Event manager with large output (how to filter???)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-09-2018 07:54 AM - edited 03-01-2019 06:23 PM
Hello experts,
I'm trying to figure it out a way that I can manipulate an output in a way that I can store 2 variables, here's my output:
SW-CLOSET_3-100#show cts interface summary | in MANUAL
Te5/2 MANUAL OPEN unknown unknown invalid Invalid
Te6/2 MANUAL OPEN unknown unknown invalid Invalid
SW-CLOSET_3-100#
I need to grab Te5/2 and Te6/2 from that output since I need to make some configurations after the device reloads since I have a BUG that everytime that these devices (Catalyst 9400) reload CTS fails so I need to remove CTS and re-apply it back.
I have another example where I'm trying to manipulate a big output:
RTR_CISCO#ssh sshmyip.com
Translating "sshmyip.com"...domain server (8.8.8.8) [OK]
"comment": "## Your IP Address is XXX.XXX.XXX.XXX (43683) ##",
"family": "ipv4",
"ip": "XXX.XXX.XXX.XXX",
"port": "43683",
"protocol": "ssh",
"version": "v1.0.0",
"website": "https://github.com/packetsar/checkmyip"
[Connection to sshmyip.com closed by foreign host]
RTR_CISCO#
I'm using this output to build another EEM that works with DDNS on a DMZ area, but I have no idea how to just grab the IP part.
Any ideas on both solutions???
Thanks as always and appreciate the time that you take to read my post.
- Labels:
Network Management
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-09-2018 01:08 PM
For the first one:
cli command "show cts interface summary | in MANUAL"
set intfs ""
foreach line "$_cli_result" "\n"
regexp "^([A-Z][a-z0-9/]+)[[:space:]]+MANUAL" "$line" match intf
if $_regexp_result eq "1"
append intfs "$intf "
end
end
foreach intf $intfs
puts "Interface is $intf"
end
For the second one:
cli command "ssh sshmyip.com"
regexp "Your IP Address is ([0-9.]+)" "$_cli_result" match ip
puts "IP is $ip"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-09-2018 02:28 PM - edited 02-09-2018 02:29 PM
Joe,
As always you rock doing Scripting, just one question, I'm having issues on the second Script, the IP related:
This is my config:RTR_CISCO#show run | sec event manager
event manager directory user policy "flash:/TCL_Scripts/"
event manager directory user library "flash:/TCL_Scripts/"
event manager policy Login_SSH_VPN_HTTP_HTTPS.tcl
event manager applet ddns authorization bypass
event none
action 001 cli command "ssh sshmyip.com"
action 005 wait 15
action 010 regexp "Your IP Address is ([0-9.]+)" "$_cli_result" match ip
action 015 puts "IP is $ip"
RTR_CISCO#
I added a delay, 15 seconds because that's the time that the ssh takes to respond and get the information to the console.
Feb 9 16:18:11.959 CST: %HA_EM-6-LOG: ddns : DEBUG(cli_lib) : : CTL : cli_open called.
Feb 9 16:18:11.979 CST: %HA_EM-6-LOG: ddns : DEBUG(cli_lib) : : IN : RTR_CISCO#ssh sshmyip.com
Feb 9 16:18:12.191 CST: %HA_EM-6-LOG: ddns : DEBUG(cli_lib) : : OUT : RTR_CISCO#
Feb 9 16:18:27.202 CST: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: ip
Feb 9 16:18:27.202 CST: %HA_EM-3-FMPD_ERROR: Error executing applet ddns statement 015
Feb 9 16:18:27.202 CST: %HA_EM-6-LOG: ddns : DEBUG(cli_lib) : : CTL : cli_close called.
