Error in Authentication
shivam agarwal
Community Member
Hello All,
I am getting error in authetication when I am trying to access a switch through tacacs. I have added the switch in ACS server.
The aaa config is
aaa new-model
aaa authentication login default group tacacs+ line
aaa authentication login console line
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ if-authenticated
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 15 default stop-only group tacacs+
tacacs-server host 10.201.85.222
tacacs-server key ******
line con 0
exec-timeout 30 0
password 7 104A5A1B1010425E
line vty 0 4
exec-timeout 30 0
password 7 045F58041A261C1B
login
line vty 5 15
exec-timeout 30 0
password 7 08251F4C1C1E5542
login
I know i forgot to add enable password in the config. What's the best way to access the switch now.
johnfrancisco
Visitor
Remove connection to the Tacacs server, and the line should fall back to line password for authentication.
Thanks for replying and I did the same thing as you said but I see the same behavior..removing from ACS server it should fall back to line passwords. I am at console and still i am getting the same thing which is wierd ...
User Access Verification
Password:
cs-sbd1-dmz>en
% Error in authentication.
Thanks all, we had to do a password recovery though...So no other otpion..
