04-04-2011 05:50 AM
I try to create an energywise lab using some switches and IP phones. Orchestrator, proxy and ActiveMQ are installed on a single machine. Orchestrator web works OK. I have a problem with the communication betweeen core switch and the energywise proxy.
The proxy log says the subsequent info:
[04/04/11 02:33:49.948 PM CEST] INFO [tzScheduler_Worker-6] ergywise.EnergywiseDomainManager: Polling EnergyWise domain: techdepart.ttc-marconi.cz{svr=10.22.255.1 key=7c9dac7ddea0d8d1496617113d1c6983ac79493}
[04/04/11 02:33:49.948 PM CEST] INFO [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Collect query for NAME, ROLE, KEYWORDS, DEVICE_TYPE, IMPORTANCE, LEVEL on domain techdepart.ttc-marconi.cz
[04/04/11 02:33:49.948 PM CEST] INFO [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Executing collect query on domain techdepart.ttc-marconi.cz
[04/04/11 02:33:50.965 PM CEST] ERROR [tzScheduler_Worker-6] cisco.CiscoEnergywiseLog: ew_init_socket: Socket connect failed -1, error = 10061(Unknown error)
[04/04/11 02:33:50.965 PM CEST] ERROR [tzScheduler_Worker-6] cisco.CiscoEnergywiseLog: energywise_execQuery: Error connecting to host, query failed.
[04/04/11 02:33:50.965 PM CEST] ERROR [tzScheduler_Worker-6] cisco.CiscoEnergywiseLog: energywise_queryResults: Query failed to execute, no results available.
[04/04/11 02:33:50.965 PM CEST] INFO [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Completed collect query on domain techdepart.ttc-marconi.cz
[04/04/11 02:33:50.965 PM CEST] WARN [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Query result set came back null, likely could not connect to domain server
[04/04/11 02:33:50.980 PM CEST] INFO [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Collect query for USAGE, UNITS, USAGE_CALIBER, USAGE_VECTOR, DELTA_VECTOR on domain techdepart.ttc-marconi.cz
[04/04/11 02:34:00.989 PM CEST] INFO [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Executing collect query on domain techdepart.ttc-marconi.cz
[04/04/11 02:34:02.037 PM CEST] ERROR [tzScheduler_Worker-6] cisco.CiscoEnergywiseLog: ew_init_socket: Socket connect failed -1, error = 10061(Unknown error)
[04/04/11 02:34:02.052 PM CEST] ERROR [tzScheduler_Worker-6] cisco.CiscoEnergywiseLog: energywise_execQuery: Error connecting to host, query failed.
[04/04/11 02:34:02.052 PM CEST] ERROR [tzScheduler_Worker-6] cisco.CiscoEnergywiseLog: energywise_queryResults: Query failed to execute, no results available.
[04/04/11 02:34:02.052 PM CEST] INFO [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Completed collect query on domain techdepart.ttc-marconi.cz
[04/04/11 02:34:02.052 PM CEST] WARN [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Query result set came back null, likely could not connect to domain server
[04/04/11 02:34:02.052 PM CEST] INFO [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Collect query for RECURRENCE on domain techdepart.ttc-marconi.cz
[04/04/11 02:34:12.061 PM CEST] INFO [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Executing collect query on domain techdepart.ttc-marconi.cz
[04/04/11 02:34:13.015 PM CEST] ERROR [tzScheduler_Worker-6] cisco.CiscoEnergywiseLog: ew_init_socket: Socket connect failed -1, error = 10061(Unknown error)
[04/04/11 02:34:13.015 PM CEST] ERROR [tzScheduler_Worker-6] cisco.CiscoEnergywiseLog: energywise_execQuery: Error connecting to host, query failed.
[04/04/11 02:34:13.015 PM CEST] ERROR [tzScheduler_Worker-6] cisco.CiscoEnergywiseLog: energywise_queryResults: Query failed to execute, no results available.
[04/04/11 02:34:13.015 PM CEST] INFO [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Completed collect query on domain techdepart.ttc-marconi.cz
[04/04/11 02:34:13.015 PM CEST] WARN [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Query result set came back null, likely could not connect to domain server
[04/04/11 02:34:13.015 PM CEST] INFO [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Collect query for NAME, ROLE, KEYWORDS, DEVICE_TYPE, IMPORTANCE, LEVEL on domain techdepart.ttc-marconi.cz
[04/04/11 02:34:23.039 PM CEST] INFO [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Executing collect query on domain techdepart.ttc-marconi.cz
[04/04/11 02:34:24.087 PM CEST] ERROR [tzScheduler_Worker-6] cisco.CiscoEnergywiseLog: ew_init_socket: Socket connect failed -1, error = 10061(Unknown error)
[04/04/11 02:34:24.087 PM CEST] ERROR [tzScheduler_Worker-6] cisco.CiscoEnergywiseLog: energywise_execQuery: Error connecting to host, query failed.