Feb 9 16:18:27.206 CST: tty is now going through its death sequence
I already checked the regex and should work, I'm not sure what I'm missing.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-10-2018 02:13 PM
First, you absolutely cannot add a wait 15. That does nothing other than ensure your applet won't finish. Second, EEM doesn't have a pre-configured username. If you do not specify the CLI username, then commands like SSH will fail. Something like this will work:
event none maxrun 35
action 000 cli command "enable"
action 001 cli command "ssh -l bogus sshmyip.com" pattern "}"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-13-2018 06:55 AM
Joe,
Thanks again for your help, the main reason why I'm trying to get my IP is because I would like to send an http request from my router to a website to update my public IP, I already know that the router is not capable to do that so I need to use TCL, actually I found a post where you posted a solution:
https://supportforums.cisco.com/t5/eem-scripting/dyndns-update-script/td-p/2240108
The problem that I'm facing is when I try to merge bot solutions, everytime that I make a request for the new IP my router it freezes, this just sumple Script that I'm using is to retrieve the information:
::cisco::eem::event_register_none maxrun 300 queue_priority low nice 0
namespace import ::cisco::eem::*
if [catch {cli_open} result] {
error $result $errorInfo
} else {
array set cli1 $result
if [catch {cli_exec $cli1(fd) "ssh sshmyip.com" } _cli_result] {
error $_cli_result $errorInfo
set _regexp_result [regexp {Your IP Address is ([0-9.]+)} $_cli_result match ip]
if { $_regexp_result == 0 } {
puts "Error retrieving information from sshmyip.com"
exit 1
puts $ip
exit 0
And if I want to use both:
#::cisco::eem::event_register_timer cron name queue_priority low nice 0
#TCL created to retrieve public IP from sshmyip.com
#TCL also will send an email with the information provided
namespace import ::cisco::lib::*
source my_smtp_lib.tcl
namespace import ::custom::lib::*
set user "NO-IP USERNAME"
set pass "NO-IP PASSWORD"
set fqdn "NO-IP FQDN"
} else {
if [catch {cli_exec $cli1(fd) "ssh -l bogus sshmyip.com" pattern "website"} _cli_result] {
exit 1
set ipinterface $ip
set url "http://$user:$pass@dynupdate.no-ip.com/nic/update?hostname=$fqdn&myip=$ip"
# Close open cli before exit.
catch {cli_close $cli1(fd) $cli1(tty_id)} result
set auth "Basic [base64::encode $user:$pass]"
set headerl [list Authorization $auth]
if {[catch {http::geturl $url -headers $headerl -queryblocksize 50 -type "text/plain" } token]} {
action_syslog priority info msg "http request failed"
} else {
action_syslog priority info msg "Response: [http::data $token]"
I tried using telnetmyip.com and sshmyip.com with the exact same result. What do I'm missing? Also I would like to know if I use the cron function I can ask for my new IP every X time, right?
Thanks a lot Joe.
BTW. Do you recommend a book where I can study EEM or TCL Scripting? I already bought the one from Cisco but do you have a second one?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-13-2018 07:04 AM
Take the applet I provided in my previous example and convert it to Tcl at https://www.marcuscom.com/convert_applet . Use that as a base to add the HTTP call. I'm not sure where you're getting the customer::lib and SMTP library from. They are not needed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-13-2018 02:28 PM - edited 02-13-2018 04:08 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-13-2018 04:09 PM
Thanks Joe, I already changed to TCL, the Script that you sent and I'm receiving an error on the pattern that we use (}), it looks like TCL is taking that character a close of a function:
WS-C3560CG(config)#event manager policy ddns.tcl
EEM Register event failed:extra characters after close-brace
while compiling
"if [catch {cli_read_pattern $cli1(fd) ""
EEM configuration: failed to retrieve intermediate registration result for policy ddns.tcl
WS-C3560CG(config)#
The pattern is:
if [catch {cli_read_pattern $cli1(fd) "}"} _cli_result] {
Now I change it to use different output like:
if [catch {cli_read_pattern $cli1(fd) "website"} _cli_result] {
and now works but every time that I try to run the tcl looks like I'm getting stuck in the process:
WS-C3560CG#event manager run ddns.tcl
invalid command name "Connection"
while executing
"Connection to sshmyip.com closed by foreign host"
invoked from within
"$slave eval $Contents"
(procedure "eval_script" line 7)
invoked from within
"eval_script slave $scriptname"
invoked from within
"if {$security_level == 1} { #untrusted script
interp create -safe slave
interp share {} stdin slave
interp share {} stdout slave
(file "tmpsys:/lib/tcl/base.tcl" line 50)
Tcl policy execute failed: invalid command name "Connection"
WS-C3560CG#
Based on "if {$security_level == 1} { #untrusted script I found:
https://supportforums.cisco.com/t5/network-management/eem-applet-help-appreciated/td-p/1411434
I think that my Script stucks on getting the IP since it takes between 2 to 3 seconds, what do you think?
