EPNM on AWS
ameer-shariff
Hello Team,
Has anyone installed EPNM on AWS EC2 ? I have been trying to import the OVA but it always fails. I have changed the OVA config to ignore disks, but finally it fails as DHCP Error. Has anyone installed successfully or does Cisco has a image to run on AWS ?
Please Advice.
I am not sure AWS supports direct .ova imports. Have you tried converting the .ova to a VMDK, and then import it ?
