error for copy disk:/defaultRepo
R.P7900
hello ,
i have a problem with copy file from disk:/defaultRepo to one repository that i make in disk:/file .
I use from below command :
# copy disk:/defaultRepo/VER3.3.0.303.107_BKSZ19G_CPU8_MEM3G_RAM15G_SWAP15G_APP_CK3353207043.tar.gpg ftp://reportsOnDemand
Username: admin
Password:
% Error: Transfer failed
but i recieve error : % Error: Transfer failed
can anyone help me?
thanks
7 Replies 7
pieterh
I notice there is no IP-address in the FTP-url?
copy disk:/defaultRepo/<filename> ftp://111.222.333.444/reportsOnDemand
or is reportsOnDemand a DNS-entry that resolves to an ip-address?
you can also add the location as a new repository
repository RemoteRepo
  url ftp://111.222.333.444
  user RepoUser password hash aabbccddeeffgghhiijjkkllmmnn
then list the repository to check if you can access it.
show repository RemoteRepo
then copy a file
copy disk:/defaultRepo/<filename> repository RemoteRepo
at first i want copy backup file into internal disk of prime , and then see backup with software ''Winscp '' and copy it to my pc .
can i without ftp server , take backup ?
you want a disk-to-disk copy?, that should be no problem
then you should not use ftp://... in the destination but also a disk+directory
thanks for your answer.
can you help me , after updating , how can i restore my backup from my repository or my ftp server?
with wich command ?
thanks alot
and how can restore backup from cisco prime v3.3 to cisco prime version 3.5 ?
I suggest you read the Prime Infrastructure 3.5 quick start guide.
in this document is descried how to make your backup and how to restore this.
You can also try to do an "in-line-upgrade" where you do not need to restore
(i would take the backup anyway,  if anything goes wrong, you can do a fresh installation and restore)
reed the section that starts with
You can upgrade the following 3.1.x, 3.2.x, 3.3.x and 3.4.x Prime Infrastructure versions to Prime Infrastructure 3.5:
and check your running version is listed.
thanks alot.