Regards and thanks as always.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-14-2018 06:28 AM
Try this:
::cisco::eem::event_register_none maxrun 35 # # This EEM tcl policy was generated by the EEM applet conversion # utility at http://www.marcuscom.com/convert_applet/ # using the following applet: # # event manager applet ddns authorization bypass # event none maxrun 35 # action 000 cli command "enable" # action 001 cli command "ssh -l bogus sshmyip.com" pattern "}" # action 010 regexp "Your IP Address is ([0-9.]+)" "$_cli_result" match ip # action 015 puts "IP is $ip" # namespace import ::cisco::eem::* namespace import ::cisco::lib::* array set arr_einfo [event_reqinfo] if [catch {cli_open} result] { error $result $errorInfo } else { array set cli1 $result } if [catch {cli_exec $cli1(fd) "enable"} _cli_result] { error $_cli_result $errorInfo } if [catch {cli_write $cli1(fd) "ssh -l bogus sshmyip.com"} _cli_result] { error $_cli_result $errorInfo } if [catch {cli_read_pattern $cli1(fd) "\}"} _cli_result] { error $_cli_result $errorInfo } set _regexp_result [regexp {Your IP Address is ([0-9.]+)} $_cli_result match ip] puts "IP is $ip" # Close open cli before exit. catch {cli_close $cli1(fd) $cli1(tty_id)} result
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-20-2018 06:45 AM
Hey Joe,
Thanks for the support. I added the TCL that you suggested but I don't see any result, actually when I run the applet I lose ssh prompt for about 15 seconds, I think because the script is running, here's my output from the log:
Log Buffer (16384 bytes):
.670 ET: [fh_tty_read_cmd] read not ready
Feb 20 09:43:16.769 ET: [fh_tty_read_cmd]
Feb 20 09:43:16.769 ET: [fh_tty_read_cmd] read not ready
Feb 20 09:43:16.874 ET: [fh_tty_read_cmd]
Feb 20 09:43:16.874 ET: [fh_tty_read_cmd] read not ready
Feb 20 09:43:16.974 ET: [fh_tty_read_cmd]
<<< SNIP >>>
Feb 20 09:43:33.468 ET: [fh_tty_read_cmd] read not ready
Feb 20 09:43:33.568 ET: [fh_tty_read_cmd]
WS-C3560CG# Process Forced Exit- MAXRUN timer expired.