[04/04/11 02:34:24.087 PM CEST] ERROR [tzScheduler_Worker-6] cisco.CiscoEnergywiseLog: energywise_queryResults: Query failed to execute, no results available.
[04/04/11 02:34:24.087 PM CEST] INFO [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Completed collect query on domain techdepart.ttc-marconi.cz
[04/04/11 02:34:24.087 PM CEST] WARN [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Query result set came back null, likely could not connect to domain server
[04/04/11 02:34:24.087 PM CEST] INFO [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Collect query for USAGE, UNITS, USAGE_CALIBER, USAGE_VECTOR, DELTA_VECTOR on domain techdepart.ttc-marconi.cz
[04/04/11 02:34:34.096 PM CEST] INFO [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Executing collect query on domain techdepart.ttc-marconi.cz
[04/04/11 02:34:35.065 PM CEST] ERROR [tzScheduler_Worker-6] cisco.CiscoEnergywiseLog: ew_init_socket: Socket connect failed -1, error = 10061(Unknown error)
[04/04/11 02:34:35.065 PM CEST] ERROR [tzScheduler_Worker-6] cisco.CiscoEnergywiseLog: energywise_execQuery: Error connecting to host, query failed.
[04/04/11 02:34:35.065 PM CEST] ERROR [tzScheduler_Worker-6] cisco.CiscoEnergywiseLog: energywise_queryResults: Query failed to execute, no results available.
[04/04/11 02:34:35.065 PM CEST] INFO [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Completed collect query on domain techdepart.ttc-marconi.cz
[04/04/11 02:34:35.065 PM CEST] WARN [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Query result set came back null, likely could not connect to domain server
[04/04/11 02:34:35.065 PM CEST] INFO [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Collect query for RECURRENCE on domain techdepart.ttc-marconi.cz
[04/04/11 02:34:45.074 PM CEST] INFO [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Executing collect query on domain techdepart.ttc-marconi.cz
[04/04/11 02:34:46.044 PM CEST] ERROR [tzScheduler_Worker-6] cisco.CiscoEnergywiseLog: ew_init_socket: Socket connect failed -1, error = 10061(Unknown error)
[04/04/11 02:34:46.044 PM CEST] ERROR [tzScheduler_Worker-6] cisco.CiscoEnergywiseLog: energywise_execQuery: Error connecting to host, query failed.
[04/04/11 02:34:46.044 PM CEST] ERROR [tzScheduler_Worker-6] cisco.CiscoEnergywiseLog: energywise_queryResults: Query failed to execute, no results available.
[04/04/11 02:34:46.044 PM CEST] INFO [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Completed collect query on domain techdepart.ttc-marconi.cz
[04/04/11 02:34:46.044 PM CEST] WARN [tzScheduler_Worker-6] cisco.CiscoEnergywiseAccess: Query result set came back null, likely could not connect to domai
Could you please help?
Best regards,
Michal
Solved! Go to Solution.
04-07-2011 05:01 AM
Hello --
Are you sure EnergyWise is properly configure on the core switch (including management port and password), and that the IOS supports EnergyWise Phase 2 or Phase 2+?
Check your IOS release and platform here:
http://www.cisco.com/en/US/docs/switches/lan/energywise/phase2/ios/release/notes/OL19810.html
The management config line on the switch should looks like this:
SwitchA(config)# energywise management security shared-secret 7 yourstrongpassword
Also is the switch properly configure in Orchstrator? Check the XML file C:\Inetpub\wwwroot\Cisco Systems\EWProvService\Web.config and make sure there is a section like this:
Emmanuel
04-07-2011 06:47 AM
Good news Michal, glad it works.
Don't forget to mark this question as "answered" for others.
Emmanuel
04-07-2011 05:01 AM
Hello --
Emmanuel
04-07-2011 05:49 AM
ios version is correct, but was missing the energywise management security command. It works now.
Thank you for your help.
Michal
04-07-2011 06:47 AM
Emmanuel
