취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
VIEWS
답글
epnm : HealthMonitorServer : :heartBeat() : failed to exchange heartbe
mano1
hello :
please ,this log after EPNM has failed
what's the problem?
[HealthMonitorThread-10.5.11.154] HealthMonitorHelper : :IPV4ReachabilityCheck() : IPV4IP::10.5.11.154
09/28/23 23:52:13.236 ERROR [aesSystem] [HealthMonitorThread-10.5.11.154] HealthMonitorServer : :heartBeat() : failed to exchange heartbeat 0: Server 10.5.11.154 is not reacheable through ping command Lets do a try for WebURL access as well...
09/28/23 23:52:23.257 ERROR [aesSystem] [HealthMonitorThread-10.5.11.154] HealthMonitorServer : :heartBeat() : failed to exchange heartbeat
; nested exception is:
java.net.SocketTimeoutException: connect timed out
  org.apache.axis.AxisFault(AxisFault.java):makeFault:101
  org.apache.axis.transport.http.HTTPSender(HTTPSender.java):invoke:159
  org.apache.axis.strategies.InvocationStrategy(InvocationStrategy.java):visit:32
  org.apache.axis.SimpleChain(SimpleChain.java):doVisiting:118
  org.apache.axis.SimpleChain(SimpleChain.java):invoke:83
  org.apache.axis.client.AxisClient(AxisClient.java):invoke:165
  org.apache.axis.client.Call(Call.java):invokeEngine:2784
  org.apache.axis.client.Call(Call.java):invoke:2767
  org.apache.axis.client.Call(Call.java):invoke:2443
  org.apache.axis.client.Call(Call.java):invoke:2366
  org.apache.axis.client.Call(Call.java):invoke:1812
  com.cisco.ws.ha.client.HealthMonitorApiStub(HealthMonitorApiStub.java):heartbeat:1337
  com.cisco.common.ha.server.HealthMonitorServer$HealthMonitorThread(HealthMonitorServer.java):heartBeat:306
  com.cisco.common.ha.server.HealthMonitorServer$HealthMonitorThread(HealthMonitorServer.java):run:241
  java.lang.Thread(null):run:-1
09/28/23 23:52:23.257 INFO  [aesSystem] [HealthMonitorThread-10.5.11.154] HealthMonitorHelper : :IPV4ReachabilityCheck() : IPV4IP::10.5.11.154
09/28/23 23:52:33.276 ERROR [aesSystem] [HealthMonitorThread-10.5.11.154] HealthMonitorServer : :heartBeat() : failed to exchange heartbeat 1: Server 10.5.11.154 is not reacheable through ping command Lets do a try for WebURL access as well...
09/28/23 23:52:43.293 ERROR [aesSystem] [HealthMonitorThread-10.5.11.154] HealthMonitorServer : :heartBeat() : failed to exchange heartbeat
09/28/23 23:52:43.293 INFO  [aesSystem] [HealthMonitorThread-10.5.11.154] HealthMonitorHelper : :IPV4ReachabilityCheck() : IPV4IP::10.5.11.154
09/28/23 23:52:46.317 ERROR [aesSystem] [HealthMonitorThread-10.5.11.154] HealthMonitorServer : :heartBeat() : failed to exchange heartbeat 2: Server 10.5.11.154 is not reacheable through ping command Lets do a try for WebURL access as well...
09/28/23 23:52:49.342 ERROR [aesSystem] [HealthMonitorThread-10.5.11.154] HealthMonitorServer : :heartBeat() : failed to exchange heartbeat
java.net.NoRouteToHostException: No route to host (Host unreachable)
09/28/23 23:52:49.342 INFO  [aesSystem] [HealthMonitorThread-10.5.11.154] HealthMonitorHelper : :failOver() : :Input Params : :remoteIpAddress :10.5.11.154 :reasontoFailover : failed to exchange heartbeat:Entering Time : 09-28-2023 23:52:49
09/28/23 23:52:49.345 INFO  [aesSystem] [HealthMonitorThread-10.5.11.154] HealthMonitorHelper : :failOver() : :primaryAddressInfo : 10.5.11.154 [10.5.11.154] :secondaryAddressInfo : CEPNN2 [10.5.11.156]
09/28/23 23:52:49.345 INFO  [aesSystem] [HealthMonitorThread-10.5.11.154] HealthMonitorHelper : :failOver() : :set state to SECONDARYLOSTPRIMARY removes this instance from thread q :
09/28/23 23:52:49.351 ERROR [aesSystem] [HealthMonitorThread-10.5.11.154] Terminating HealthMonitor for 10.5.11.154
09/28/23 23:52:49.351 INFO  [aesSystem] [HealthMonitorThread-10.5.11.154] HealthMonitorHelper : :failOver() : :Primary Evolved Programmable Network Manager '10.5.11.154 [10.5.11.154]' has failed
09/28/23 23:52:49.352 INFO  [aesSystem] [HealthMonitorThread-10.5.11.154] EmailService:About to send email
09/28/23 23:52:49.424 INFO  [aesSystem] [HealthMonitorThread-10.5.11.154] Email sent successfully
09/28/23 23:52:49.424 INFO  [aesSystem] [HealthMonitorThread-10.5.11.154] EmailService:About to send email
09/28/23 23:52:49.446 INFO  [aesSystem] [HealthMonitorThread-10.5.11.154] Email sent successfully
09/28/23 23:52:49.566 INFO  [aesSystem] [HealthMonitorThread-10.5.11.154] HealthMonitorServer : monitorInterfaces : HMT INSIDE CHECK NETWORK INTERFACES
09/28/23 23:52:49.573 ERROR [aesSystem] [HealthMonitorThread-10.5.11.154] HealthMonitorThread con.close() failed:  No more data to read from socket
09/28/23 23:52:50.505 INFO  [aesSystem] [HealthMonitorThread-10.5.11.154] Started health monitor thread for 10.5.11.154
09/28/23 23:52:55.778 INFO  [aesSystem] [HealthMonitorThread-10.5.11.154] HealthMonitorServer : run() :oomPatternCount: 0
0 응답 0
