executed commands history
barakg
hello guys,
anyone familiar with a way to see a logg of executed commands history?
one of our customers had a service down because someone entered a 'shutdown vlan XX' command on the NFS vlan.
i know there is such log file in Juniper and HP.
thanks in advanced,
barak
Francesco Molino
If you have tacacs configured, you should be able to see them on your tacacs monitoring tool.
If you enabled the logging of config changes with archive, you will see them on your syslog server (if you send them to syslog) or on your logginf buffer (if buffer big enough to keep history).
Without that, there's no log file you can access to see who did what.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
