09-27-2009 05:47 PM
Is the EnergyWise plug-in for LMS 3.2 embedded within RME 4.3.1 or is there a separate download for it?
Solved! Go to Solution.
09-27-2009 05:54 PM
The EnergyWise "plug-in" for LMS consists of two updates: RME 4.3.1 and HUM 1.2.1. The RME piece is mainly for provisioning while the HUM piece is purely for monitoring.
Once the updates are installed, you will see each application offers features for EnergyWise management (e.g. reports, tasks, pollers, etc.).
09-27-2009 05:54 PM
12-16-2009 06:15 AM
Is there e new document version for the RME 4.3.1 describing the EnergyWise capabilities and features?
I could not find such document in the RME section of cisco.com
Velin
12-16-2009 07:30 AM
When you download the RME (and HUM) updates, there will be a a readme Release Note included in the target directory. That document outlines the new EnergyWise-specific features introduced in RME 4.3.1.
Note that installation of these updates is via the self-extracting executable, not via CiscoWorks itself.
