Error with device performance report
vuonghongvu
Hi all
I had propblem with  Device performance report of LMS 4.0. You could see picture below about the problem. How do resolve it ?
vuonghongvu
Hi all
Here is error about Device performance report. Please help me fix it. Thanks
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: Servlet execution threw an exception
    org.ajaxanywhere.AAFilter.doFilter(AAFilter.java:46)
    com.cisco.nm.cmf.util.AjaxAccessFilter.doFilter(AjaxAccessFilter.java:189)
    com.cisco.nm.cmf.util.AccessLogFilter.doFilter(AccessLogFilter.java:128)
root cause
java.lang.OutOfMemoryError: unable to create new native thread
    java.lang.Thread.start0(Native Method)
    java.lang.Thread.start(Thread.java:640)
    com.sun.net.ssl.internal.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:923)
    com.sun.net.ssl.internal.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1138)
    com.sun.net.ssl.internal.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1165)
    com.sun.net.ssl.internal.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1149)
    sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:434)
    sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:166)
    sun.net.www.protocol.http.HttpURLConnection.getOutputStream(HttpURLConnection.java:1019)
    com.sun.net.ssl.internal.www.protocol.https.HttpsURLConnectionOldImpl.getOutputStream(HttpsURLConnectionOldImpl.java:200)
    com.cisco.nm.xms.ctm.client.DefaultHTTPClientImpl.getOutputStream(DefaultHTTPClientImpl.java:83)
    com.cisco.nm.xms.ctm.client.CTMCall.performBinaryRPC(CTMCall.java:782)
    com.cisco.nm.xms.ctm.client.CTMCall.performRPC(CTMCall.java:694)
    com.cisco.nm.xms.ctm.client.CTMCall.invoke(CTMCall.java:409)
    com.cisco.nm.xms.ctm.client.CTMCall.setMethodAndInvoke(CTMCall.java:449)
    com.cisco.nm.xms.ctm.client.CTMClientProxy.invoke(CTMClientProxy.java:70)
    $Proxy544.evaluateGroup(Unknown Source)
    com.cisco.nm.xms.ogs.client.OGSServerProxy.evaluateGroup(OGSServerProxy.java:900)
    com.cisco.nm.cmf.devsel.DeviceSelectorTreeGenerator.evaluateGroup(DeviceSelectorTreeGenerator.java:2621)
    com.cisco.nm.cmf.devsel.DeviceSelectorTreeGenerator.getFirstLevelGroups(DeviceSelectorTreeGenerator.java:453)
    com.cisco.nm.cmf.devsel.DeviceSelectorTreeGenerator.getGroupsAndObjects(DeviceSelectorTreeGenerator.java:399)
    com.cisco.nm.cmf.devsel.DeviceSelectorTreeGenerator.getTreeEntries(DeviceSelectorTreeGenerator.java:192)
    com.cisco.nm.uii.hos.HOSRequestHelper.generateParameterEntries(HOSRequestHelper.java:5560)
    com.cisco.nm.uii.hos.HOSRequestHelper.constructHOSTree(HOSRequestHelper.java:1010)
    com.cisco.nm.upm.reports.devicedashboard.DeviceDashBoardAction.perform(DeviceDashBoardAction.java:65)
    org.apache.struts.action.ActionServlet.processActionPerform(ActionServlet.java:1786)
    org.apache.struts.action.ActionServlet.process(ActionServlet.java:1585)
    org.apache.struts.action.ActionServlet.doGet(ActionServlet.java:491)
    javax.servlet.http.HttpServlet.service(HttpServlet.java:627)
    javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
note The full stack trace of the root cause is available in the Apache Tomcat/5.5.29 logs.
Seems the processes may be down. please check NMSROOT/bin/pdshow -brief and see if many processes and maily containign UPM are down?
If so, please try to restart the daemon manager and check again!!
-Thanks Vinod **Rating Encourages contributors, and its really free. **
