Showing results forĀ
Search instead forĀ
Did you mean:Ā
Etherchannel issue between 3750 stack and WS-CBS3012 for IBM blade centre
madhankumar.g
We are trying to configure Etherchannel between four ports of cisco 3750 stack(2ports from one switch of stack and two ports from another switch of same stack). We are facing issues with this setup. The ports in WS-CBS3012 are going to err disable mode.
Is  there any limitations associated with such a cross-stack etherchannel configuration. Please suggest if there is any particular sequence of configuration involved.
Switch1 in stack
int gi 3/0/3
switchport mo trunk
switchport trunk allowed vlan 10-30
sw tr en dot1q
channel-group 1 mode on
spanning-tree guard root
switch 2 in stack
int gi 3/0/3
switchport mode trunk
sw tr en dot1q
int port-channel 1
sw tr en dot1q
in WS-CBS3012 ports are configured with trunk,allowed vlan and etherchannel configuration with mode on.
With Regards,
Madhan kumar G
madhankumar.g
The commnad "no spanning-tree etherchannel guard misconfig" on WS-CBS3012 resolved the issue.
Madhan kumar G
