Error trying open Prime Network clients
Hi Support,
I've installed Prime Network 4.3.2 clients, but when I loggin I received this error message:
org.nanode.launcher.cache.CacheError. This application will be closed.
I already update java to latested version 8, update 221 (build 1.8.0_221-b11)
Could you help with this?
Tks,
5 Replies 5
Mark Elsen
 Ref : https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/network/4-3-2/installation/guide/CiscoPrimeNetwork432InstallationGuide/clients_ig.html
  • Java 8 update 60 is installed on your computer. If not, download it from the Java download site: http://www.java.com .
 Have a test with the above version of Java first.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Thanks for reply.
Installed java 8 update 60, but still same failed.
 - This is a bug ; the only option you have is to open a ticket at Cisco TAC.
    M.
Try to clean the Java JRE cache files and launch the client jnlp file again.
If the error persists, please open a TAC case.
To solve it at least on Win OS, you can open the client using the 'Run as administrator' option
