Error trying open Prime Network clients
Hi Support,
I've installed Prime Network 4.3.2 clients, but when I loggin I received this error message:
org.nanode.launcher.cache.CacheError. This application will be closed.
I already update java to latested version 8, update 221 (build 1.8.0_221-b11)
Could you help with this?
Tks,
5 Replies 5
Mark Elsen
 Ref : https://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/network/4-3-2/installation/guide/CiscoPrimeNetwork432InstallationGuide/clients_ig.html
  • Java 8 update 60 is installed on your computer. If not, download it from the Java download site: http://www.java.com .
 Have a test with the above version of Java first.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thanks for reply.
Installed java 8 update 60, but still same failed.
 - This is a bug ; the only option you have is to open a ticket at Cisco TAC.
    M.
       Beauty and terror
      Just keep going
       No feeling is final
Try to clean the Java JRE cache files and launch the client jnlp file again.
If the error persists, please open a TAC case.
To solve it at least on Win OS, you can open the client using the 'Run as administrator' option
