end to end connection between devices
nampindimatheus
i have configured my devicess as follows but the server can not ping the last switch in line
it can only ping up until multi L switch 3
someone please help me out
post your zipped Packet Tracer project (.pkt) file...
Martin L
You can attach PT file here but it must be in z zip format
often vlans are missing from database in case of L3 switches; those as well as any L2 switches will need vlans entered into database.  What is vlan for server (what is vlan server sits on)? that vlan x must be on L3 swithces.
Also, check default gateway settings on end device to match correct L3 IP address and subnet.
Regards, ML
**Please Rate All Helpful Responses **
