Err-disable port on switches
jouellet
I run LMS 2.6 and I wonder to know how to monitor err-disabled ports. I want to configure an alert and afterward get this alert on e-mail. I already configured event sets. Is the err-disabled state a trap or syslog event??
I am a newbie on ciscoworks.
2 Accepted Solutions
The syslog is like this:
%PM-4-ERR_DISABLE: link-flap error detected on Fa0/3, putting Fa0/3 in err-disable state
Create an automated action on RME->Tools->Syslog
You can send e-mail.
david.fernandes
Here are the ones I use for Automated Actions:
SYS-*-3-PORT_COLLDIS:*
PM-*-4-ERR_DISABLE:*
5 Replies 5
david.fernandes
jouellet
I followed the RME guide to set the syslog automation action. The ERR disable appears in syslog.
My smtp server is configured in CS/server/admin/system preference. I ping the smtp, I use telnet ip 25 to test the smtp and it's ok. The smtp that I use is microsoft esmtp mail service.
How can i debug that, the ciscoworks don't send any e-mail.
Set a ip hostname in host file and I changed the smtp server label from ip to hostname.
In the smtp server log file :
2007-04-04 19:50:44 10.8.x.x 2003-noc SMTPSVC1 2003-NOC 10.8.x.x 0 HELO
2007-04-04 19:50:44 10.8.x.x 2003-noc SMTPSVC1 2003-NOC 10.8.x.x 0 QUIT
I there an issue with microsoft esmtp?
I had multiple RME managed devices with the same ip, it's why i didn't received any e-mail. I deleted the duplicated ip devices and it worked.
Thanks for the posts.
