enabling netflow in cisco 2960 and 4948 switches
donnie
Hi all,
I am unable to input the command "ip flow-cache timeout active 1" to my cisco 2960 and 4948 switches. But i am able to do so in my cisco 6500 series switch. Hence how do i enable netflow on both 2960 and 4948 devices?
My 2960 and 4948 are L3 switches. Pls advise what commands or additional hardware module are required. Thks in advance.
5 Replies 5
Both switches don't support Netflow as of the feature-navigator. So probably you're out of luck with that.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Joshua Falso
The 2960 is layer 2 so it won't do netflow. The 4948 does not support it. I had tried to configure it on a 3560 and although it took my commands netflow would not work. I instead had to use my asa 5520.
Sent from Cisco Technical Support Android App
V/r Josh
Is Netflow via SNMP an option on switches?
According to this Cisco doc, it appears possible.
http://www.cisco.com/en/US/docs/ios-xml/ios/netflow/configuration/12-4t/nf-12-4t-book.pdf
Frank
Neither the Catalyst 2960 nor the 4948 will provide Netflow data. Please see manageengines' site for a good summary of which Cisco devices provide Netflow data.
Seems like depending of the IOS, a 2960 switch is able to report NetFlow.
