Ethernet interfaces missing from SNMP walk
mmmhosk
Visitor
I have run into an SNMP issue when connecting a N2k FEX to a N5k switch. Prior to connecting the FEX, all interfaces on the N5k are found running snmpwalk against OID 1.3.6.1.2.1.2.2.1.2.
Post connecting the FEX (two fibres in port channel) and configuring ports 1-16 as fibre channel, only the FEX fibre channel ports are discovered with snmpwalk. All the N5k and non FC interfaces on the FEX are not available.
N5k is running 7.3(0)N1(1).
Has anyone come across this before or where to start looking to try and fix? Thanks.
0 Replies 0
