured correctly before I speak with the folks who manage the SNMP server resources. I am following documentation
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/network_management/configuration_guide/b_nm_15ex_2960-x_cg/b_nm_15ex_2960-x_cg_chapter_0100.html#task_7B4609ACB50F4DCA877A911711E3E395
To enable traps on a 2960x the following is all that is required (what I currently have)?
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps errdisable
snmp-server host 192.168.20.5 version 3 auth ciscotraps
or do I need
snmp-server host 192.168.20.5 version 3 auth ciscotraps snmp
snmp-server host 192.168.20.5 version 3 auth ciscotraps  errdisable
Just not sure if the switch is not configured fully yet or if something is wrong with the server that will send out an email once the traps are received.
Also,
I read about the difference between "Informs" vs "trap' and how Informs respond with an ACK. Other then the response, is there any benefit in using 'informs' over 'traps'?
Thank you
snmp [authentication ]--Sends RFC 1157 SNMP notifications. Using the authentication keyword produces the same effect as not using it. Both the snmp-server enable traps snmp and the snmp-server enable traps snmp authentication forms of this command globally enable the following SNMP notifications (or, if you are using the no form of the command, disables such notifications): authenticationFailure , linkUp , linkDown , and warmstart .
The snmp-server enable traps command is used in conjunction with the snmp-server host command. Use the snmp-server host command to specify which host or hosts receive SNMP notifications. To send notifications, you must configure at least one snmp-server host command.
BB
balaji.bandi
If you like to send only those traps then that is the correct one.
you can find information Trap vs Informs (based on the requirement)
http://www.net-snmp.org/tutorial/tutorial-5/commands/snmptrap-v3.html
BB
@balaji.bandi
This worked great thank you. However, looks like messages are not sent encrypted, even though I have 'group' and authentication set, so I might have to look at other issues there.
Why the two different methods on configuration?
(vs)
BB