while executing
"error $_cli_result $errorInfo"
invoked from within
invoked from within
invoked from within
Tcl policy execute failed: Process Forced Exit- MAXRUN timer expired
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-20-2018 10:08 AM
You have to increase the maxrun time of your Tcl policy. The Tcl policy worked for me with a maxrun of 35.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-20-2018 12:51 PM - edited 02-20-2018 12:57 PM
Hello Joe,
By mistake, I forgot to apply authorization bypass. After I add that option on the policy everything went perfectly. Now I have 2 questions, I've been trying to manipulate the ddns with the update from the script that you sent:
set user "no-ip user"
set pass "no-ip password"
set fqdn "no-ip fqdn"
} else {
#next line for troubleshooting purposes
puts "IP is $ip"
#catch {cli_close $cli1(fd) $cli1(tty_id)} result
# Second part, get the no-ip http request
set ipinterface $ip
puts "http://$user:$pass@dynupdate.no-ip.com/nic/update?hostname=$fqdn&myip=$ip"
} else {
exit 0
The logs that I see when I run the TCL are:
Feb 20 15:50:21.162 ET: fh_tcl_get_mode: mode = 1, StartupScript = tmpsys:/lib/tcl/base.tcl, RealScript = tmpsys:/eem_policy/ddns_full.tcl
Feb 20 15:50:21.162 ET: fh_set_tclpath_global: tcl_library is set to tmpsys:/lib/tcl
Feb 20 15:50:21.167 ET: fh_set_tclpath_global: auto_path is set to tmpsys:/eem_lib_user tmpsys:/eem_lib_system
Feb 20 15:50:21.225 ET: fh_register_evreg_cmds: tctx=7BE1E08, dummy=1
Feb 20 15:50:21.225 ET: fh_tcl_compile_policy: evaluating policy: startup_scriptname=tmpsys:/lib/tcl/base.tcl, real_scriptname=tmpsys:/eem_policy/ddns_full.tcl
Feb 20 15:50:21.235 ET: fh_tcl_slave_interp_init: interp=7968778, tctx=7BE1E08, fh_mode=1, real=tmpsys:/eem_policy/ddns_full.tcl, curr=ddns_full.tcl
Feb 20 15:50:21.267 ET: fh_register_evreg_cmds: tctx=7BE1E08, dummy=1
Feb 20 15:50:22.866 ET: [fh_event_reqinfo_cmd]
Feb 20 15:50:22.866 ET: [fh_process_event_reqinfo]
Feb 20 15:50:22.871 ET: [fh_event_reqinfo_cmd] event_trigger_num 1 event_id 9 job_id 2888 event_pub_sec 1519159821 event_pub_msec 157 event_pub_time 1519159821.157 event_type {131} event_type_string {none} event_severity {severity-normal} argc {0}
Feb 20 15:50:22.876 ET: [fh_cli_debug_cmd]
Feb 20 15:50:22.876 ET: [fh_tty_open_cmd]
Feb 20 15:50:22.887 ET: [fh_sys_reqinfo_routername_cmd]
Feb 20 15:50:22.903 ET: [fh_tty_read_cmd]
Feb 20 15:50:22.903 ET: [fh_tty_read_cmd] size= 2267
Feb 20 15:50:22.903 ET: [fh_tty_prompt_cmd]
Feb 20 15:50:23.128 ET: [fh_cli_debug_cmd]
Feb 20 15:50:23.133 ET: [fh_cli_debug_cmd]
Feb 20 15:50:23.133 ET: [fh_tty_write_cmd]
Feb 20 15:50:23.133 ET: [fh_tty_write_cmd] cmd = enable, cmdsize = 6
