Error Problem
I want to connect IBGP and EBGP but i can't
Cisco packet tracer show this Msg.....
%Cisco Packet Tracer does not support internal BGP in this version. Only external neighbors are supported.
2 Accepted Solutions
Mark Elsen
  - Seems like a limitation of your current Packet Tracer instance, try latest version - if applicable
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Georg Pauwen
I agree with @Mark Elsen . iBGP is not supported in Packet Tracer. I get that message even when running version 8.1.1 (the latest):
Router(config)#router bgp 1
Router(config-router)#bgp router-id 1.1.1.1
Router(config-router)#neighbor 1.1.1.2 remote-as 1
5 Replies 5
Mark Elsen
 M.
sswen
Community Member
It does not work
Georg Pauwen
paolo.macchi246
Community Member
I agree with @marce1000 . iBGP is not supported in Packet Tracer. I get that message even when running version 8.2.x (the latest).
I'm sorry, but why can't it be fixed?
Well, firstly, it's not really broken, i.e. it doesn't need to be fixed.  ; )
What the issue is, PT just doesn't provide support for iBGP; just as it also doesn't support many, many (many) other features found in the "real McCoy" IOS versions.
Could Cisco add support for iBGP?  Very likely they could.
But, consider PT is a basic (and free) training tool.  I suspect, at the moment, they see no reason to add support for iBGP.  Of course, they might change their mind and add it later.  (Much has been added to PT over the years.  [Also, what it does support, now more often works "correctly" too.])
If you want something that does support iBGP, and much more, Cisco's CML personal, is available.  The most basic version, I believe is $200 for a year's subscription.