Feb 20 15:50:23.133 ET: [fh_sys_reqinfo_routername_cmd]
Feb 20 15:50:23.149 ET: [fh_tty_read_cmd]
Feb 20 15:50:23.149 ET: [fh_tty_read_cmd] size= 13
Feb 20 15:50:23.149 ET: [fh_tty_prompt_cmd]
Feb 20 15:50:23.254 ET: [fh_cli_debug_cmd]
Feb 20 15:50:23.254 ET: [fh_tty_write_cmd]
Feb 20 15:50:23.254 ET: [fh_tty_write_cmd] cmd = ssh -l bogus sshmyip.com, cmdsize = 24
Feb 20 15:50:23.264 ET: [fh_tty_read_cmd]
Feb 20 15:50:23.264 ET: [fh_tty_read_cmd] read not ready
Feb 20 15:50:23.364 ET: [fh_tty_read_cmd]
Feb 20 15:50:23.364 ET: [fh_tty_read_cmd] read not ready
Feb 20 15:50:23.469 ET: [fh_tty_read_cmd]
Feb 20 15:50:23.469 ET: [fh_tty_read_cmd] read not ready
Feb 20 15:50:23.610 ET: [fh_tty_read_cmd]
Feb 20 15:50:23.610 ET: [fh_tty_read_cmd] read not ready
Feb 20 15:50:23.736 ET: [fh_tty_read_cmd]
Feb 20 15:50:23.736 ET: [fh_tty_read_cmd] read not ready
Feb 20 15:50:23.836 ET: [fh_tty_read_cmd]
Feb 20 15:50:23.836 ET: [fh_tty_read_cmd] read not ready
Feb 20 15:50:23.993 ET: [fh_tty_read_cmd]
Feb 20 15:50:23.993 ET: [fh_tty_read_cmd] read not ready
Feb 20 15:50:24.108 ET: [fh_tty_read_cmd]
Feb 20 15:50:24.108 ET: [fh_tty_read_cmd] read not ready
Feb 20 15:50:24.234 ET: [fh_tty_read_cmd]
Feb 20 15:50:24.234 ET: [fh_tty_read_cmd] read not ready
Feb 20 15:50:24.334 ET: [fh_tty_read_cmd]
Feb 20 15:50:24.334 ET: [fh_tty_read_cmd] read not ready
Feb 20 15:50:24.439 ET: [fh_tty_read_cmd]
Feb 20 15:50:24.439 ET: [fh_tty_read_cmd] read not ready
Feb 20 15:50:24.549 ET: [fh_tty_read_cmd]
Feb 20 15:50:24.549 ET: [fh_tty_read_cmd] read not ready
Feb 20 15:50:24.654 ET: [fh_tty_read_cmd]
Feb 20 15:50:24.654 ET: [fh_tty_read_cmd] read not ready
Feb 20 15:50:24.753 ET: [fh_tty_read_cmd]
Feb 20 15:50:24.753 ET: [fh_tty_read_cmd] read not ready
Feb 20 15:50:24.853 ET: [fh_tty_read_cmd]
Feb 20 15:50:24.853 ET: [fh_tty_read_cmd] size= 236
Feb 20 15:50:24.968 ET: [fh_cli_debug_cmd]
Feb 20 15:50:24.984 ET: [fh_cli_debug_cmd]
Feb 20 15:50:24.984 ET: [fh_tty_close_cmd]
Feb 20 15:50:25.802 ET: [fh_action_syslog_cmd]
Feb 20 15:50:25.802 ET: priority: 6
Feb 20 15:50:25.802 ET: %HA_EM-6-LOG: ddns_full.tcl: http request failed
Feb 20 15:50:25.802 ET: [fh_tcl_exit_cmd]
Feb 20 15:50:25.802 ET: [fh_tcl_exit_cmd] set _exit_code=0
Feb 20 15:50:25.823 ET: fh_tcl_assoc_data_delproc: freeing tctx=0x7BE1E08
Also how can I configure a timer that this TCL should run every 4 hours?
Thanks, I really appreciate your help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-21-2018 06:58 AM
I've never used this service, so I have no idea how the URLs are supposed to be constructed. You might try using this URL in a tool like cURL to see what it gives you. You might also try printing http::code and http:error to see what the server returns.
Note: if this is supposed to be a GET, you should omit -queryblocksize and -type.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-21-2018 07:33 AM - edited 02-21-2018 07:35 AM
Joe,
The base of the update is (example update request string):
http://username:password@dynupdate.no-ip.com/nic/update?hostname=mytest.testdomain.com&myip=1.2.3.4
This is kind of the same tool like dyndns: https://www.noip.com/integrate/request
If you use that URL that I sent (update request string) and put your credentials, automatically no-ip will update your public IP, for example, I use my credentials and when I hit enter the webpage responds as good with the IP that you just configured and their system will be updated:
Next webpage when I hit enter:
good 1.2.3.4
Here's some output from the debugs:
Feb 21 10:30:29.240 ET: %HA_EM-6-LOG: ddns_full.tcl : DEBUG(cli_lib) : OUT : {
Feb 21 10:30:29.240 ET: %HA_EM-6-LOG: ddns_full.tcl : DEBUG(cli_lib) : OUT : "comment": "## Your IP Address is <<<OUTPUT OMMITED>>> (27139) ##",
Feb 21 10:30:29.240 ET: %HA_EM-6-LOG: ddns_full.tcl : DEBUG(cli_lib) : OUT : "family": "ipv4",
Feb 21 10:30:29.240 ET: %HA_EM-6-LOG: ddns_full.tcl : DEBUG(cli_lib) : OUT : "ip": "<<<OUTPUT OMMITED>>>",
Feb 21 10:30:29.240 ET: %HA_EM-6-LOG: ddns_full.tcl : DEBUG(cli_lib) : OUT : "port": "27139",
Feb 21 10:30:29.240 ET: %HA_EM-6-LOG: ddns_full.tcl : DEBUG(cli_lib) : OUT : "protocol": "ssh",
Feb 21 10:30:29.240 ET: %HA_EM-6-LOG: ddns_full.tcl : DEBUG(cli_lib) : OUT : "version": "v1.1.0",
Feb 21 10:30:29.240 ET: %HA_EM-6-LOG: ddns_full.tcl : DEBUG(cli_lib) : OUT : "website": "https://github.com/packetsar/checkmyip"
Feb 21 10:30:29.240 ET: %HA_EM-6-LOG: ddns_full.tcl : DEBUG(cli_lib) : OUT : }
Feb 21 10:30:29.261 ET: [fh_cli_debug_cmd]
Feb 21 10:30:29.261 ET: %HA_EM-6-LOG: ddns_full.tcl : DEBUG(cli_lib) : CTL : cli_close called.
Feb 21 10:30:29.261 ET: [fh_tty_close_cmd]
Feb 21 10:30:29.712 ET:
Feb 21 10:30:29.712 ET: tty is now going through its death sequence
Feb 21 10:30:30.079 ET: [fh_action_syslog_cmd]
Feb 21 10:30:30.079 ET: priority: 6
Feb 21 10:30:30.079 ET: %HA_EM-6-LOG: ddns_full.tcl: http request failed
Feb 21 10:30:30.079 ET: [fh_tcl_exit_cmd]
Feb 21 10:30:30.079 ET: [fh_tcl_exit_cmd] set _exit_code=0
Feb 21 10:30:30.079 ET: fh_server: fh_io_ipc_msg: received msg FH_MSG_API_CLOSE from client 3273 pclient 3273
Feb 21 10:30:30.079 ET: fh_io_ipc_msg: received FH_MSG_API_CLOSE client=3273
Feb 21 10:30:30.100 ET: fh_tcl_assoc_data_delproc: freeing tctx=0x7AF8E4C
Feb 21 10:30:30.488 ET: received SIGCHLD pulse from child death pid=223
Feb 21 10:30:30.488 ET: received pulse from child death code=1; epc=0x7BE141C
Feb 21 10:30:30.488 ET: EEM policy ddns_full.tcl has completed with normal exit status of 0x0 exec_status=2 event_completion=0
Feb 21 10:30:30.488 ET: fh_reg_send_msg_to_fd server sending FH_MSG_EVENT_PUBLISH_DONE message to FD:none xos_ipc_sync_send to fdc->eph = 1245202)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-21-2018 07:43 AM
Beyond what I already said, you don't need the username and password in the URL if you're passing a Basic auth header. If you've fixed your use of the Tcl as I've said, and you still have problems you'll need to print those additional diagnostics or use a packet capture tool to figure out why it's not working.
